m32r.h
1
12 /*
13  * COPYRIGHT (c) 1989-1999.
14  * On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef _RTEMS_SCORE_NO_CPU_H
22 #define _RTEMS_SCORE_NO_CPU_H
23
24 #ifdef __cplusplus
25 extern "C" {
26 #endif
27
28 /*
29  * This file contains the information required to build
30  * RTEMS for a particular member of the NO CPU family.
31  * It does this by setting variables to indicate which
32  * implementation dependent features are present in a particular
33  * member of the family.
34  *
35  * This is a good place to list all the known CPU models
36  * that this port supports and which RTEMS CPU model they correspond
37  * to.
38  */
39
40 #if defined(rtems_multilib)
41 /*
42  * Figure out all CPU Model Feature Flags based upon compiler
43  * predefines.
44  */
45
46 #define CPU_MODEL_NAME "rtems_multilib"
47 #define NOCPU_HAS_FPU 1
48
49 #elif defined(__m32r__)
50
51 #define CPU_MODEL_NAME "m32r"
52 #define NOCPU_HAS_FPU 1
53
54 #else
55
56 #error "Unsupported CPU Model"
57
58 #endif
59
60 /*
61  * Define the name of the CPU family.
62  */
63
64 #define CPU_NAME "NO CPU"
65
66 #ifdef __cplusplus
67 }
68 #endif
69
70 #endif /* _RTEMS_SCORE_NO_CPU_H */
