md5.h
1 /*
2  ***********************************************************************
3  ** md5.h -- header file for implementation of MD5 **
4  ** RSA Data Security, Inc. MD5 Message-Digest Algorithm **
5  ** Created: 2/17/90 RLR **
6  ** Revised: 12/27/90 SRD,AJ,BSK,JT Reference C version **
7  ** Revised (for MD5): RLR 4/27/91 **
8  ** -- G modified to have y&~z instead of y&z **
9  ** -- FF, GG, HH modified to add in last register done **
10  ** -- Access pattern: round 2 works mod 5, round 3 works mod 3 **
11  ** -- distinct additive constant for each step **
12  ** -- round 4 added, working mod 7 **
13  ***********************************************************************
14  */
15
16 /*
17  ***********************************************************************
18  ** Copyright (C) 1990, RSA Data Security, Inc. All rights reserved. **
19  ** **
20  ** License to copy and use this software is granted provided that **
21  ** it is identified as the "RSA Data Security, Inc. MD5 Message- **
22  ** Digest Algorithm" in all material mentioning or referencing this **
23  ** software or this function. **
24  ** **
25  ** License is also granted to make and use derivative works **
26  ** provided that such works are identified as "derived from the RSA **
27  ** Data Security, Inc. MD5 Message-Digest Algorithm" in all **
28  ** material mentioning or referencing the derived work. **
29  ** **
30  ** RSA Data Security, Inc. makes no representations concerning **
31  ** either the merchantability of this software or the suitability **
32  ** of this software for any particular purpose. It is provided "as **
33  ** is" without express or implied warranty of any kind. **
34  ** **
35  ** These notices must be retained in any copies of any part of this **
36  ** documentation and/or software. **
37  ***********************************************************************
38  */
39
40 #ifndef __MD5_INCLUDE__
41
42 #include <stdint.h>
43
44 #ifdef __cplusplus
45 extern "C" {
46 #endif /* __cplusplus */
47
48 /* typedef a 32-bit type */
49 typedef uint32_t UINT4;
50
51 #define MD5_BLOCK_LENGTH 64
52 #define MD5_DIGEST_LENGTH 16
53
54 /* Data structure for MD5 (Message-Digest) computation */
55 typedef struct {
56  UINT4 i[2]; /* number of _bits_ handled mod 2^64 */
57  UINT4 buf[4]; /* scratch buffer */
58  unsigned char in[64]; /* input buffer */
59  unsigned char digest[16]; /* actual digest after MD5Final call */
60 } MD5_CTX;
61
62 void MD5Init (MD5_CTX *);
63 void MD5Update (MD5_CTX *, const void *, unsigned int);
64 void MD5Final (unsigned char [16], MD5_CTX *);
65
66 #ifdef __cplusplus
67 }
68 #endif /* __cplusplus */
69
70 #define __MD5_INCLUDE__
71 #endif /* __MD5_INCLUDE__ */
Definition: md5.h:56
