score
cpu
avr
avr
iom48.h
1
7
8
* Copyright (c) 2004, Theodore A. Roth
9
* All rights reserved.
10
11
12
* modification, are permitted provided that the following conditions are met:
13
14
* * Redistributions of source code must retain the above copyright
15
* notice, this list of conditions and the following disclaimer.
16
17
* * Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in
19
* the documentation and/or other materials provided with the
20
* distribution.
21
22
* * Neither the name of the copyright holders nor the names of
23
* contributors may be used to endorse or promote products derived
24
* from this software without specific prior written permission.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
#ifndef _AVR_IOM48_H_
40
#define _AVR_IOM48_H_ 1
41
49
avr/iomx8.h
50
51
/* Constants */
52
#define SPM_PAGESIZE 64
53
#define RAMEND 0x2FF
54
#define XRAMEND RAMEND
55
#define E2END 0xFF
56
#define E2PAGESIZE 4
57
#define FLASHEND 0xFFF
58
59
60
/* Fuses */
61
#define FUSE_MEMORY_SIZE 3
62
63
/* Low Fuse Byte */
64
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
/* Select Clock Source */
65
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
66
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
67
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
68
#define FUSE_SUT0 (unsigned char)~_BV(4)
/* Select start-up time */
69
#define FUSE_SUT1 (unsigned char)~_BV(5)
70
#define FUSE_CKOUT (unsigned char)~_BV(6)
/* Clock output */
71
#define FUSE_CKDIV8 (unsigned char)~_BV(7)
/* Divide clock by 8 */
72
#define LFUSE_DEFAULT (FUSE_CKDIV8 & FUSE_SUT0 & FUSE_CKSEL3 & FUSE_CKSEL2 & FUSE_CKSEL0)
73
74
/* High Fuse Byte */
75
#define FUSE_BODLEVEL0 (unsigned char)~_BV(0)
/* Brown-out Detector trigger level */
76
#define FUSE_BODLEVEL1 (unsigned char)~_BV(1)
77
#define FUSE_BODLEVEL2 (unsigned char)~_BV(2)
78
#define FUSE_EESAVE (unsigned char)~_BV(3)
/* EEPROM memory is preserved through chip erase */
79
#define FUSE_WDTON (unsigned char)~_BV(4)
/* Watchdog Timer Always On */
80
#define FUSE_SPIEN (unsigned char)~_BV(5)
/* Enable Serial programming and Data Downloading */
81
#define FUSE_DWEN (unsigned char)~_BV(6)
/* debugWIRE Enable */
82
#define FUSE_RSTDISBL (unsigned char)~_BV(7)
/* External reset disable */
83
#define HFUSE_DEFAULT (FUSE_SPIEN)
84
85
/* Extended Fuse Byte */
86
#define FUSE_SELFPRGEN (unsigned char)~_BV(0)
/* Self Programming Enable */
87
#define EFUSE_DEFAULT (0xFF)
88
89
90
/* Lock Bits */
91
#define __LOCK_BITS_EXIST
92
93
94
/* Signature */
95
#define SIGNATURE_0 0x1E
96
#define SIGNATURE_1 0x92
97
#define SIGNATURE_2 0x05
98
100
#endif
/* _AVR_IOM48_H_ */
iomx8.h
