list.h
1 /*
2  * JFFS2 -- Journalling Flash File System, Version 2.
3  *
4  *
5  * Created by Jonathan Larmour <jlarmour@redhat.com>
6  *
7  *===========================================================================
8  * ####ECOSGPLCOPYRIGHTBEGIN####
9  * -------------------------------------------
10  * This file is part of eCos, the Embedded Configurable Operating System.
11  * Copyright (C) 2002, 2003 Free Software Foundation, Inc.
12  *
13  * eCos is free software; you can redistribute it and/or modify it under
14  * the terms of the GNU General Public License as published by the Free
15  * Software Foundation; either version 2 or (at your option) any later
16  * version.
17  *
18  * eCos is distributed in the hope that it will be useful, but WITHOUT
19  * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
20  * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
21  * for more details.
22  *
23  * You should have received a copy of the GNU General Public License
24  * along with eCos; if not, write to the Free Software Foundation, Inc.,
25  * 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
26  *
27  * As a special exception, if other files instantiate templates or use
28  * macros or inline functions from this file, or you compile this file
29  * and link it with other works to produce a work based on this file,
30  * this file does not by itself cause the resulting work to be covered by
31  * the GNU General Public License. However the source code for this file
32  * must still be made available in accordance with section (3) of the GNU
33  * General Public License v2.
34  *
35  * This exception does not invalidate any other reasons why a work based
36  * on this file might be covered by the GNU General Public License.
37  * -------------------------------------------
38  * ####ECOSGPLCOPYRIGHTEND####
39  *===========================================================================
40  *
41  */
42
43 #ifndef CYGONCE_FS_JFFS2_LIST_H
44 #define CYGONCE_FS_JFFS2_LIST_H
45
46
47 /* -----------------------------------------------------------------------*/
48
49 /* Doubly linked list implementation to replace the GPL'd one used in
50  the Linux kernel. */
51
52 #include <stddef.h>
53 #include <cyg/infra/cyg_type.h>
54
55 /* TYPES */
56
57 struct list_head {
58  struct list_head *next;
59  struct list_head *prev;
60 };
61
62 /* MACROS */
63
64 #define LIST_HEAD_INIT(name) { &(name), &(name) }
65
66 #define LIST_HEAD(name) \
67  struct list_head name = LIST_HEAD_INIT(name)
68
69 #define INIT_LIST_HEAD( _list_ ) \
70 CYG_MACRO_START \
71 (_list_)->next = (_list_)->prev = (_list_); \
72 CYG_MACRO_END
73
74 /* FUNCTIONS */
75
76 /* Insert an entry _after_ the specified entry */
77 static __inline__ void
78 list_add( struct list_head *newent, struct list_head *afterthisent )
79 {
80  struct list_head *next = afterthisent->next;
81  newent->next = next;
82  newent->prev = afterthisent;
83  afterthisent->next = newent;
84  next->prev = newent;
85 } /* list_add() */
86
87 /* Insert an entry _before_ the specified entry */
88 static __inline__ void
89 list_add_tail( struct list_head *newent, struct list_head *beforethisent )
90 {
91  struct list_head *prev = beforethisent->prev;
92  newent->prev = prev;
93  newent->next = beforethisent;
94  beforethisent->prev = newent;
95  prev->next = newent;
96 } /* list_add_tail() */
97
98 /* Delete the specified entry */
99 static __inline__ void
100 list_del( struct list_head *ent )
101 {
102  ent->prev->next = ent->next;
103  ent->next->prev = ent->prev;
104 } /* list_del() */
105
106 static __inline__ void
107 list_move( struct list_head *list, struct list_head *head )
108 {
109  list_del( list );
110  list_add( list, head );
111 }
112
113 static __inline__ void
114 list_move_tail( struct list_head *list, struct list_head *head )
115 {
116  list_del( list );
117  list_add_tail( list, head );
118 }
119
120 /* Is this list empty? */
121 static __inline__ int
122 list_empty( struct list_head *list )
123 {
124  return ( list->next == list );
125 } /* list_empty() */
126
127 /* list_entry - Assuming you have a struct of type _type_ that contains a
128  list which has the name _member_ in that struct type, then given the
129  address of that list in the struct, _list_, this returns the address
130  of the container structure */
131
132 #define list_entry( _list_, _type_, _member_ ) \
133  ((_type_ *)((char *)(_list_)-(char *)(offsetof(_type_,_member_))))
134
135 /* list_for_each - using _ent_, iterate through list _list_ */
136
137 #define list_for_each( _ent_, _list_ ) \
138  for ( (_ent_) = (_list_)->next; \
139  (_ent_) != (_list_); \
140  (_ent_) = (_ent_)->next )
141
142 /*
143  * list_for_each_entry - this function can be use to iterate over all
144  * items in a list* _list_ with it's head at _head_ and link _item_
145  */
146 #define list_for_each_entry(_list_, _head_, _item_) \
147 for ((_list_) = list_entry((_head_)->next, typeof(*_list_), _item_); \
148  &((_list_)->_item_) != (_head_); \
149  (_list_) = list_entry((_list_)->_item_.next, typeof(*_list_), _item_))
150
151 /* -----------------------------------------------------------------------*/
152 #endif /* #ifndef CYGONCE_FS_JFFS2_LIST_H */
153 /* EOF list.h */
Definition: list.h:58
