score
cpu
mips
mips
iregdef.h
1
11
12
* Copyright 1989 Integrated Device Technology, Inc
13
* All Rights Reserved
14
15
* Based upon IDT provided code with the following release:
16
17
* This source code has been made available to you by IDT on an AS-IS
18
* basis. Anyone receiving this source is licensed under IDT copyrights
19
* to use it in any way he or she deems fit, including copying it,
20
* modifying it, compiling it, and redistributing it either with or
21
* without modifications. No license under IDT patents or patent
22
* applications is to be implied by the copyright license.
23
24
* Any user of this software should understand that IDT cannot provide
25
* technical support for this software and will not be responsible for
26
* any consequences resulting from the use of this software.
27
28
* Any person who transfers this source code or any derivative work must
29
* include the IDT copyright notice, this paragraph, and the preceeding
30
* two paragraphs in the transferred software.
31
32
* COPYRIGHT IDT CORPORATION 1996
33
* LICENSED MATERIAL - PROGRAM PROPERTY OF IDT
34
35
36
#ifndef _RTEMS_MIPS_IREGDEF_H
37
#define _RTEMS_MIPS_IREGDEF_H
38
47
/* register names */
48
49
#define r0 $0
50
#define r1 $1
51
#define r2 $2
52
#define r3 $3
53
#define r4 $4
54
#define r5 $5
55
#define r6 $6
56
#define r7 $7
57
#define r8 $8
58
#define r9 $9
59
#define r10 $10
60
#define r11 $11
61
#define r12 $12
62
#define r13 $13
63
64
#define r14 $14
65
#define r15 $15
66
#define r16 $16
67
#define r17 $17
68
#define r18 $18
69
#define r19 $19
70
#define r20 $20
71
#define r21 $21
72
#define r22 $22
73
#define r23 $23
74
#define r24 $24
75
#define r25 $25
76
#define r26 $26
77
#define r27 $27
78
#define r28 $28
79
#define r29 $29
80
#define r30 $30
81
#define r31 $31
82
83
#define fp0 $f0
84
#define fp1 $f1
85
#define fp2 $f2
86
#define fp3 $f3
87
#define fp4 $f4
88
#define fp5 $f5
89
#define fp6 $f6
90
#define fp7 $f7
91
#define fp8 $f8
92
#define fp9 $f9
93
#define fp10 $f10
94
#define fp11 $f11
95
#define fp12 $f12
96
#define fp13 $f13
97
#define fp14 $f14
98
#define fp15 $f15
99
#define fp16 $f16
100
#define fp17 $f17
101
#define fp18 $f18
102
#define fp19 $f19
103
#define fp20 $f20
104
#define fp21 $f21
105
#define fp22 $f22
106
#define fp23 $f23
107
#define fp24 $f24
108
#define fp25 $f25
109
#define fp26 $f26
110
#define fp27 $f27
111
#define fp28 $f28
112
#define fp29 $f29
113
#define fp30 $f30
114
#define fp31 $f31
115
116
#define fcr0 $0
117
#define fcr30 $30
118
#define fcr31 $31
119
120
#define zero $0
/* wired zero */
121
#define AT $at
/* assembler temp */
122
#define v0 $2
/* return value */
123
#define v1 $3
124
#define a0 $4
/* argument registers a0-a3 */
125
#define a1 $5
126
#define a2 $6
127
#define a3 $7
128
#define t0 $8
/* caller saved t0-t9 */
129
#define t1 $9
130
#define t2 $10
131
#define t3 $11
132
#define t4 $12
133
#define t5 $13
134
#define t6 $14
135
#define t7 $15
136
#define s0 $16
/* callee saved s0-s8 */
137
#define s1 $17
138
#define s2 $18
139
#define s3 $19
140
#define s4 $20
141
#define s5 $21
142
#define s6 $22
143
#define s7 $23
144
#define t8 $24
145
#define t9 $25
146
#define k0 $26
/* kernel usage */
147
#define k1 $27
/* kernel usage */
148
#define gp $28
/* sdata pointer */
149
#define sp $29
/* stack pointer */
150
#define s8 $30
/* yet another saved reg for the callee */
151
#define fp $30
/* frame pointer - this is being phased out by MIPS */
152
#define ra $31
/* return address */
153
154
155
156
** relative position of registers in interrupt/exception frame
157
158
#define R_R0 0
159
#define R_R1 1
160
#define R_R2 2
161
#define R_R3 3
162
#define R_R4 4
163
#define R_R5 5
164
#define R_R6 6
165
#define R_R7 7
166
#define R_R8 8
167
#define R_R9 9
168
#define R_R10 10
169
#define R_R11 11
170
#define R_R12 12
171
#define R_R13 13
172
#define R_R14 14
173
#define R_R15 15
174
#define R_R16 16
175
#define R_R17 17
176
#define R_R18 18
177
#define R_R19 19
178
#define R_R20 20
179
#define R_R21 21
180
#define R_R22 22
181
#define R_R23 23
182
#define R_R24 24
183
#define R_R25 25
184
#define R_R26 26
185
#define R_R27 27
186
#define R_R28 28
187
#define R_R29 29
188
#define R_R30 30
189
#define R_R31 31
190
191
#define R_SR 32
192
#define R_MDLO 33
193
#define R_MDHI 34
194
#define R_BADVADDR 35
195
#define R_CAUSE 36
196
#define R_EPC 37
197
198
#define R_F0 38
199
#define R_F1 39
200
#define R_F2 40
201
#define R_F3 41
202
#define R_F4 42
203
#define R_F5 43
204
#define R_F6 44
205
#define R_F7 45
206
#define R_F8 46
207
#define R_F9 47
208
#define R_F10 48
209
#define R_F11 49
210
#define R_F12 50
211
#define R_F13 41
212
#define R_F14 42
213
#define R_F15 43
214
#define R_F16 44
215
#define R_F17 45
216
#define R_F18 56
217
#define R_F19 57
218
#define R_F20 58
219
#define R_F21 59
220
#define R_F22 60
221
#define R_F23 61
222
#define R_F24 62
223
#define R_F25 63
224
#define R_F26 64
225
#define R_F27 65
226
#define R_F28 66
227
#define R_F29 67
228
#define R_F30 68
229
#define R_F31 69
230
#define R_FCSR 70
231
#define R_FEIR 71
232
#define R_TLBHI 72
233
234
#if __mips == 1
235
#define R_TLBLO 73
236
#endif
237
#if (__mips == 3 ) || ( __mips == 32)
238
#define R_TLBLO0 73
239
#endif
240
241
#define R_INX 74
242
#define R_RAND 75
243
#define R_CTXT 76
244
#define R_EXCTYPE 77
245
#define R_MODE 78
246
#define R_PRID 79
247
#define R_TAR 80
248
#if __mips == 1
249
#define NREGS 81
250
#endif
251
252
#define R_TLBLO1 81
253
#define R_PAGEMASK 82
254
#define R_WIRED 83
255
#define R_COUNT 84
256
#define R_COMPARE 85
257
#define R_CONFIG 86
258
#define R_LLADDR 87
259
#define R_WATCHLO 88
260
#define R_WATCHHI 89
261
#define R_ECC 90
262
#define R_CACHEERR 91
263
#define R_TAGLO 92
264
#define R_TAGHI 93
265
#define R_ERRPC 94
266
#define R_XCTXT 95
/* Ketan added from SIM64bit */
267
268
#define NREGS 96
269
#endif
270
271
272
** For those who like to think in terms of the compiler names for the regs
273
274
#define R_ZERO R_R0
275
#define R_AT R_R1
276
#define R_V0 R_R2
277
#define R_V1 R_R3
278
#define R_A0 R_R4
279
#define R_A1 R_R5
280
#define R_A2 R_R6
281
#define R_A3 R_R7
282
#define R_T0 R_R8
283
#define R_T1 R_R9
284
#define R_T2 R_R10
285
#define R_T3 R_R11
286
#define R_T4 R_R12
287
#define R_T5 R_R13
288
#define R_T6 R_R14
289
#define R_T7 R_R15
290
#define R_S0 R_R16
291
#define R_S1 R_R17
292
#define R_S2 R_R18
293
#define R_S3 R_R19
294
#define R_S4 R_R20
295
#define R_S5 R_R21
296
#define R_S6 R_R22
297
#define R_S7 R_R23
298
#define R_T8 R_R24
299
#define R_T9 R_R25
300
#define R_K0 R_R26
301
#define R_K1 R_R27
302
#define R_GP R_R28
303
#define R_SP R_R29
304
#define R_FP R_R30
305
#define R_RA R_R31
306
307
/* disabled for RTEMS */
308
#if 0
309
/* Ketan added the following */
310
#if __mips == 1
311
#define sreg sw
312
#define lreg lw
313
#define rmfc0 mfc0
314
#define rmtc0 mtc0
315
#define R_SZ 4
316
#endif
/* __mips == 1 */
317
318
/* #ifdef __mips == 3 */
319
#if __mips < 3
320
#define sreg sw
321
#define lreg lw
322
#define rmfc0 mfc0
323
#define rmtc0 mtc0
324
#define R_SZ 4
325
#else
326
#define sreg sd
327
#define lreg ld
328
#define rmfc0 dmfc0
329
#define rmtc0 dmtc0
330
#define R_SZ 8
331
#endif
332
/* #endif __mips == 3 */
333
/* Ketan till here */
334
#endif
335
337
#endif
/* _RTEMS_MIPS_IREGDEF_H */
