Definitions for ATtiny28. More...
| #define | _AVR_IOXXX_H_ "iotn28.h" |
| #define | OSCCAL _SFR_IO8(0x00) |
| #define | WDTCR _SFR_IO8(0x01) |
| #define | MODCR _SFR_IO8(0x02) |
| #define | TCNT0 _SFR_IO8(0x03) |
| #define | TCCR0 _SFR_IO8(0x04) |
| #define | IFR _SFR_IO8(0x05) |
| #define | ICR _SFR_IO8(0x06) |
| #define | MCUCS _SFR_IO8(0x07) |
| #define | ACSR _SFR_IO8(0x08) |
| #define | PIND _SFR_IO8(0x10) |
| #define | DDRD _SFR_IO8(0x11) |
| #define | PORTD _SFR_IO8(0x12) |
| #define | PINB _SFR_IO8(0x16) |
| #define | PINA _SFR_IO8(0x19) |
| #define | PACR _SFR_IO8(0x1A) |
| #define | PORTA _SFR_IO8(0x1B) |
| #define | INT0_vect _VECTOR(1) |
| #define | SIG_INTERRUPT0 _VECTOR(1) |
| #define | INT1_vect _VECTOR(2) |
| #define | SIG_INTERRUPT1 _VECTOR(2) |
| #define | LOWLEVEL_IO_PINS_vect _VECTOR(3) |
| #define | SIG_PIN _VECTOR(3) |
| #define | TIMER0_OVF_vect _VECTOR(4) |
| #define | SIG_OVERFLOW0 _VECTOR(4) |
| #define | ANA_COMP_vect _VECTOR(5) |
| #define | SIG_COMPARATOR _VECTOR(5) |
| #define | _VECTORS_SIZE 12 |
| #define | INT1 7 |
| #define | INT0 6 |
| #define | LLIE 5 |
| #define | TOIE0 4 |
| #define | ISC11 3 |
| #define | ISC10 2 |
| #define | ISC01 1 |
| #define | ISC00 |
| #define | INTF1 7 |
| #define | INTF0 6 |
| #define | TOV0 4 |
| #define | PLUPB 7 |
| #define | SE 5 |
| #define | SM 4 |
| #define | WDRF 3 |
| #define | EXTRF 1 |
| #define | PORF 0 |
| #define | FOV0 7 |
| #define | OOM01 4 |
| #define | OOM00 3 |
| #define | CS02 2 |
| #define | CS01 1 |
| #define | CS00 0 |
| #define | ONTIM4 7 |
| #define | ONTIM3 6 |
| #define | ONTIM2 5 |
| #define | ONTIM1 4 |
| #define | ONTIM0 3 |
| #define | MCONF2 2 |
| #define | MCONF1 1 |
| #define | MCONF0 0 |
| #define | WDTOE 4 |
| #define | WDE 3 |
| #define | WDP2 2 |
| #define | WDP1 1 |
| #define | WDP0 0 |
| #define | PA3 3 |
| #define | PA2 2 |
| #define | PA1 1 |
| #define | PA0 0 |
| #define | DDA3 3 |
| #define | PA2HC 2 |
| #define | DDA1 1 |
| #define | DDA0 0 |
| #define | PINA3 3 |
| #define | PINA1 1 |
| #define | PINA0 0 |
| #define | PINB7 7 |
| #define | PINB6 6 |
| #define | PINB5 5 |
| #define | PINB4 4 |
| #define | PINB3 3 |
| #define | PINB2 2 |
| #define | PINB1 1 |
| #define | PINB0 0 |
| #define | PD7 7 |
| #define | PD6 6 |
| #define | PD5 5 |
| #define | PD4 4 |
| #define | PD3 3 |
| #define | PD2 2 |
| #define | PD1 1 |
| #define | PD0 0 |
| #define | DDD7 7 |
| #define | DDD6 6 |
| #define | DDD5 5 |
| #define | DDD4 4 |
| #define | DDD3 3 |
| #define | DDD2 2 |
| #define | DDD1 1 |
| #define | DDD0 0 |
| #define | PIND7 7 |
| #define | PIND6 6 |
| #define | PIND5 5 |
| #define | PIND4 4 |
| #define | PIND3 3 |
| #define | PIND2 2 |
| #define | PIND1 1 |
| #define | PIND0 0 |
| #define | ACD 7 |
| #define | ACO 5 |
| #define | ACI 4 |
| #define | ACIE 3 |
| #define | ACIS1 1 |
| #define | ACIS0 0 |
| #define | RAMEND 0x1F |
| #define | XRAMEND 0x0 |
| #define | E2END 0x0 |
| #define | E2PAGESIZE 0 |
| #define | FLASHEND 0x7FF |
| #define | FUSE_MEMORY_SIZE 1 |
| #define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
| #define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
| #define | FUSE_CKSEL2 (unsigned char)~_BV(2) |
| #define | FUSE_CKSEL3 (unsigned char)~_BV(3) |
| #define | FUSE_INTCAP (unsigned char)~_BV(4) |
| #define | FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3) |
| #define | __LOCK_BITS_EXIST |
| #define | SIGNATURE_0 0x1E |
| #define | SIGNATURE_1 0x91 |
| #define | SIGNATURE_2 0x07 |
This file should only be included from <avr/io.h>, never directly.
