score
cpu
avr
avr
iotn12.h
1
9
10
* Copyright (c) 2002,2005 Marek Michalkiewicz
11
* All rights reserved.
12
13
14
* modification, are permitted provided that the following conditions are met:
15
16
* * Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
19
* * Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in
21
* the documentation and/or other materials provided with the
22
* distribution.
23
24
* * Neither the name of the copyright holders nor the names of
25
* contributors may be used to endorse or promote products derived
26
* from this software without specific prior written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _AVR_IOTN12_H_
42
#define _AVR_IOTN12_H_ 1
43
51
#ifndef _AVR_IO_H_
52
# error "Include <avr/io.h> instead of this file."
53
#endif
54
55
#ifndef _AVR_IOXXX_H_
56
# define _AVR_IOXXX_H_ "iotn12.h"
57
#else
58
# error "Attempt to include more than one <avr/ioXXX.h> file."
59
#endif
60
61
#ifndef __ASSEMBLER__
62
# warning "MCU not supported by the C compiler"
63
#endif
64
65
/* I/O registers */
66
67
/* 0x00..0x07 reserved */
68
69
/* Analog Comparator Control and Status Register */
70
#define ACSR _SFR_IO8(0x08)
71
72
/* 0x09..0x15 reserved */
73
74
/* Input Pins, Port B */
75
#define PINB _SFR_IO8(0x16)
76
77
/* Data Direction Register, Port B */
78
#define DDRB _SFR_IO8(0x17)
79
80
/* Data Register, Port B */
81
#define PORTB _SFR_IO8(0x18)
82
83
/* 0x19..0x1B reserved */
84
85
/* EEPROM Control Register */
86
#define EECR _SFR_IO8(0x1C)
87
88
/* EEPROM Data Register */
89
#define EEDR _SFR_IO8(0x1D)
90
91
/* EEPROM Address Register */
92
#define EEAR _SFR_IO8(0x1E)
93
#define EEARL _SFR_IO8(0x1E)
94
95
/* 0x1F..0x20 reserved */
96
97
/* Watchdog Timer Control Register */
98
#define WDTCR _SFR_IO8(0x21)
99
100
/* 0x22..0x30 reserved */
101
102
/* Oscillator Calibration Register */
103
#define OSCCAL _SFR_IO8(0x31)
104
105
/* Timer/Counter0 (8-bit) */
106
#define TCNT0 _SFR_IO8(0x32)
107
108
/* Timer/Counter0 Control Register */
109
#define TCCR0 _SFR_IO8(0x33)
110
111
/* MCU general Status Register */
112
#define MCUSR _SFR_IO8(0x34)
113
114
/* MCU general Control Register */
115
#define MCUCR _SFR_IO8(0x35)
116
117
/* 0x36..0x37 reserved */
118
119
/* Timer/Counter Interrupt Flag Register */
120
#define TIFR _SFR_IO8(0x38)
121
122
/* Timer/Counter Interrupt MaSK Register */
123
#define TIMSK _SFR_IO8(0x39)
124
125
/* General Interrupt Flag Register */
126
#define GIFR _SFR_IO8(0x3A)
127
128
/* General Interrupt MaSK register */
129
#define GIMSK _SFR_IO8(0x3B)
130
131
/* 0x3C..0x3E reserved */
132
133
/* 0x3F SREG */
134
135
/* Interrupt vectors */
136
137
/* External Interrupt 0 */
138
#define INT0_vect _VECTOR(1)
139
#define SIG_INTERRUPT0 _VECTOR(1)
140
141
/* External Interrupt Request 0 */
142
#define IO_PINS_vect _VECTOR(2)
143
#define SIG_PIN _VECTOR(2)
144
#define SIG_PIN_CHANGE _VECTOR(2)
145
146
/* Timer/Counter0 Overflow */
147
#define TIMER0_OVF_vect _VECTOR(3)
148
#define SIG_OVERFLOW0 _VECTOR(3)
149
150
/* EEPROM Ready */
151
#define EE_RDY_vect _VECTOR(4)
152
#define SIG_EEPROM_READY _VECTOR(4)
153
154
/* Analog Comparator */
155
#define ANA_COMP_vect _VECTOR(5)
156
#define SIG_COMPARATOR _VECTOR(5)
157
158
#define _VECTORS_SIZE 12
159
160
/* Bit numbers */
161
162
/* GIMSK */
163
#define INT0 6
164
#define PCIE 5
165
166
/* GIFR */
167
#define INTF0 6
168
#define PCIF 5
169
170
/* TIMSK */
171
#define TOIE0 1
172
173
/* TIFR */
174
#define TOV0 1
175
176
/* MCUCR */
177
#define PUD 6
178
#define SE 5
179
#define SM 4
180
#define ISC01 1
181
#define ISC00 0
182
183
/* TCCR0 */
184
#define CS02 2
185
#define CS01 1
186
#define CS00 0
187
188
/* WDTCR */
189
#define WDTOE 4
190
#define WDE 3
191
#define WDP2 2
192
#define WDP1 1
193
#define WDP0 0
194
195
196
PB5 = RESET#
197
PB4 = XTAL2
198
PB3 = XTAL1
199
PB2 = T0 / SCK
200
PB1 = INT0 / AIN1 / MISO
201
PB0 = AIN0 / MOSI
202
203
204
/* PORTB */
205
#define PB4 4
206
#define PB3 3
207
#define PB2 2
208
#define PB1 1
209
#define PB0 0
210
211
/* DDRB */
212
#define DDB5 5
213
#define DDB4 4
214
#define DDB3 3
215
#define DDB2 2
216
#define DDB1 1
217
#define DDB0 0
218
219
/* PINB */
220
#define PINB5 5
221
#define PINB4 4
222
#define PINB3 3
223
#define PINB2 2
224
#define PINB1 1
225
#define PINB0 0
226
227
/* ACSR */
228
#define ACD 7
229
#define AINBG 6
230
#define ACO 5
231
#define ACI 4
232
#define ACIE 3
233
#define ACIS1 1
234
#define ACIS0 0
235
236
237
#define EERIE 3
238
#define EEMWE 2
239
#define EEWE 1
240
#define EERE 0
241
242
/* Last memory addresses */
243
#define RAMEND 0x1F
244
#define XRAMEND 0x0
245
#define E2END 0x3F
246
#define E2PAGESIZE 2
247
#define FLASHEND 0x3FF
248
249
250
/* Fuses */
251
252
#define FUSE_MEMORY_SIZE 1
253
254
/* Low Fuse Byte */
255
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
256
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
257
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
258
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
259
#define FUSE_RSTDISBL (unsigned char)~_BV(4)
260
#define FUSE_SPIEN (unsigned char)~_BV(5)
261
#define FUSE_BODEN (unsigned char)~_BV(6)
262
#define FUSE_BODLEVEL (unsigned char)~_BV(7)
263
#define FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SPIEN & FUSE_BODLEVEL)
264
265
266
/* Lock Bits */
267
#define __LOCK_BITS_EXIST
268
269
270
/* Signature */
271
#define SIGNATURE_0 0x1E
272
#define SIGNATURE_1 0x90
273
#define SIGNATURE_2 0x05
274
276
#endif
/* _AVR_IOTN12_H_ */
