libnetworking
sys
poll.h
1
2
* Copyright (c) 1997 Peter Wemm <peter@freebsd.org>
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 3. The name of the author may not be used to endorse or promote products
14
* derived from this software without specific prior written permission.
15
16
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
17
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
20
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
21
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
22
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
23
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
24
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
25
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
26
* SUCH DAMAGE.
27
28
* $FreeBSD: src/sys/sys/poll.h,v 1.13 2002/07/10 04:47:25 mike Exp $
29
30
31
#ifndef _SYS_POLL_H_
32
#define _SYS_POLL_H_
33
34
#include <sys/cdefs.h>
35
36
37
* This file is intended to be compatible with the traditional poll.h.
38
39
40
typedef
unsigned
int
nfds_t;
41
42
43
* This structure is passed as an array to poll(2).
44
45
struct
pollfd
46
int
fd;
/* which file descriptor to poll */
47
short
events;
/* events we are interested in */
48
short
revents;
/* events found on return */
49
50
51
52
* Requestable events. If poll(2) finds any of these set, they are
53
* copied to revents on return.
54
* XXX Note that FreeBSD doesn't make much distinction between POLLPRI
55
* and POLLRDBAND since none of the file types have distinct priority
56
* bands - and only some have an urgent "mode".
57
* XXX Note POLLIN isn't really supported in true SVSV terms. Under SYSV
58
* POLLIN includes all of normal, band and urgent data. Most poll handlers
59
* on FreeBSD only treat it as "normal" data.
60
61
#define POLLIN 0x0001
/* any readable data available */
62
#define POLLPRI 0x0002
/* OOB/Urgent readable data */
63
#define POLLOUT 0x0004
/* file descriptor is writeable */
64
#define POLLRDNORM 0x0040
/* non-OOB/URG data available */
65
#define POLLWRNORM POLLOUT
/* no write type differentiation */
66
#define POLLRDBAND 0x0080
67
#define POLLWRBAND 0x0100
/* OOB/Urgent data can be written */
68
69
#if __BSD_VISIBLE
70
/* General FreeBSD extension (currently only supported for sockets): */
71
#define POLLINIGNEOF 0x2000
/* like POLLIN, except ignore EOF */
72
#endif
73
74
75
* These events are set if they occur regardless of whether they were
76
* requested.
77
78
#define POLLERR 0x0008
/* some poll error occurred */
79
#define POLLHUP 0x0010
/* file descriptor was "hung up" */
80
#define POLLNVAL 0x0020
/* requested events "invalid" */
81
82
#if __BSD_VISIBLE
83
84
#define POLLSTANDARD (POLLIN|POLLPRI|POLLOUT|POLLRDNORM|POLLRDBAND|\
85
POLLWRBAND|POLLERR|POLLHUP|POLLNVAL)
86
87
88
* Request that poll() wait forever.
89
* XXX in SYSV, this is defined in stropts.h, which is not included
90
* by poll.h.
91
92
#define INFTIM (-1)
93
94
#endif
95
96
#ifndef _KERNEL
97
98
__BEGIN_DECLS
99
int
poll(
struct
pollfd
_pfd[], nfds_t _nfds,
int
_timeout);
100
__END_DECLS
101
102
#endif
/* !_KERNEL */
103
104
#endif
/* !_SYS_POLL_H_ */
pollfd
Definition:
poll.h:46
