pci.h
1 /*
2  * PCI library. Defines in this file was taken from FreeBSD and auto-generated
3  * pci_ids.h reused from RTEMS.
4  *
5  * COPYRIGHT (c) 2009 Cobham Gaisler AB.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __PCI_H__
13 #define __PCI_H__
14
15 #include <pci/pcireg.h>
16 #include <pci/ids.h>
17
18 #define PCI_INVALID_VENDORDEVICEID 0xffffffff
19
20 #define PCID_CLASS(class, dev) ((class << 8) | dev)
21 #define PCID_PCI2PCI_BRIDGE PCID_CLASS(PCIC_BRIDGE, PCIS_BRIDGE_PCI)
22
23 #include <pci/access.h>
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29 /* The PCI Library have the following build time configuration options. It is
30  * up to the BSP header file (bsp.h) to set options properly.
31  *
32  * BSP_PCI_BIG_ENDIAN - Access inline routines will be for a big-endian PCI
33  * bus, if not defined the routines will assume that
34  * PCI is as the standard defines: little-endian.
35  *
36  * Note that drivers may be run-time configurable,
37  * meaning that they may adopt to either big-endian or
38  * little-endian PCI bus, the host driver or BSP may
39  * detect endianness during run-time.
40  */
41
42 /* Error return values */
43 enum {
44  PCISTS_ERR = -1, /* Undefined Error */
45  PCISTS_OK = 0,
46  PCISTS_EINVAL = 1, /* Bad input arguments */
47  PCISTS_MSTABRT = 2, /* CFG space access error (can be ignored) */
48 };
49
50 /* PCI System type can be used to determine system for drivers. Normally
51  * the system is Host, but the peripheral configuration library also supports
52  * being PCI peripheral not allowed to access configuration space.
53  *
54  * The active configuration Library set this variable.
55  */
56 enum pci_system_type {
57  PCI_SYSTEM_NONE = 0,
58  PCI_SYSTEM_HOST = 1,
59  PCI_SYSTEM_PERIPHERAL = 2,
60 };
61 extern enum pci_system_type pci_system_type;
62
63 /* PCI Bus Endianness. The PCI specification is little endian, however on some
64  * embedded systems (AT697-LEON2 for example) the PCI bus is defined as big
65  * endian (non-standard) in order to avoid byte-twisting.
66  */
67 enum {
68  PCI_LITTLE_ENDIAN = 0,
69  PCI_BIG_ENDIAN = 1,
70 };
71 extern int pci_endian;
72
73 /* Return the number of PCI busses in the system */
74 extern int pci_bus_count(void);
75
76 /* Scan the PCI bus and print the PCI device/functions/bridges and their
77  * current resources and size to the system console.
78  */
79 extern void pci_print(void);
80
81 /* Print current configuration of a single PCI device by reading PCI
82  * configuration space
83  */
84 extern void pci_print_dev(pci_dev_t dev);
85 extern void pci_print_device(int bus, int slot, int function);
86
87 /*** PCI Configuration Space direct access routines ***/
88
89 /* Function iterates over all PCI buses/devices/functions and calls
90  * func(PCIDEV,arg) for each present device. The iteration is stopped if
91  * func() returns non-zero result the same result is returned. As long
92  * as func() returns zero the function will keep on iterating, when all
93  * devices has been processed the function return zero.
94  *
95  * The function iterates over all devices/functions on all buses by accessing
96  * configuration space directly (PCI RAM data structures not used). This
97  * function is valid to call after PCI buses have been enumrated.
98  */
99 extern int pci_for_each(int (*func)(pci_dev_t, void*), void *arg);
100
101 /* Get PCI Configuration space BUS|SLOT|FUNC for a device matching PCI
102  * Vendor, Device and instance number 'index'.
103  *
104  * Return Values
105  * -1 pci_find_dev did not find a device matching the criterion.
106  * 0 device was found, *pdev was updated with the device's BUS|SLOT|FUNC
107  */
108 extern int pci_find(uint16_t ven, uint16_t dev, int index, pci_dev_t *pdev);
109
110 #ifdef __cplusplus
111 }
112 #endif
113
114 #endif /* __PCI_H__ */
