Definitions for ATtiny10/11. More...
| #define | _AVR_IOXXX_H_ "iotn11.h" |
| #define | ACSR _SFR_IO8(0x08) |
| #define | PINB _SFR_IO8(0x16) |
| #define | DDRB _SFR_IO8(0x17) |
| #define | PORTB _SFR_IO8(0x18) |
| #define | WDTCR _SFR_IO8(0x21) |
| #define | TCNT0 _SFR_IO8(0x32) |
| #define | TCCR0 _SFR_IO8(0x33) |
| #define | MCUSR _SFR_IO8(0x34) |
| #define | MCUCR _SFR_IO8(0x35) |
| #define | TIFR _SFR_IO8(0x38) |
| #define | TIMSK _SFR_IO8(0x39) |
| #define | GIFR _SFR_IO8(0x3A) |
| #define | GIMSK _SFR_IO8(0x3B) |
| #define | INT0_vect _VECTOR(1) |
| #define | SIG_INTERRUPT0 _VECTOR(1) |
| #define | IO_PINS_vect _VECTOR(2) |
| #define | SIG_PIN _VECTOR(2) |
| #define | SIG_PIN_CHANGE _VECTOR(2) |
| #define | TIMER0_OVF_vect _VECTOR(3) |
| #define | SIG_OVERFLOW0 _VECTOR(3) |
| #define | ANA_COMP_vect _VECTOR(4) |
| #define | SIG_COMPARATOR _VECTOR(4) |
| #define | _VECTORS_SIZE 10 |
| #define | INT0 6 |
| #define | PCIE 5 |
| #define | INTF0 6 |
| #define | PCIF 5 |
| #define | TOIE0 1 |
| #define | TOV0 1 |
| #define | SE 5 |
| #define | SM 4 |
| #define | ISC01 1 |
| #define | ISC00 0 |
| #define | CS02 2 |
| #define | CS01 1 |
| #define | CS00 0 |
| #define | WDTOE 4 |
| #define | WDE 3 |
| #define | WDP2 2 |
| #define | WDP1 1 |
| #define | WDP0 0 |
| #define | PB4 4 |
| #define | PB3 3 |
| #define | PB2 2 |
| #define | PB1 1 |
| #define | PB0 0 |
| #define | DDB4 4 |
| #define | DDB3 3 |
| #define | DDB2 2 |
| #define | DDB1 1 |
| #define | DDB0 0 |
| #define | PINB5 5 |
| #define | PINB4 4 |
| #define | PINB3 3 |
| #define | PINB2 2 |
| #define | PINB1 1 |
| #define | PINB0 0 |
| #define | ACD 7 |
| #define | ACO 5 |
| #define | ACI 4 |
| #define | ACIE 3 |
| #define | ACIS1 1 |
| #define | ACIS0 0 |
| #define | RAMEND 0x1F |
| #define | XRAMEND 0x0 |
| #define | E2END 0x0 |
| #define | E2PAGESIZE 2 |
| #define | FLASHEND 0x3FF |
| #define | FUSE_MEMORY_SIZE 1 |
| #define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
| #define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
| #define | FUSE_CKSEL2 (unsigned char)~_BV(2) |
| #define | FUSE_RSTDISBL (unsigned char)~_BV(3) |
| #define | FUSE_FSTRT (unsigned char)~_BV(4) |
| #define | FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL1) |
| #define | __LOCK_BITS_EXIST |
| #define | SIGNATURE_0 0x1E |
| #define | SIGNATURE_1 0x90 |
| #define | SIGNATURE_2 0x04 |
This file should only be included from <avr/io.h>, never directly.
