iom2560.h
1 /* Copyright (c) 2005 Anatoly Sokolov
2  All rights reserved.
3
4  Redistribution and use in source and binary forms, with or without
5  modification, are permitted provided that the following conditions are met:
6
7  * Redistributions of source code must retain the above copyright
8  notice, this list of conditions and the following disclaimer.
9
10  * Redistributions in binary form must reproduce the above copyright
11  notice, this list of conditions and the following disclaimer in
12  the documentation and/or other materials provided with the
13  distribution.
14
15  * Neither the name of the copyright holders nor the names of
16  contributors may be used to endorse or promote products derived
17  from this software without specific prior written permission.
18
19  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
20  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
23  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
24  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
25  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
26  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
27  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
28  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
29  POSSIBILITY OF SUCH DAMAGE. */
30
31
32 /* avr/iom2560.h - definitions for ATmega2560 */
33
34 #ifndef _AVR_IOM2560_H_
35 #define _AVR_IOM2560_H_ 1
36
37 #include <avr/iomxx0_1.h>
38
44 #define SPM_PAGESIZE 256
45 #define RAMEND 0x21FF
46 #define XRAMEND 0xFFFF
47 #define E2END 0xFFF
48 #define E2PAGESIZE 8
49 #define FLASHEND 0x3FFFF
50
57 #define FUSE_MEMORY_SIZE 3
58
59 /* Low Fuse Byte */
60 #define FUSE_CKSEL0 (unsigned char)~_BV(0)
61 #define FUSE_CKSEL1 (unsigned char)~_BV(1)
62 #define FUSE_CKSEL2 (unsigned char)~_BV(2)
63 #define FUSE_CKSEL3 (unsigned char)~_BV(3)
64 #define FUSE_SUT0 (unsigned char)~_BV(4)
65 #define FUSE_SUT1 (unsigned char)~_BV(5)
66 #define FUSE_CKOUT (unsigned char)~_BV(6)
67 #define FUSE_CKDIV8 (unsigned char)~_BV(7)
68 #define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & \
69  FUSE_SUT0 & FUSE_CKDIV8)
70
71 /* High Fuse Byte */
72 #define FUSE_BOOTRST (unsigned char)~_BV(0)
73 #define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
74 #define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
75 #define FUSE_EESAVE (unsigned char)~_BV(3)
76 #define FUSE_WDTON (unsigned char)~_BV(4)
77 #define FUSE_SPIEN (unsigned char)~_BV(5)
78 #define FUSE_JTAGEN (unsigned char)~_BV(6)
79 #define FUSE_OCDEN (unsigned char)~_BV(7)
80 #define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
81
82 /* Extended Fuse Byte */
83 #define FUSE_BODLEVEL0 (unsigned char)~_BV(0)
84 #define FUSE_BODLEVEL1 (unsigned char)~_BV(1)
85 #define FUSE_BODLEVEL2 (unsigned char)~_BV(2)
86 #define EFUSE_DEFAULT (0xFF)
87
94 #define __LOCK_BITS_EXIST
95 #define __BOOT_LOCK_BITS_0_EXIST
96 #define __BOOT_LOCK_BITS_1_EXIST
97
104 #define SIGNATURE_0 0x1E
105 #define SIGNATURE_1 0x98
106 #define SIGNATURE_2 0x01
107
109 #endif /* _AVR_IOM2560_H_ */
Definitions for ATmega640/1280/1281/2560/2561.
