score
cpu
m68k
m68k
m68360.h
1
6
7
8
9
10
** MOTOROLA MC68360 QUAD INTEGRATED COMMUNICATIONS CONTROLLER (QUICC) **
11
12
** HARDWARE DECLARATIONS **
13
14
15
** Submitted By: **
16
17
** W. Eric Norum **
18
** Saskatchewan Accelerator Laboratory **
19
** University of Saskatchewan **
20
** 107 North Road **
21
** Saskatoon, Saskatchewan, CANADA **
22
** S7N 5C6 **
23
24
** eric@skatter.usask.ca **
25
26
27
28
29
30
#ifndef _RTEMS_M68K_M68360_H
31
#define _RTEMS_M68K_M68360_H
32
33
34
35
* REGISTER SUBBLOCKS *
36
37
38
39
40
* Memory controller registers
41
42
typedef
struct
m360MEMCRegisters_
43
unsigned
long
br;
44
unsigned
long
or;
45
unsigned
long
_pad[2];
46
m360MEMCRegisters_t
47
48
49
* Serial Communications Controller registers
50
51
typedef
struct
m360SCCRegisters_
52
unsigned
long
gsmr_l;
53
unsigned
long
gsmr_h;
54
unsigned
short
psmr;
55
unsigned
short
_pad0;
56
unsigned
short
todr;
57
unsigned
short
dsr;
58
unsigned
short
scce;
59
unsigned
short
_pad1;
60
unsigned
short
sccm;
61
unsigned
char
_pad2;
62
unsigned
char
sccs;
63
unsigned
long
_pad3[2];
64
m360SCCRegisters_t
65
66
67
* Serial Management Controller registers
68
69
typedef
struct
m360SMCRegisters_
70
unsigned
short
_pad0;
71
unsigned
short
smcmr;
72
unsigned
short
_pad1;
73
unsigned
char
smce;
74
unsigned
char
_pad2;
75
unsigned
short
_pad3;
76
unsigned
char
smcm;
77
unsigned
char
_pad4;
78
unsigned
long
_pad5;
79
m360SMCRegisters_t
80
81
82
83
84
* Miscellaneous Parameters *
85
86
87
typedef
struct
m360MiscParms_
88
unsigned
short
rev_num;
89
unsigned
short
_res1;
90
unsigned
long
_res2;
91
unsigned
long
_res3;
92
m360MiscParms_t
93
94
95
96
* RISC Timers *
97
98
99
typedef
struct
m360TimerParms_
100
unsigned
short
tm_base;
101
unsigned
short
_tm_ptr;
102
unsigned
short
_r_tmr;
103
unsigned
short
_r_tmv;
104
unsigned
long
tm_cmd;
105
unsigned
long
tm_cnt;
106
m360TimerParms_t
107
108
109
* RISC Controller Configuration Register (RCCR)
110
* All other bits in this register are either reserved or
111
* used only with a Motorola-supplied RAM microcode packge.
112
113
#define M360_RCCR_TIME (1<<15)
/* Enable timer */
114
#define M360_RCCR_TIMEP(x) ((x)<<8)
/* Timer period */
115
116
117
* Command register
118
* Set up this register before issuing a M360_CR_OP_SET_TIMER command.
119
120
#define M360_TM_CMD_V (1<<31)
/* Set to enable timer */
121
#define M360_TM_CMD_R (1<<30)
/* Set for automatic restart */
122
#define M360_TM_CMD_TIMER(x) ((x)<<16)
/* Select timer */
123
#define M360_TM_CMD_PERIOD(x) (x)
/* Timer period (16 bits) */
124
125
126
127
* DMA Controllers *
128
129
130
typedef
struct
m360IDMAparms_
131
unsigned
short
ibase;
132
unsigned
short
ibptr;
133
unsigned
long
_istate;
134
unsigned
long
_itemp;
135
m360IDMAparms_t
136
137
138
139
* Serial Communication Controllers *
140
141
142
typedef
struct
m360SCCparms_
143
unsigned
short
rbase;
144
unsigned
short
tbase;
145
unsigned
char
rfcr;
146
unsigned
char
tfcr;
147
unsigned
short
mrblr;
148
unsigned
long
_rstate;
149
unsigned
long
_pad0;
150
unsigned
short
_rbptr;
151
unsigned
short
_pad1;
152
unsigned
long
_pad2;
153
unsigned
long
_tstate;
154
unsigned
long
_pad3;
155
unsigned
short
_tbptr;
156
unsigned
short
_pad4;
157
unsigned
long
_pad5;
158
unsigned
long
_rcrc;
159
unsigned
long
_tcrc;
160
union
161
struct
162
unsigned
long
_res0;
163
unsigned
long
_res1;
164
unsigned
short
max_idl;
165
unsigned
short
_idlc;
166
unsigned
short
brkcr;
167
unsigned
short
parec;
168
unsigned
short
frmec;
169
unsigned
short
nosec;
170
unsigned
short
brkec;
171
unsigned
short
brklen;
172
unsigned
short
uaddr[2];
173
unsigned
short
_rtemp;
174
unsigned
short
toseq;
175
unsigned
short
character[8];
176
unsigned
short
rccm;
177
unsigned
short
rccr;
178
unsigned
short
rlbc;
179
} uart;
180
struct
181
unsigned
long
crc_p;
182
unsigned
long
crc_c;
183
} transparent;
184
185
} un;
186
m360SCCparms_t
187
188
typedef
struct
m360SCCENparms_
189
unsigned
short
rbase;
190
unsigned
short
tbase;
191
unsigned
char
rfcr;
192
unsigned
char
tfcr;
193
unsigned
short
mrblr;
194
unsigned
long
_rstate;
195
unsigned
long
_pad0;
196
unsigned
short
_rbptr;
197
unsigned
short
_pad1;
198
unsigned
long
_pad2;
199
unsigned
long
_tstate;
200
unsigned
long
_pad3;
201
unsigned
short
_tbptr;
202
unsigned
short
_pad4;
203
unsigned
long
_pad5;
204
unsigned
long
_rcrc;
205
unsigned
long
_tcrc;
206
union
207
struct
208
unsigned
long
_res0;
209
unsigned
long
_res1;
210
unsigned
short
max_idl;
211
unsigned
short
_idlc;
212
unsigned
short
brkcr;
213
unsigned
short
parec;
214
unsigned
short
frmec;
215
unsigned
short
nosec;
216
unsigned
short
brkec;
217
unsigned
short
brklen;
218
unsigned
short
uaddr[2];
219
unsigned
short
_rtemp;
220
unsigned
short
toseq;
221
unsigned
short
character[8];
222
unsigned
short
rccm;
223
unsigned
short
rccr;
224
unsigned
short
rlbc;
225
} uart;
226
struct
227
unsigned
long
c_pres;
228
unsigned
long
c_mask;
229
unsigned
long
crcec;
230
unsigned
long
alec;
231
unsigned
long
disfc;
232
unsigned
short
pads;
233
unsigned
short
ret_lim;
234
unsigned
short
_ret_cnt;
235
unsigned
short
mflr;
236
unsigned
short
minflr;
237
unsigned
short
maxd1;
238
unsigned
short
maxd2;
239
unsigned
short
_maxd;
240
unsigned
short
dma_cnt;
241
unsigned
short
_max_b;
242
unsigned
short
gaddr1;
243
unsigned
short
gaddr2;
244
unsigned
short
gaddr3;
245
unsigned
short
gaddr4;
246
unsigned
long
_tbuf0data0;
247
unsigned
long
_tbuf0data1;
248
unsigned
long
_tbuf0rba0;
249
unsigned
long
_tbuf0crc;
250
unsigned
short
_tbuf0bcnt;
251
unsigned
short
paddr_h;
252
unsigned
short
paddr_m;
253
unsigned
short
paddr_l;
254
unsigned
short
p_per;
255
unsigned
short
_rfbd_ptr;
256
unsigned
short
_tfbd_ptr;
257
unsigned
short
_tlbd_ptr;
258
unsigned
long
_tbuf1data0;
259
unsigned
long
_tbuf1data1;
260
unsigned
long
_tbuf1rba0;
261
unsigned
long
_tbuf1crc;
262
unsigned
short
_tbuf1bcnt;
263
unsigned
short
_tx_len;
264
unsigned
short
iaddr1;
265
unsigned
short
iaddr2;
266
unsigned
short
iaddr3;
267
unsigned
short
iaddr4;
268
unsigned
short
_boff_cnt;
269
unsigned
short
taddr_h;
270
unsigned
short
taddr_m;
271
unsigned
short
taddr_l;
272
} ethernet;
273
struct
274
unsigned
long
crc_p;
275
unsigned
long
crc_c;
276
} transparent;
277
} un;
278
m360SCCENparms_t
279
280
281
* Receive and transmit function code register bits
282
* These apply to the function code registers of all devices, not just SCC.
283
284
#define M360_RFCR_MOT (1<<4)
285
#define M360_RFCR_DMA_SPACE 0x8
286
#define M360_TFCR_MOT (1<<4)
287
#define M360_TFCR_DMA_SPACE 0x8
288
289
290
291
* Serial Management Controllers *
292
293
294
typedef
struct
m360SMCparms_
295
unsigned
short
rbase;
296
unsigned
short
tbase;
297
unsigned
char
rfcr;
298
unsigned
char
tfcr;
299
unsigned
short
mrblr;
300
unsigned
long
_rstate;
301
unsigned
long
_pad0;
302
unsigned
short
_rbptr;
303
unsigned
short
_pad1;
304
unsigned
long
_pad2;
305
unsigned
long
_tstate;
306
unsigned
long
_pad3;
307
unsigned
short
_tbptr;
308
unsigned
short
_pad4;
309
unsigned
long
_pad5;
310
union
311
struct
312
unsigned
short
max_idl;
313
unsigned
short
_pad0;
314
unsigned
short
brklen;
315
unsigned
short
brkec;
316
unsigned
short
brkcr;
317
unsigned
short
_r_mask;
318
} uart;
319
struct
320
unsigned
short
_pad0[5];
321
} transparent;
322
} un;
323
m360SMCparms_t
324
325
326
* Mode register
327
328
#define M360_SMCMR_CLEN(x) ((x)<<11)
/* Character length */
329
#define M360_SMCMR_2STOP (1<<10)
/* 2 stop bits */
330
#define M360_SMCMR_PARITY (1<<9)
/* Enable parity */
331
#define M360_SMCMR_EVEN (1<<8)
/* Even parity */
332
#define M360_SMCMR_SM_GCI (0<<4)
/* GCI Mode */
333
#define M360_SMCMR_SM_UART (2<<4)
/* UART Mode */
334
#define M360_SMCMR_SM_TRANSPARENT (3<<4)
/* Transparent Mode */
335
#define M360_SMCMR_DM_LOOPBACK (1<<2)
/* Local loopback mode */
336
#define M360_SMCMR_DM_ECHO (2<<2)
/* Echo mode */
337
#define M360_SMCMR_TEN (1<<1)
/* Enable transmitter */
338
#define M360_SMCMR_REN (1<<0)
/* Enable receiver */
339
340
341
* Event and mask registers (SMCE, SMCM)
342
343
#define M360_SMCE_BRK (1<<4)
344
#define M360_SMCE_BSY (1<<2)
345
#define M360_SMCE_TX (1<<1)
346
#define M360_SMCE_RX (1<<0)
347
348
349
350
* Serial Peripheral Interface *
351
352
353
typedef
struct
m360SPIparms_
354
unsigned
short
rbase;
355
unsigned
short
tbase;
356
unsigned
char
rfcr;
357
unsigned
char
tfcr;
358
unsigned
short
mrblr;
359
unsigned
long
_rstate;
360
unsigned
long
_pad0;
361
unsigned
short
_rbptr;
362
unsigned
short
_pad1;
363
unsigned
long
_pad2;
364
unsigned
long
_tstate;
365
unsigned
long
_pad3;
366
unsigned
short
_tbptr;
367
unsigned
short
_pad4;
368
unsigned
long
_pad5;
369
m360SPIparms_t
370
371
372
* Mode register (SPMODE)
373
374
#define M360_SPMODE_LOOP (1<<14)
375
#define M360_SPMODE_CI (1<<13)
/* Clock invert */
376
#define M360_SPMODE_CP (1<<12)
/* Clock phase */
377
#define M360_SPMODE_DIV16 (1<<11)
/* Divide BRGCLK by 16 */
378
#define M360_SPMODE_REV (1<<10)
/* Reverse data */
379
#define M360_SPMODE_MASTER (1<<9)
/* SPI is master */
380
#define M360_SPMODE_EN (1<<8)
/* Enable SPI */
381
#define M360_SPMODE_CLEN(x) ((x)<<4)
382
#define M360_SPMODE_PM(x) (x)
/* Prescaler modulus */
383
384
385
* Mode register (SPCOM)
386
387
#define M360_SPCOM_STR (1<<7)
/* Start transmit */
388
389
390
* Event and mask registers (SPIE, SPIM)
391
392
#define M360_SPIE_MME (1<<5)
/* Multi-master error */
393
#define M360_SPIE_TXE (1<<4)
/* Tx error */
394
#define M360_SPIE_BSY (1<<2)
/* Busy condition*/
395
#define M360_SPIE_TXB (1<<1)
/* Tx buffer */
396
#define M360_SPIE_RXB (1<<0)
/* Rx buffer */
397
398
399
400
* SDMA (SCC, SMC, SPI) Buffer Descriptors *
401
402
403
typedef
struct
m360BufferDescriptor_
404
unsigned
short
status;
405
unsigned
short
length;
406
volatile
void
*buffer;
407
m360BufferDescriptor_t
408
409
410
* Bits in receive buffer descriptor status word
411
412
#define M360_BD_EMPTY (1<<15)
/* Ethernet, SCC UART, SMC UART, SPI */
413
#define M360_BD_WRAP (1<<13)
414
#define M360_BD_INTERRUPT (1<<12)
415
#define M360_BD_LAST (1<<11)
/* Ethernet, SPI */
416
#define M360_BD_CONTROL_CHAR (1<<11)
/* SCC UART */
417
#define M360_BD_FIRST_IN_FRAME (1<<10)
/* Ethernet */
418
#define M360_BD_ADDRESS (1<<10)
/* SCC UART */
419
#define M360_BD_CONTINUOUS (1<<9)
/* SCC UART, SMC UART, SPI */
420
#define M360_BD_MISS (1<<8)
/* Ethernet */
421
#define M360_BD_IDLE (1<<8)
/* SCC UART, SMC UART */
422
#define M360_BD_ADDRSS_MATCH (1<<7)
/* SCC UART */
423
#define M360_BD_LONG (1<<5)
/* Ethernet */
424
#define M360_BD_BREAK (1<<5)
425
#define M360_BD_NONALIGNED (1<<4)
/* Ethernet */
426
#define M360_BD_FRAMING_ERROR (1<<4)
427
#define M360_BD_SHORT (1<<3)
/* Ethernet */
428
#define M360_BD_PARITY_ERROR (1<<3)
429
#define M360_BD_CRC_ERROR (1<<2)
/* Ethernet */
430
#define M360_BD_OVERRUN (1<<1)
431
#define M360_BD_COLLISION (1<<0)
/* Ethernet */
432
#define M360_BD_CARRIER_LOST (1<<0)
/* SCC UART */
433
#define M360_BD_MASTER_ERROR (1<<0)
/* SPI */
434
435
436
* Bits in transmit buffer descriptor status word
437
* Many bits have the same meaning as those in receiver buffer descriptors.
438
439
#define M360_BD_READY (1<<15)
440
#define M360_BD_PAD (1<<14)
/* Ethernet */
441
#define M360_BD_CTS_REPORT (1<<11)
/* SCC UART */
442
#define M360_BD_TX_CRC (1<<10)
/* Ethernet */
443
#define M360_BD_DEFER (1<<9)
/* Ethernet */
444
#define M360_BD_HEARTBEAT (1<<8)
/* Ethernet */
445
#define M360_BD_PREAMBLE (1<<8)
446
#define M360_BD_LATE_COLLISION (1<<7)
/* Ethernet */
447
#define M360_BD_NO_STOP_BIT (1<<7)
/* SCC UART */
448
#define M360_BD_RETRY_LIMIT (1<<6)
/* Ethernet */
449
#define M360_BD_RETRY_COUNT(x) (((x)&0x3C)>>2)
/* Ethernet */
450
#define M360_BD_UNDERRUN (1<<1)
/* Ethernet, SPI */
451
/* Ethernet */
452
#define M360_BD_CTS_LOST (1<<0)
/* SCC UART */
453
454
455
456
* IDMA Buffer Descriptors *
457
458
459
typedef
struct
m360IDMABufferDescriptor_
460
unsigned
short
status;
461
unsigned
short
_pad;
462
unsigned
long
length;
463
void
*source;
464
void
*destination;
465
m360IDMABufferDescriptor_t
466
467
468
469
* RISC Communication Processor Module Command Register (CR) *
470
471
472
#define M360_CR_RST (1<<15)
/* Reset communication processor */
473
#define M360_CR_OP_INIT_RX_TX (0<<8)
/* SCC, SMC UART, SMC GCI, SPI */
474
#define M360_CR_OP_INIT_RX (1<<8)
/* SCC, SMC UART, SPI */
475
#define M360_CR_OP_INIT_TX (2<<8)
476
#define M360_CR_OP_INIT_HUNT (3<<8)
/* SCC, SMC UART */
477
#define M360_CR_OP_STOP_TX (4<<8)
/* SCC, SMC UART */
478
#define M360_CR_OP_GR_STOP_TX (5<<8)
/* SCC */
479
#define M360_CR_OP_INIT_IDMA (5<<8)
/* IDMA */
480
#define M360_CR_OP_RESTART_TX (6<<8)
/* SCC, SMC UART */
481
#define M360_CR_OP_CLOSE_RX_BD (7<<8)
482
#define M360_CR_OP_SET_GRP_ADDR (8<<8)
/* SCC */
483
#define M360_CR_OP_SET_TIMER (8<<8)
/* Timer */
484
#define M360_CR_OP_GCI_TIMEOUT (9<<8)
/* SMC GCI */
485
#define M360_CR_OP_RESERT_BCS (10<<8)
/* SCC */
486
#define M360_CR_OP_GCI_ABORT (10<<8)
/* SMC GCI */
487
#define M360_CR_CHAN_SCC1 (0<<4)
/* Channel selection */
488
#define M360_CR_CHAN_SCC2 (4<<4)
489
#define M360_CR_CHAN_SPI (5<<4)
490
#define M360_CR_CHAN_TIMER (5<<4)
491
#define M360_CR_CHAN_SCC3 (8<<4)
492
#define M360_CR_CHAN_SMC1 (9<<4)
493
#define M360_CR_CHAN_IDMA1 (9<<4)
494
#define M360_CR_CHAN_SCC4 (12<<4)
495
#define M360_CR_CHAN_SMC2 (13<<4)
496
#define M360_CR_CHAN_IDMA2 (13<<4)
497
#define M360_CR_FLG (1<<0)
/* Command flag */
498
499
500
501
* System Protection Control Register (SYPCR) *
502
503
504
#define M360_SYPCR_SWE (1<<7)
/* Software watchdog enable */
505
#define M360_SYPCR_SWRI (1<<6)
/* Software watchdog reset select */
506
#define M360_SYPCR_SWT1 (1<<5)
/* Software watchdog timing bit 1 */
507
#define M360_SYPCR_SWT0 (1<<4)
/* Software watchdog timing bit 0 */
508
#define M360_SYPCR_DBFE (1<<3)
/* Double bus fault monitor enable */
509
#define M360_SYPCR_BME (1<<2)
/* Bus monitor external enable */
510
#define M360_SYPCR_BMT1 (1<<1)
/* Bus monitor timing bit 1 */
511
#define M360_SYPCR_BMT0 (1<<0)
/* Bus monitor timing bit 0 */
512
513
514
515
* Memory Control Registers *
516
517
518
#define M360_GMR_RCNT(x) ((x)<<24)
/* Refresh count */
519
#define M360_GMR_RFEN (1<<23)
/* Refresh enable */
520
#define M360_GMR_RCYC(x) ((x)<<21)
/* Refresh cycle length */
521
#define M360_GMR_PGS(x) ((x)<<18)
/* Page size */
522
#define M360_GMR_DPS_32BIT (0<<16)
/* DRAM port size */
523
#define M360_GMR_DPS_16BIT (1<<16)
524
#define M360_GMR_DPS_8BIT (2<<16)
525
#define M360_GMR_DPS_DSACK (3<<16)
526
#define M360_GMR_WBT40 (1<<15)
/* Wait between 040 transfers */
527
#define M360_GMR_WBTQ (1<<14)
/* Wait between 360 transfers */
528
#define M360_GMR_SYNC (1<<13)
/* Synchronous external access */
529
#define M360_GMR_EMWS (1<<12)
/* External master wait state */
530
#define M360_GMR_OPAR (1<<11)
/* Odd parity */
531
#define M360_GMR_PBEE (1<<10)
/* Parity bus error enable */
532
#define M360_GMR_TSS40 (1<<9)
/* TS* sample for 040 */
533
#define M360_GMR_NCS (1<<8)
/* No CPU space */
534
#define M360_GMR_DWQ (1<<7)
/* Delay write for 360 */
535
#define M360_GMR_DW40 (1<<6)
/* Delay write for 040 */
536
#define M360_GMR_GAMX (1<<5)
/* Global address mux enable */
537
538
#define M360_MEMC_BR_FC(x) ((x)<<7)
/* Function code limit */
539
#define M360_MEMC_BR_TRLXQ (1<<6)
/* Relax timing requirements */
540
#define M360_MEMC_BR_BACK40 (1<<5)
/* Burst acknowledge to 040 */
541
#define M360_MEMC_BR_CSNT40 (1<<4)
/* CS* negate timing for 040 */
542
#define M360_MEMC_BR_CSNTQ (1<<3)
/* CS* negate timing for 360 */
543
#define M360_MEMC_BR_PAREN (1<<2)
/* Enable parity checking */
544
#define M360_MEMC_BR_WP (1<<1)
/* Write Protect */
545
#define M360_MEMC_BR_V (1<<0)
/* Base/Option register are valid */
546
547
#define M360_MEMC_OR_TCYC(x) ((x)<<28)
/* Cycle length (clocks) */
548
#define M360_MEMC_OR_WAITS(x) M360_MEMC_OR_TCYC((x)+1)
549
#define M360_MEMC_OR_2KB 0x0FFFF800
/* Address range */
550
#define M360_MEMC_OR_4KB 0x0FFFF000
551
#define M360_MEMC_OR_8KB 0x0FFFE000
552
#define M360_MEMC_OR_16KB 0x0FFFC000
553
#define M360_MEMC_OR_32KB 0x0FFF8000
554
#define M360_MEMC_OR_64KB 0x0FFF0000
555
#define M360_MEMC_OR_128KB 0x0FFE0000
556
#define M360_MEMC_OR_256KB 0x0FFC0000
557
#define M360_MEMC_OR_512KB 0x0FF80000
558
#define M360_MEMC_OR_1MB 0x0FF00000
559
#define M360_MEMC_OR_2MB 0x0FE00000
560
#define M360_MEMC_OR_4MB 0x0FC00000
561
#define M360_MEMC_OR_8MB 0x0F800000
562
#define M360_MEMC_OR_16MB 0x0F000000
563
#define M360_MEMC_OR_32MB 0x0E000000
564
#define M360_MEMC_OR_64MB 0x0C000000
565
#define M360_MEMC_OR_128MB 0x08000000
566
#define M360_MEMC_OR_256MB 0x00000000
567
#define M360_MEMC_OR_FCMC(x) ((x)<<7)
/* Function code mask */
568
#define M360_MEMC_OR_BCYC(x) ((x)<<5)
/* Burst cycle length (clocks) */
569
#define M360_MEMC_OR_PGME (1<<3)
/* Page mode enable */
570
#define M360_MEMC_OR_32BIT (0<<1)
/* Port size */
571
#define M360_MEMC_OR_16BIT (1<<1)
572
#define M360_MEMC_OR_8BIT (2<<1)
573
#define M360_MEMC_OR_DSACK (3<<1)
574
#define M360_MEMC_OR_DRAM (1<<0)
/* Dynamic RAM select */
575
576
577
578
* SI Mode Register (SIMODE) *
579
580
581
#define M360_SI_SMC2_BITS 0xFFFF0000
/* All SMC2 bits */
582
#define M360_SI_SMC2_TDM (1<<31)
/* Multiplexed SMC2 */
583
#define M360_SI_SMC2_BRG1 (0<<28)
/* SMC2 clock souce */
584
#define M360_SI_SMC2_BRG2 (1<<28)
585
#define M360_SI_SMC2_BRG3 (2<<28)
586
#define M360_SI_SMC2_BRG4 (3<<28)
587
#define M360_SI_SMC2_CLK5 (0<<28)
588
#define M360_SI_SMC2_CLK6 (1<<28)
589
#define M360_SI_SMC2_CLK7 (2<<28)
590
#define M360_SI_SMC2_CLK8 (3<<28)
591
#define M360_SI_SMC1_BITS 0x0000FFFF
/* All SMC1 bits */
592
#define M360_SI_SMC1_TDM (1<<15)
/* Multiplexed SMC1 */
593
#define M360_SI_SMC1_BRG1 (0<<12)
/* SMC1 clock souce */
594
#define M360_SI_SMC1_BRG2 (1<<12)
595
#define M360_SI_SMC1_BRG3 (2<<12)
596
#define M360_SI_SMC1_BRG4 (3<<12)
597
#define M360_SI_SMC1_CLK1 (0<<12)
598
#define M360_SI_SMC1_CLK2 (1<<12)
599
#define M360_SI_SMC1_CLK3 (2<<12)
600
#define M360_SI_SMC1_CLK4 (3<<12)
601
602
603
604
* SDMA Configuration Register (SDMA) *
605
606
607
#define M360_SDMA_FREEZE (2<<13)
/* Freeze on next bus cycle */
608
#define M360_SDMA_SISM_7 (7<<8)
/* Normal interrupt service mask */
609
#define M360_SDMA_SAID_4 (4<<4)
/* Normal arbitration ID */
610
#define M360_SDMA_INTE (1<<1)
/* SBER interrupt enable */
611
#define M360_SDMA_INTB (1<<0)
/* SBKP interrupt enable */
612
613
614
615
* Baud (sic) Rate Generators *
616
617
618
#define M360_BRG_RST (1<<17)
/* Reset generator */
619
#define M360_BRG_EN (1<<16)
/* Enable generator */
620
#define M360_BRG_EXTC_BRGCLK (0<<14)
/* Source is BRGCLK */
621
#define M360_BRG_EXTC_CLK2 (1<<14)
/* Source is CLK2 pin */
622
#define M360_BRG_EXTC_CLK6 (2<<14)
/* Source is CLK6 pin */
623
#define M360_BRG_ATB (1<<13)
/* Autobaud */
624
#define M360_BRG_115200 (13<<1)
/* Assume 25 MHz clock */
625
#define M360_BRG_57600 (26<<1)
626
#define M360_BRG_38400 (40<<1)
627
#define M360_BRG_19200 (80<<1)
628
#define M360_BRG_9600 (162<<1)
629
#define M360_BRG_4800 (324<<1)
630
#define M360_BRG_2400 (650<<1)
631
#define M360_BRG_1200 (1301<<1)
632
#define M360_BRG_600 (2603<<1)
633
#define M360_BRG_300 ((324<<1) | 1)
634
#define M360_BRG_150 ((650<<1) | 1)
635
#define M360_BRG_75 ((1301<<1) | 1)
636
637
638
639
* MC68360 DUAL-PORT RAM AND REGISTERS *
640
641
642
typedef
struct
m360_
643
644
* Dual-port RAM
645
646
unsigned
char
dpram0[0x400];
/* Microcode program */
647
unsigned
char
dpram1[0x200];
648
unsigned
char
dpram2[0x100];
/* Microcode scratch */
649
unsigned
char
dpram3[0x100];
/* Not on REV A or B masks */
650
unsigned
char
_rsv0[0xC00-0x800];
651
m360SCCENparms_t
scc1p;
652
unsigned
char
_rsv1[0xCB0-0xC00-
sizeof
m360SCCENparms_t
653
m360MiscParms_t
miscp;
654
unsigned
char
_rsv2[0xD00-0xCB0-
sizeof
m360MiscParms_t
655
m360SCCparms_t
scc2p;
656
unsigned
char
_rsv3[0xD80-0xD00-
sizeof
m360SCCparms_t
657
m360SPIparms_t
spip;
658
unsigned
char
_rsv4[0xDB0-0xD80-
sizeof
m360SPIparms_t
659
m360TimerParms_t
tmp;
660
unsigned
char
_rsv5[0xE00-0xDB0-
sizeof
m360TimerParms_t
661
m360SCCparms_t
scc3p;
662
unsigned
char
_rsv6[0xE70-0xE00-
sizeof
m360SCCparms_t
663
m360IDMAparms_t
idma1p;
664
unsigned
char
_rsv7[0xE80-0xE70-
sizeof
m360IDMAparms_t
665
m360SMCparms_t
smc1p;
666
unsigned
char
_rsv8[0xF00-0xE80-
sizeof
m360SMCparms_t
667
m360SCCparms_t
scc4p;
668
unsigned
char
_rsv9[0xF70-0xF00-
sizeof
m360SCCparms_t
669
m360IDMAparms_t
idma2p;
670
unsigned
char
_rsv10[0xF80-0xF70-
sizeof
m360IDMAparms_t
671
m360SMCparms_t
smc2p;
672
unsigned
char
_rsv11[0x1000-0xF80-
sizeof
m360SMCparms_t
673
674
675
* SIM Block
676
677
unsigned
long
mcr;
678
unsigned
long
_pad00;
679
unsigned
char
avr;
680
unsigned
char
rsr;
681
unsigned
short
_pad01;
682
unsigned
char
clkocr;
683
unsigned
char
_pad02;
684
unsigned
short
_pad03;
685
unsigned
short
pllcr;
686
unsigned
short
_pad04;
687
unsigned
short
cdvcr;
688
unsigned
short
pepar;
689
unsigned
long
_pad05[2];
690
unsigned
short
_pad06;
691
unsigned
char
sypcr;
692
unsigned
char
swiv;
693
unsigned
short
_pad07;
694
unsigned
short
picr;
695
unsigned
short
_pad08;
696
unsigned
short
pitr;
697
unsigned
short
_pad09;
698
unsigned
char
_pad10;
699
unsigned
char
swsr;
700
unsigned
long
bkar;
701
unsigned
long
bcar;
702
unsigned
long
_pad11[2];
703
704
705
* MEMC Block
706
707
unsigned
long
gmr;
708
unsigned
short
mstat;
709
unsigned
short
_pad12;
710
unsigned
long
_pad13[2];
711
m360MEMCRegisters_t
memc[8];
712
unsigned
char
_pad14[0xF0-0xD0];
713
unsigned
char
_pad15[0x100-0xF0];
714
unsigned
char
_pad16[0x500-0x100];
715
716
717
* IDMA1 Block
718
719
unsigned
short
iccr;
720
unsigned
short
_pad17;
721
unsigned
short
cmr1;
722
unsigned
short
_pad18;
723
unsigned
long
sapr1;
724
unsigned
long
dapr1;
725
unsigned
long
bcr1;
726
unsigned
char
fcr1;
727
unsigned
char
_pad19;
728
unsigned
char
cmar1;
729
unsigned
char
_pad20;
730
unsigned
char
csr1;
731
unsigned
char
_pad21;
732
unsigned
short
_pad22;
733
734
735
* SDMA Block
736
737
unsigned
char
sdsr;
738
unsigned
char
_pad23;
739
unsigned
short
sdcr;
740
unsigned
long
sdar;
741
742
743
* IDMA2 Block
744
745
unsigned
short
_pad24;
746
unsigned
short
cmr2;
747
unsigned
long
sapr2;
748
unsigned
long
dapr2;
749
unsigned
long
bcr2;
750
unsigned
char
fcr2;
751
unsigned
char
_pad26;
752
unsigned
char
cmar2;
753
unsigned
char
_pad27;
754
unsigned
char
csr2;
755
unsigned
char
_pad28;
756
unsigned
short
_pad29;
757
unsigned
long
_pad30;
758
759
760
* CPIC Block
761
762
unsigned
long
cicr;
763
unsigned
long
cipr;
764
unsigned
long
cimr;
765
unsigned
long
cisr;
766
767
768
* Parallel I/O Block
769
770
unsigned
short
padir;
771
unsigned
short
papar;
772
unsigned
short
paodr;
773
unsigned
short
padat;
774
unsigned
long
_pad31[2];
775
unsigned
short
pcdir;
776
unsigned
short
pcpar;
777
unsigned
short
pcso;
778
unsigned
short
pcdat;
779
unsigned
short
pcint;
780
unsigned
short
_pad32;
781
unsigned
long
_pad33[5];
782
783
784
* TIMER Block
785
786
unsigned
short
tgcr;
787
unsigned
short
_pad34;
788
unsigned
long
_pad35[3];
789
unsigned
short
tmr1;
790
unsigned
short
tmr2;
791
unsigned
short
trr1;
792
unsigned
short
trr2;
793
unsigned
short
tcr1;
794
unsigned
short
tcr2;
795
unsigned
short
tcn1;
796
unsigned
short
tcn2;
797
unsigned
short
tmr3;
798
unsigned
short
tmr4;
799
unsigned
short
trr3;
800
unsigned
short
trr4;
801
unsigned
short
tcr3;
802
unsigned
short
tcr4;
803
unsigned
short
tcn3;
804
unsigned
short
tcn4;
805
unsigned
short
ter1;
806
unsigned
short
ter2;
807
unsigned
short
ter3;
808
unsigned
short
ter4;
809
unsigned
long
_pad36[2];
810
811
812
* CP Block
813
814
unsigned
short
cr;
815
unsigned
short
_pad37;
816
unsigned
short
rccr;
817
unsigned
short
_pad38;
818
unsigned
long
_pad39[3];
819
unsigned
short
_pad40;
820
unsigned
short
rter;
821
unsigned
short
_pad41;
822
unsigned
short
rtmr;
823
unsigned
long
_pad42[5];
824
825
826
* BRG Block
827
828
unsigned
long
brgc1;
829
unsigned
long
brgc2;
830
unsigned
long
brgc3;
831
unsigned
long
brgc4;
832
833
834
* SCC Block
835
836
m360SCCRegisters_t
scc1;
837
m360SCCRegisters_t
scc2;
838
m360SCCRegisters_t
scc3;
839
m360SCCRegisters_t
scc4;
840
841
842
* SMC Block
843
844
m360SMCRegisters_t
smc1;
845
m360SMCRegisters_t
smc2;
846
847
848
* SPI Block
849
850
unsigned
short
spmode;
851
unsigned
short
_pad43[2];
852
unsigned
char
spie;
853
unsigned
char
_pad44;
854
unsigned
short
_pad45;
855
unsigned
char
spim;
856
unsigned
char
_pad46[2];
857
unsigned
char
spcom;
858
unsigned
short
_pad47[2];
859
860
861
* PIP Block
862
863
unsigned
short
pipc;
864
unsigned
short
_pad48;
865
unsigned
short
ptpr;
866
unsigned
long
pbdir;
867
unsigned
long
pbpar;
868
unsigned
short
_pad49;
869
unsigned
short
pbodr;
870
unsigned
long
pbdat;
871
unsigned
long
_pad50[6];
872
873
874
* SI Block
875
876
unsigned
long
simode;
877
unsigned
char
sigmr;
878
unsigned
char
_pad51;
879
unsigned
char
sistr;
880
unsigned
char
sicmr;
881
unsigned
long
_pad52;
882
unsigned
long
sicr;
883
unsigned
short
_pad53;
884
unsigned
short
sirp[2];
885
unsigned
short
_pad54;
886
unsigned
long
_pad55[2];
887
unsigned
char
siram[256];
888
m360_t
889
890
extern
volatile
m360_t
m360;
891
892
893
* definitions for the port b SPI pin bits
894
895
#define M360_PB_SPI_MISO_MSK (1<< 3)
896
#define M360_PB_SPI_MOSI_MSK (1<< 2)
897
#define M360_PB_SPI_CLK_MSK (1<< 1)
898
899
#endif
/* _RTEMS_M68K_M68360_H */
m360_
Definition:
m68360.h:642
Definition:
m68360.h:459
m360MiscParms_
Definition:
m68360.h:87
m360TimerParms_
Definition:
m68360.h:99
m360SMCRegisters_
Definition:
m68360.h:69
m360SCCRegisters_
Definition:
m68360.h:51
m360MEMCRegisters_
Definition:
m68360.h:42
m360SCCENparms_
Definition:
m68360.h:188
Definition:
m68360.h:403
m360SMCparms_
Definition:
m68360.h:294
m360SPIparms_
Definition:
m68360.h:353
m360SCCparms_
Definition:
m68360.h:142
m360IDMAparms_
Definition:
m68360.h:130
