ip_fw.h
1 /*
2  * Copyright (c) 1993 Daniel Boulet
3  * Copyright (c) 1994 Ugen J.S.Antsilevich
4  *
5  * Redistribution and use in source forms, with and without modification,
6  * are permitted provided that this entire comment appears intact.
7  *
8  * Redistribution in binary form may occur without any restrictions.
9  * Obviously, it would be nice if you gave credit where credit is due
10  * but requiring it would be too onerous.
11  *
12  * This software is provided ``AS IS'' without any warranties of any kind.
13  */
14
15 #ifndef _IP_FW_H
16 #define _IP_FW_H
17
18 #include <sys/queue.h> /* LIST_ENTRY */
19 #include <net/if.h>
20 #include <netinet/in.h> /* struct in_addr */
21
22 /*
23  * This union structure identifies an interface, either explicitly
24  * by name or implicitly by IP address. The flags IP_FW_F_IIFNAME
25  * and IP_FW_F_OIFNAME say how to interpret this structure. An
26  * interface unit number of -1 matches any unit number, while an
27  * IP address of 0.0.0.0 indicates matches any interface.
28  *
29  * The receive and transmit interfaces are only compared against the
30  * the packet if the corresponding bit (IP_FW_F_IIFACE or IP_FW_F_OIFACE)
31  * is set. Note some packets lack a receive or transmit interface
32  * (in which case the missing "interface" never matches).
33  */
34
35 union ip_fw_if {
36  struct in_addr fu_via_ip; /* Specified by IP address */
37  struct { /* Specified by interface name */
38 #define FW_IFNLEN IFNAMSIZ
39  char name[FW_IFNLEN];
40  short unit; /* -1 means match any unit */
41  } fu_via_if;
42 };
43
44 /*
45  * Format of an IP firewall descriptor
46  *
47  * fw_src, fw_dst, fw_smsk, fw_dmsk are always stored in network byte order.
48  * fw_flg and fw_n*p are stored in host byte order (of course).
49  * Port numbers are stored in HOST byte order.
50  * Warning: setsockopt() will fail if sizeof(struct ip_fw) > MLEN (108)
51  */
52
53 struct ip_fw {
54  u_long fw_pcnt,fw_bcnt; /* Packet and byte counters */
55  struct in_addr fw_src, fw_dst; /* Source and destination IP addr */
56  struct in_addr fw_smsk, fw_dmsk; /* Mask for src and dest IP addr */
57  u_short fw_number; /* Rule number */
58  u_short fw_flg; /* Flags word */
59 #define IP_FW_MAX_PORTS 10 /* A reasonable maximum */
60  u_short fw_pts[IP_FW_MAX_PORTS]; /* Array of port numbers to match */
61  u_char fw_ipopt,fw_ipnopt; /* IP options set/unset */
62  u_char fw_tcpf,fw_tcpnf; /* TCP flags set/unset */
63 #define IP_FW_ICMPTYPES_DIM (32 / (sizeof(unsigned) * 8))
64  unsigned fw_icmptypes[IP_FW_ICMPTYPES_DIM]; /* ICMP types bitmap */
65  long timestamp; /* timestamp (tv_sec) of last match */
66  union ip_fw_if fw_in_if, fw_out_if; /* Incoming and outgoing interfaces */
67  union {
68  u_short fu_divert_port; /* Divert/tee port (options IPDIVERT) */
69  u_short fu_skipto_rule; /* SKIPTO command rule number */
70  u_short fu_reject_code; /* REJECT response code */
71  } fw_un;
72  u_char fw_prot; /* IP protocol */
73  u_char fw_nports; /* N'of src ports and # of dst ports */
74  /* in ports array (dst ports follow */
75  /* src ports; max of 10 ports in all; */
76  /* count of 0 means match all ports) */
77 };
78
79 #define IP_FW_GETNSRCP(rule) ((rule)->fw_nports & 0x0f)
80 #define IP_FW_SETNSRCP(rule, n) do { \
81  (rule)->fw_nports &= ~0x0f; \
82  (rule)->fw_nports |= (n); \
83  } while (0)
84 #define IP_FW_GETNDSTP(rule) ((rule)->fw_nports >> 4)
85 #define IP_FW_SETNDSTP(rule, n) do { \
86  (rule)->fw_nports &= ~0xf0; \
87  (rule)->fw_nports |= (n) << 4;\
88  } while (0)
89
90 #define fw_divert_port fw_un.fu_divert_port
91 #define fw_skipto_rule fw_un.fu_skipto_rule
92 #define fw_reject_code fw_un.fu_reject_code
93
94 struct ip_fw_chain {
95  LIST_ENTRY(ip_fw_chain) chain;
96  struct ip_fw *rule;
97 };
98
99 /*
100  * Values for "flags" field .
101  */
102 #define IP_FW_F_IN 0x0001 /* Check inbound packets */
103 #define IP_FW_F_OUT 0x0002 /* Check outbound packets */
104 #define IP_FW_F_IIFACE 0x0004 /* Apply inbound interface test */
105 #define IP_FW_F_OIFACE 0x0008 /* Apply outbound interface test */
106
107 #define IP_FW_F_COMMAND 0x0070 /* Mask for type of chain entry: */
108 #define IP_FW_F_DENY 0x0000 /* This is a deny rule */
109 #define IP_FW_F_REJECT 0x0010 /* Deny and send a response packet */
110 #define IP_FW_F_ACCEPT 0x0020 /* This is an accept rule */
111 #define IP_FW_F_COUNT 0x0030 /* This is a count rule */
112 #define IP_FW_F_DIVERT 0x0040 /* This is a divert rule */
113 #define IP_FW_F_TEE 0x0050 /* This is a tee rule */
114 #define IP_FW_F_SKIPTO 0x0060 /* This is a skipto rule */
115
116 #define IP_FW_F_PRN 0x0080 /* Print if this rule matches */
117
118 #define IP_FW_F_SRNG 0x0100 /* The first two src ports are a min *
119  * and max range (stored in host byte *
120  * order). */
121
122 #define IP_FW_F_DRNG 0x0200 /* The first two dst ports are a min *
123  * and max range (stored in host byte *
124  * order). */
125
126 #define IP_FW_F_IIFNAME 0x0400 /* In interface by name/unit (not IP) */
127 #define IP_FW_F_OIFNAME 0x0800 /* Out interface by name/unit (not IP) */
128
129 #define IP_FW_F_INVSRC 0x1000 /* Invert sense of src check */
130 #define IP_FW_F_INVDST 0x2000 /* Invert sense of dst check */
131
132 #define IP_FW_F_FRAG 0x4000 /* Fragment */
133
134 #define IP_FW_F_ICMPBIT 0x8000 /* ICMP type bitmap is valid */
135
136 #define IP_FW_F_MASK 0xFFFF /* All possible flag bits mask */
137
138 /*
139  * For backwards compatibility with rules specifying "via iface" but
140  * not restricted to only "in" or "out" packets, we define this combination
141  * of bits to represent this configuration.
142  */
143
144 #define IF_FW_F_VIAHACK (IP_FW_F_IN|IP_FW_F_OUT|IP_FW_F_IIFACE|IP_FW_F_OIFACE)
145
146 /*
147  * Definitions for REJECT response codes.
148  * Values less than 256 correspond to ICMP unreachable codes.
149  */
150 #define IP_FW_REJECT_RST 0x0100 /* TCP packets: send RST */
151
152 /*
153  * Definitions for IP option names.
154  */
155 #define IP_FW_IPOPT_LSRR 0x01
156 #define IP_FW_IPOPT_SSRR 0x02
157 #define IP_FW_IPOPT_RR 0x04
158 #define IP_FW_IPOPT_TS 0x08
159
160 /*
161  * Definitions for TCP flags.
162  */
163 #define IP_FW_TCPF_FIN TH_FIN
164 #define IP_FW_TCPF_SYN TH_SYN
165 #define IP_FW_TCPF_RST TH_RST
166 #define IP_FW_TCPF_PSH TH_PUSH
167 #define IP_FW_TCPF_ACK TH_ACK
168 #define IP_FW_TCPF_URG TH_URG
169 #define IP_FW_TCPF_ESTAB 0x40
170
171 /*
172  * Main firewall chains definitions and global var's definitions.
173  */
174 #ifdef _KERNEL
175
176 /*
177  * Function definitions.
178  */
179 void ip_fw_init(void);
180
181 #endif /* _KERNEL */
182
183 #endif /* _IP_FW_H */
Definition: ip_fw.h:36
Definition: ip_fw.h:95
Definition: inet.h:93
Definition: ip_fw.h:54
Definition: rtems_bsdnet.h:233
