Definitions for iom168. More...
#include <avr/iomx8.h>
| #define | SPM_PAGESIZE 128 |
| #define | RAMEND 0x4FF |
| #define | XRAMEND RAMEND |
| #define | E2END 0x1FF |
| #define | E2PAGESIZE 4 |
| #define | FLASHEND 0x3FFF |
| #define | FUSE_MEMORY_SIZE 3 |
| #define | FUSE_CKSEL0 (unsigned char)~_BV(0) /* Select Clock Source */ |
| #define | FUSE_CKSEL1 (unsigned char)~_BV(1) /* Select Clock Source */ |
| #define | FUSE_CKSEL2 (unsigned char)~_BV(2) /* Select Clock Source */ |
| #define | FUSE_CKSEL3 (unsigned char)~_BV(3) /* Select Clock Source */ |
| #define | FUSE_SUT0 (unsigned char)~_BV(4) /* Select start-up time */ |
| #define | FUSE_SUT1 (unsigned char)~_BV(5) /* Select start-up time */ |
| #define | FUSE_CKOUT (unsigned char)~_BV(6) /* Clock output */ |
| #define | FUSE_CKDIV8 (unsigned char)~_BV(7) /* Divide clock by 8 */ |
| #define | LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8) |
| #define | FUSE_BODLEVEL0 (unsigned char)~_BV(0) /* Brown-out Detector trigger level */ |
| #define | FUSE_BODLEVEL1 (unsigned char)~_BV(1) /* Brown-out Detector trigger level */ |
| #define | FUSE_BODLEVEL2 (unsigned char)~_BV(2) /* Brown-out Detector trigger level */ |
| #define | FUSE_EESAVE (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */ |
| #define | FUSE_WDTON (unsigned char)~_BV(4) /* Watchdog Timer Always On */ |
| #define | FUSE_SPIEN (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */ |
| #define | FUSE_DWEN (unsigned char)~_BV(6) /* debugWIRE Enable */ |
| #define | FUSE_RSTDISBL (unsigned char)~_BV(7) /* External reset disable */ |
| #define | HFUSE_DEFAULT (FUSE_SPIEN) |
| #define | FUSE_BOOTRST (unsigned char)~_BV(0) |
| #define | FUSE_BOOTSZ0 (unsigned char)~_BV(1) |
| #define | FUSE_BOOTSZ1 (unsigned char)~_BV(2) |
| #define | EFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1) |
| #define | __LOCK_BITS_EXIST |
| #define | __BOOT_LOCK_BITS_0_EXIST |
| #define | __BOOT_LOCK_BITS_1_EXIST |
| #define | SIGNATURE_0 0x1E |
| #define | SIGNATURE_1 0x94 |
| #define | SIGNATURE_2 0x06 |
