Definitions for ATtiny13. More...
| #define | _AVR_IOXXX_H_ "iotn13.h" |
| #define | ADCSRB _SFR_IO8(0x03) |
| #define | ACME 6 |
| #define | ADTS2 2 |
| #define | ADTS1 1 |
| #define | ADTS0 0 |
| #define | ADC _SFR_IO16 (0x04) |
| #define | ADCW _SFR_IO16 (0x04) |
| #define | ADCL _SFR_IO8(0x04) |
| #define | ADCH _SFR_IO8(0x05) |
| #define | ADCSRA _SFR_IO8(0x06) |
| #define | ADEN 7 |
| #define | ADSC 6 |
| #define | ADATE 5 |
| #define | ADIF 4 |
| #define | ADIE 3 |
| #define | ADPS2 2 |
| #define | ADPS1 1 |
| #define | ADPS0 0 |
| #define | ADMUX _SFR_IO8(0x07) |
| #define | REFS0 6 |
| #define | ADLAR 5 |
| #define | MUX1 1 |
| #define | MUX0 0 |
| #define | ACSR _SFR_IO8(0x08) |
| #define | ACD 7 |
| #define | ACBG 6 |
| #define | ACO 5 |
| #define | ACI 4 |
| #define | ACIE 3 |
| #define | ACIS1 1 |
| #define | ACIS0 0 |
| #define | DIDR0 _SFR_IO8(0x14) |
| #define | ADC0D 5 |
| #define | ADC2D 4 |
| #define | ADC3D 3 |
| #define | ADC1D 2 |
| #define | AIN1D 1 |
| #define | AIN0D 0 |
| #define | PCMSK _SFR_IO8(0x15) |
| #define | PCINT5 5 |
| #define | PCINT4 4 |
| #define | PCINT3 3 |
| #define | PCINT2 2 |
| #define | PCINT1 1 |
| #define | PCINT0 0 |
| #define | PINB _SFR_IO8(0x16) |
| #define | PINB5 5 |
| #define | PINB4 4 |
| #define | PINB3 3 |
| #define | PINB2 2 |
| #define | PINB1 1 |
| #define | PINB0 0 |
| #define | DDRB _SFR_IO8(0x17) |
| #define | DDB5 5 |
| #define | DDB4 4 |
| #define | DDB3 3 |
| #define | DDB2 2 |
| #define | DDB1 1 |
| #define | DDB0 0 |
| #define | PORTB _SFR_IO8(0x18) |
| #define | PB5 5 |
| #define | PB4 4 |
| #define | PB3 3 |
| #define | PB2 2 |
| #define | PB1 1 |
| #define | PB0 0 |
| #define | EECR _SFR_IO8(0x1C) |
| #define | EEPM1 5 |
| #define | EEPM0 4 |
| #define | EERIE 3 |
| #define | EEMPE 2 |
| #define | EEPE 1 |
| #define | EERE 0 |
| #define | EEDR _SFR_IO8(0x1D) |
| #define | EEAR _SFR_IO8(0x1E) |
| #define | EEARL _SFR_IO8(0x1E) |
| #define | WDTCR _SFR_IO8(0x21) |
| #define | WDTIF 7 |
| #define | WDTIE 6 |
| #define | WDP3 5 |
| #define | WDCE 4 |
| #define | WDE 3 |
| #define | WDP2 2 |
| #define | WDP1 1 |
| #define | WDP0 0 |
| #define | CLKPR _SFR_IO8(0x26) |
| #define | CLKPCE 7 |
| #define | CLKPS3 3 |
| #define | CLKPS2 2 |
| #define | CLKPS1 1 |
| #define | CLKPS0 0 |
| #define | GTCCR _SFR_IO8(0x28) |
| #define | TSM 7 |
| #define | PSR10 0 |
| #define | OCR0B _SFR_IO8(0x29) |
| #define | DWDR _SFR_IO8(0x2e) |
| #define | TCCR0A _SFR_IO8(0x2f) |
| #define | COM0A1 7 |
| #define | COM0A0 6 |
| #define | COM0B1 5 |
| #define | COM0B0 4 |
| #define | WGM01 1 |
| #define | WGM00 0 |
| #define | OSCCAL _SFR_IO8(0x31) |
| #define | TCNT0 _SFR_IO8(0x32) |
| #define | TCCR0B _SFR_IO8(0x33) |
| #define | FOC0A 7 |
| #define | FOC0B 6 |
| #define | WGM02 3 |
| #define | CS02 2 |
| #define | CS01 1 |
| #define | CS00 0 |
| #define | MCUSR _SFR_IO8(0x34) |
| #define | WDRF 3 |
| #define | BORF 2 |
| #define | EXTRF 1 |
| #define | PORF 0 |
| #define | MCUCR _SFR_IO8(0x35) |
| #define | PUD 6 |
| #define | SE 5 |
| #define | SM1 4 |
| #define | SM0 3 |
| #define | ISC01 1 |
| #define | ISC00 0 |
| #define | OCR0A _SFR_IO8(0x36) |
| #define | SPMCSR _SFR_IO8(0x37) |
| #define | CTPB 4 |
| #define | RFLB 3 |
| #define | PGWRT 2 |
| #define | PGERS 1 |
| #define | SPMEN 0 |
| #define | SELFPRGEN 0 |
| #define | TIFR0 _SFR_IO8(0x38) |
| #define | OCF0B 3 |
| #define | OCF0A 2 |
| #define | TOV0 1 |
| #define | TIMSK0 _SFR_IO8(0x39) |
| #define | OCIE0B 3 |
| #define | OCIE0A 2 |
| #define | TOIE0 1 |
| #define | GIFR _SFR_IO8(0x3a) |
| #define | INTF0 6 |
| #define | PCIF 5 |
| #define | GIMSK _SFR_IO8(0x3b) |
| #define | INT0 6 |
| #define | PCIE 5 |
| #define | INT0_vect _VECTOR(1) |
| #define | SIG_INTERRUPT0 _VECTOR(1) |
| #define | PCINT0_vect _VECTOR(2) |
| #define | SIG_PIN_CHANGE0 _VECTOR(2) |
| #define | TIM0_OVF_vect _VECTOR(3) |
| #define | SIG_OVERFLOW0 _VECTOR(3) |
| #define | EE_RDY_vect _VECTOR(4) |
| #define | SIG_EEPROM_READY _VECTOR(4) |
| #define | ANA_COMP_vect _VECTOR(5) |
| #define | SIG_COMPARATOR _VECTOR(5) |
| #define | TIM0_COMPA_vect _VECTOR(6) |
| #define | SIG_OUTPUT_COMPARE0A _VECTOR(6) |
| #define | TIM0_COMPB_vect _VECTOR(7) |
| #define | SIG_OUTPUT_COMPARE0B _VECTOR(7) |
| #define | WDT_vect _VECTOR(8) |
| #define | SIG_WATCHDOG_TIMEOUT _VECTOR(8) |
| #define | ADC_vect _VECTOR(9) |
| #define | SIG_ADC _VECTOR(9) |
| #define | _VECTORS_SIZE 20 |
| #define | SPM_PAGESIZE 32 |
| #define | RAMEND 0x9F |
| #define | XRAMEND RAMEND |
| #define | E2END 0x3F |
| #define | E2PAGESIZE 4 |
| #define | FLASHEND 0x3FF |
| #define | FUSE_MEMORY_SIZE 2 |
| #define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
| #define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
| #define | FUSE_SUT0 (unsigned char)~_BV(2) |
| #define | FUSE_SUT1 (unsigned char)~_BV(3) |
| #define | FUSE_CKDIV8 (unsigned char)~_BV(4) |
| #define | FUSE_WDTON (unsigned char)~_BV(5) |
| #define | FUSE_EESAVE (unsigned char)~_BV(6) |
| #define | FUSE_SPIEN (unsigned char)~_BV(7) |
| #define | LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_SUT0 & FUSE_CKDIV8 & FUSE_SPIEN) |
| #define | FUSE_RSTDISBL (unsigned char)~_BV(0) |
| #define | FUSE_BODLEVEL0 (unsigned char)~_BV(1) |
| #define | FUSE_BODLEVEL1 (unsigned char)~_BV(2) |
| #define | FUSE_DWEN (unsigned char)~_BV(3) |
| #define | FUSE_SPMEN (unsigned char)~_BV(4) |
| #define | HFUSE_DEFAULT (0xFF) |
| #define | __LOCK_BITS_EXIST |
| #define | SIGNATURE_0 0x1E |
| #define | SIGNATURE_1 0x90 |
| #define | SIGNATURE_2 0x07 |
Verified 5/20/04 by Bruce Graham
This file should only be included from <avr/io.h>, never directly.
