iom162.h
1
9 /*
10  * Copyright (c) 2002, Nils Kristian Strom <nilsst@omegav.ntnu.no>
11  * All rights reserved.
12  *
13  * Redistribution and use in source and binary forms, with or without
14  * modification, are permitted provided that the following conditions are met:
15  *
16  * * Redistributions of source code must retain the above copyright
17  * notice, this list of conditions and the following disclaimer.
18  *
19  * * Redistributions in binary form must reproduce the above copyright
20  * notice, this list of conditions and the following disclaimer in
21  * the documentation and/or other materials provided with the
22  * distribution.
23  *
24  * * Neither the name of the copyright holders nor the names of
25  * contributors may be used to endorse or promote products derived
26  * from this software without specific prior written permission.
27  *
28  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38  * POSSIBILITY OF SUCH DAMAGE.
39  */
40
41 #ifndef _AVR_IOM162_H_
42 #define _AVR_IOM162_H_ 1
43
51 #ifndef _AVR_IO_H_
52 # error "Include <avr/io.h> instead of this file."
53 #endif
54
55 #ifndef _AVR_IOXXX_H_
56 # define _AVR_IOXXX_H_ "iom162.h"
57 #else
58 # error "Attempt to include more than one <avr/ioXXX.h> file."
59 #endif
60
61 /* Memory mapped I/O registers */
62
63 /* Timer/Counter3 Control Register A */
64 #define TCCR3A _SFR_MEM8(0x8B)
65
66 /* Timer/Counter3 Control Register B */
67 #define TCCR3B _SFR_MEM8(0x8A)
68
69 /* Timer/Counter3 - Counter Register */
70 #define TCNT3H _SFR_MEM8(0x89)
71 #define TCNT3L _SFR_MEM8(0x88)
72 #define TCNT3 _SFR_MEM16(0x88)
73
74 /* Timer/Counter3 - Output Compare Register A */
75 #define OCR3AH _SFR_MEM8(0x87)
76 #define OCR3AL _SFR_MEM8(0x86)
77 #define OCR3A _SFR_MEM16(0x86)
78
79 /* Timer/Counter3 - Output Compare Register B */
80 #define OCR3BH _SFR_MEM8(0x85)
81 #define OCR3BL _SFR_MEM8(0x84)
82 #define OCR3B _SFR_MEM16(0x84)
83
84 /* Timer/Counter3 - Input Capture Register */
85 #define ICR3H _SFR_MEM8(0x81)
86 #define ICR3L _SFR_MEM8(0x80)
87 #define ICR3 _SFR_MEM16(0x80)
88
89 /* Extended Timer/Counter Interrupt Mask */
90 #define ETIMSK _SFR_MEM8(0x7D)
91
92 /* Extended Timer/Counter Interrupt Flag Register */
93 #define ETIFR _SFR_MEM8(0x7C)
94
95 /* Pin Change Mask Register 1 */
96 #define PCMSK1 _SFR_MEM8(0x6C)
97
98 /* Pin Change Mask Register 0 */
99 #define PCMSK0 _SFR_MEM8(0x6B)
100
101 /* Clock PRescale */
102 #define CLKPR _SFR_MEM8(0x61)
103
104
105 /* Standard I/O registers */
106
107 /* 0x3F SREG */
108 /* 0x3D..0x3E SP */
109 #define UBRR1H _SFR_IO8(0x3C) /* USART 1 Baud Rate Register High Byte, Shared with UCSR1C */
110 #define UCSR1C _SFR_IO8(0x3C) /* USART 1 Control and Status Register, Shared with UBRR1H */
111 #define GICR _SFR_IO8(0x3B) /* General Interrupt Control Register */
112 #define GIFR _SFR_IO8(0x3A) /* General Interrupt Flag Register */
113 #define TIMSK _SFR_IO8(0x39) /* Timer Interrupt Mask */
114 #define TIFR _SFR_IO8(0x38) /* Timer Interrupt Flag Register */
115 #define SPMCR _SFR_IO8(0x37) /* Store Program Memory Control Register */
116 #define EMCUCR _SFR_IO8(0x36) /* Extended MCU Control Register */
117 #define MCUCR _SFR_IO8(0x35) /* MCU Control Register */
118 #define MCUCSR _SFR_IO8(0x34) /* MCU Control and Status Register */
119 #define TCCR0 _SFR_IO8(0x33) /* Timer/Counter 0 Control Register */
120 #define TCNT0 _SFR_IO8(0x32) /* TImer/Counter 0 */
121 #define OCR0 _SFR_IO8(0x31) /* Output Compare Register 0 */
122 #define SFIOR _SFR_IO8(0x30) /* Special Function I/O Register */
123 #define TCCR1A _SFR_IO8(0x2F) /* Timer/Counter 1 Control Register A */
124 #define TCCR1B _SFR_IO8(0x2E) /* Timer/Counter 1 Control Register A */
125 #define TCNT1H _SFR_IO8(0x2D) /* Timer/Counter 1 High Byte */
126 #define TCNT1L _SFR_IO8(0x2C) /* Timer/Counter 1 Low Byte */
127 #define TCNT1 _SFR_IO16(0x2C) /* Timer/Counter 1 */
128 #define OCR1AH _SFR_IO8(0x2B) /* Timer/Counter 1 Output Compare Register A High Byte */
129 #define OCR1AL _SFR_IO8(0x2A) /* Timer/Counter 1 Output Compare Register A Low Byte */
130 #define OCR1A _SFR_IO16(0x2A) /* Timer/Counter 1 Output Compare Register A */
131 #define OCR1BH _SFR_IO8(0x29) /* Timer/Counter 1 Output Compare Register B High Byte */
132 #define OCR1BL _SFR_IO8(0x28) /* Timer/Counter 1 Output Compare Register B Low Byte */
133 #define OCR1B _SFR_IO16(0x28) /* Timer/Counter 1 Output Compare Register B */
134 #define TCCR2 _SFR_IO8(0x27) /* Timer/Counter 2 Control Register */
135 #define ASSR _SFR_IO8(0x26) /* Asynchronous Status Register */
136 #define ICR1H _SFR_IO8(0x25) /* Input Capture Register 1 High Byte */
137 #define ICR1L _SFR_IO8(0x24) /* Input Capture Register 1 Low Byte */
138 #define ICR1 _SFR_IO16(0x24) /* Input Capture Register 1 */
139 #define TCNT2 _SFR_IO8(0x23) /* Timer/Counter 2 */
140 #define OCR2 _SFR_IO8(0x22) /* Timer/Counter 2 Output Compare Register */
141 #define WDTCR _SFR_IO8(0x21) /* Watchdow Timer Control Register */
142 #define UBRR0H _SFR_IO8(0x20) /* USART 0 Baud-Rate Register High Byte, Shared with UCSR0C */
143 #define UCSR0C _SFR_IO8(0x20) /* USART 0 Control and Status Register C, Shared with UBRR0H */
144 #define EEARH _SFR_IO8(0x1F) /* EEPROM Address Register High Byte */
145 #define EEARL _SFR_IO8(0x1E) /* EEPROM Address Register Low Byte */
146 #define EEAR _SFR_IO16(0x1E) /* EEPROM Address Register */
147 #define EEDR _SFR_IO8(0x1D) /* EEPROM Data Register */
148 #define EECR _SFR_IO8(0x1C) /* EEPROM Control Register */
149 #define PORTA _SFR_IO8(0x1B) /* Port A */
150 #define DDRA _SFR_IO8(0x1A) /* Port A Data Direction Register */
151 #define PINA _SFR_IO8(0x19) /* Port A Pin Register */
152 #define PORTB _SFR_IO8(0x18) /* Port B */
153 #define DDRB _SFR_IO8(0x17) /* Port B Data Direction Register */
154 #define PINB _SFR_IO8(0x16) /* Port B Pin Register */
155 #define PORTC _SFR_IO8(0x15) /* Port C */
156 #define DDRC _SFR_IO8(0x14) /* Port C Data Direction Register */
157 #define PINC _SFR_IO8(0x13) /* Port C Pin Register */
158 #define PORTD _SFR_IO8(0x12) /* Port D */
159 #define DDRD _SFR_IO8(0x11) /* Port D Data Direction Register */
160 #define PIND _SFR_IO8(0x10) /* Port D Pin Register */
161 #define SPDR _SFR_IO8(0x0F) /* SPI Data Register */
162 #define SPSR _SFR_IO8(0x0E) /* SPI Status Register */
163 #define SPCR _SFR_IO8(0x0D) /* SPI Control Register */
164 #define UDR0 _SFR_IO8(0x0C) /* USART 0 Data Register */
165 #define UCSR0A _SFR_IO8(0x0B) /* USART 0 Control and Status Register A */
166 #define UCSR0B _SFR_IO8(0x0A) /* USART 0 Control and Status Register B */
167 #define UBRR0L _SFR_IO8(0x09) /* USART 0 Baud-Rate Register Low Byte */
168 #define ACSR _SFR_IO8(0x08) /* Analog Comparator Status Register */
169 #define PORTE _SFR_IO8(0x07) /* Port E */
170 #define DDRE _SFR_IO8(0x06) /* Port E Data Direction Register */
171 #define PINE _SFR_IO8(0x05) /* Port E Pin Register */
172 #define OSCCAL _SFR_IO8(0x04) /* Oscillator Calibration, Shared with OCDR */
173 #define OCDR _SFR_IO8(0x04) /* On-Chip Debug Register, Shared with OSCCAL */
174 #define UDR1 _SFR_IO8(0x03) /* USART 1 Data Register */
175 #define UCSR1A _SFR_IO8(0x02) /* USART 1 Control and Status Register A */
176 #define UCSR1B _SFR_IO8(0x01) /* USART 1 Control and Status Register B */
177 #define UBRR1L _SFR_IO8(0x00) /* USART 0 Baud Rate Register High Byte */
178
179
180 /* Interrupt vectors (byte addresses) */
181
182 /* External Interrupt Request 0 */
183 #define INT0_vect _VECTOR(1)
184 #define SIG_INTERRUPT0 _VECTOR(1)
185
186 /* External Interrupt Request 1 */
187 #define INT1_vect _VECTOR(2)
188 #define SIG_INTERRUPT1 _VECTOR(2)
189
190 /* External Interrupt Request 2 */
191 #define INT2_vect _VECTOR(3)
192 #define SIG_INTERRUPT2 _VECTOR(3)
193
194 /* Pin Change Interrupt Request 0 */
195 #define PCINT0_vect _VECTOR(4)
196 #define SIG_PIN_CHANGE0 _VECTOR(4)
197
198 /* Pin Change Interrupt Request 1 */
199 #define PCINT1_vect _VECTOR(5)
200 #define SIG_PIN_CHANGE1 _VECTOR(5)
201
202 /* Timer/Counter3 Capture Event */
203 #define TIMER3_CAPT_vect _VECTOR(6)
204 #define SIG_INPUT_CAPTURE3 _VECTOR(6)
205
206 /* Timer/Counter3 Compare Match A */
207 #define TIMER3_COMPA_vect _VECTOR(7)
208 #define SIG_OUTPUT_COMPARE3A _VECTOR(7)
209
210 /* Timer/Counter3 Compare Match B */
211 #define TIMER3_COMPB_vect _VECTOR(8)
212 #define SIG_OUTPUT_COMPARE3B _VECTOR(8)
213
214 /* Timer/Counter3 Overflow */
215 #define TIMER3_OVF_vect _VECTOR(9)
216 #define SIG_OVERFLOW3 _VECTOR(9)
217
218 /* Timer/Counter2 Compare Match */
219 #define TIMER2_COMP_vect _VECTOR(10)
220 #define SIG_OUTPUT_COMPARE2 _VECTOR(10)
221
222 /* Timer/Counter2 Overflow */
223 #define TIMER2_OVF_vect _VECTOR(11)
224 #define SIG_OVERFLOW2 _VECTOR(11)
225
226 /* Timer/Counter1 Capture Event */
227 #define TIMER1_CAPT_vect _VECTOR(12)
228 #define SIG_INPUT_CAPTURE1 _VECTOR(12)
229
230 /* Timer/Counter1 Compare Match A */
231 #define TIMER1_COMPA_vect _VECTOR(13)
232 #define SIG_OUTPUT_COMPARE1A _VECTOR(13)
233
234 /* Timer/Counter Compare Match B */
235 #define TIMER1_COMPB_vect _VECTOR(14)
236 #define SIG_OUTPUT_COMPARE1B _VECTOR(14)
237
238 /* Timer/Counter1 Overflow */
239 #define TIMER1_OVF_vect _VECTOR(15)
240 #define SIG_OVERFLOW1 _VECTOR(15)
241
242 /* Timer/Counter0 Compare Match */
243 #define TIMER0_COMP_vect _VECTOR(16)
244 #define SIG_OUTPUT_COMPARE0 _VECTOR(16)
245
246 /* Timer/Counter0 Overflow */
247 #define TIMER0_OVF_vect _VECTOR(17)
248 #define SIG_OVERFLOW0 _VECTOR(17)
249
250 /* SPI Serial Transfer Complete */
251 #define SPI_STC_vect _VECTOR(18)
252 #define SIG_SPI _VECTOR(18)
253
254 /* USART0, Rx Complete */
255 #define USART0_RXC_vect _VECTOR(19)
256 #define SIG_USART0_RECV _VECTOR(19)
257
258 /* USART1, Rx Complete */
259 #define USART1_RXC_vect _VECTOR(20)
260 #define SIG_USART1_RECV _VECTOR(20)
261
262 /* USART0 Data register Empty */
263 #define USART0_UDRE_vect _VECTOR(21)
264 #define SIG_USART0_DATA _VECTOR(21)
265
266 /* USART1, Data register Empty */
267 #define USART1_UDRE_vect _VECTOR(22)
268 #define SIG_USART1_DATA _VECTOR(22)
269
270 /* USART0, Tx Complete */
271 #define USART0_TXC_vect _VECTOR(23)
272 #define SIG_USART0_TRANS _VECTOR(23)
273
274 /* USART1, Tx Complete */
275 #define USART1_TXC_vect _VECTOR(24)
276 #define SIG_USART1_TRANS _VECTOR(24)
277
278 /* EEPROM Ready */
279 #define EE_RDY_vect _VECTOR(25)
280 #define SIG_EEPROM_READY _VECTOR(25)
281
282 /* Analog Comparator */
283 #define ANA_COMP_vect _VECTOR(26)
284 #define SIG_COMPARATOR _VECTOR(26)
285
286 /* Store Program Memory Read */
287 #define SPM_RDY_vect _VECTOR(27)
288 #define SIG_SPM_READY _VECTOR(27)
289
290 #define _VECTORS_SIZE 112 /* = (num vec+1) * 4 */
291
292
293
294
295
296 /* TCCR3B bit definitions, memory mapped I/O */
297
298 #define ICNC3 7
299 #define ICES3 6
300 #define WGM33 4
301 #define WGM32 3
302 #define CS32 2
303 #define CS31 1
304 #define CS30 0
305
306
307
308 /* TCCR3A bit definitions, memory mapped I/O */
309
310 #define COM3A1 7
311 #define COM3A0 6
312 #define COM3B1 5
313 #define COM3B0 4
314 #define FOC3A 3
315 #define FOC3B 2
316 #define WGM31 1
317 #define WGM30 0
318
319
320
321 /* ETIMSK bit definitions, memory mapped I/O */
322
323 #define TICIE3 5
324 #define OCIE3A 4
325 #define OCIE3B 3
326 #define TOIE3 2
327
328
329
330 /* ETIFR bit definitions, memory mapped I/O */
331
332 #define ICF3 5
333 #define OCF3A 4
334 #define OCF3B 3
335 #define TOV3 2
336
337
338
339 /* PCMSK1 bit definitions, memory mapped I/O */
340 #define PCINT15 7
341 #define PCINT14 6
342 #define PCINT13 5
343 #define PCINT12 4
344 #define PCINT11 3
345 #define PCINT10 2
346 #define PCINT9 1
347 #define PCINT8 0
348
349
350
351 /* PCMSK0 bit definitions, memory mapped I/O */
352
353 #define PCINT7 7
354 #define PCINT6 6
355 #define PCINT5 5
356 #define PCINT4 4
357 #define PCINT3 3
358 #define PCINT2 2
359 #define PCINT1 1
360 #define PCINT0 0
361
362
363
364 /* CLKPR bit definitions, memory mapped I/O */
365
366 #define CLKPCE 7
367 #define CLKPS3 3
368 #define CLKPS2 2
369 #define CLKPS1 1
370 #define CLKPS0 0
371
372
373
374 /* SPH bit definitions */
375
376 #define SP15 15
377 #define SP14 14
378 #define SP13 13
379 #define SP12 12
380 #define SP11 11
381 #define SP10 10
382 #define SP9 9
383 #define SP8 8
384
385
386
387 /* SPL bit definitions */
388
389 #define SP7 7
390 #define SP6 6
391 #define SP5 5
392 #define SP4 4
393 #define SP3 3
394 #define SP2 2
395 #define SP1 1
396 #define SP0 0
397
398
399
400 /* UBRR1H bit definitions */
401
402 #define URSEL1 7
403 #define UBRR111 3
404 #define UBRR110 2
405 #define UBRR19 1
406 #define UBRR18 0
407
408
409
410 /* UCSR1C bit definitions */
411
412 #define URSEL1 7
413 #define UMSEL1 6
414 #define UPM11 5
415 #define UPM10 4
416 #define USBS1 3
417 #define UCSZ11 2
418 #define UCSZ10 1
419 #define UCPOL1 0
420
421
422
423 /* GICR bit definitions */
424
425 #define INT1 7
426 #define INT0 6
427 #define INT2 5
428 #define PCIE1 4
429 #define PCIE0 3
430 #define IVSEL 1
431 #define IVCE 0
432
433
434
435 /* GIFR bit definitions */
436
437 #define INTF1 7
438 #define INTF0 6
439 #define INTF2 5
440 #define PCIF1 4
441 #define PCIF0 3
442
443
444
445 /* TIMSK bit definitions */
446
447 #define TOIE1 7
448 #define OCIE1A 6
449 #define OCIE1B 5
450 #define OCIE2 4
451 #define TICIE1 3
452 #define TOIE2 2
453 #define TOIE0 1
454 #define OCIE0 0
455
456
457
458 /* TIFR bit definitions */
459
460 #define TOV1 7
461 #define OCF1A 6
462 #define OCF1B 5
463 #define OCF2 4
464 #define ICF1 3
465 #define TOV2 2
466 #define TOV0 1
467 #define OCF0 0
468
469
470
471 /* SPMCR bit definitions */
472
473 #define SPMIE 7
474 #define RWWSB 6
475 #define RWWSRE 4
476 #define BLBSET 3
477 #define PGWRT 2
478 #define PGERS 1
479 #define SPMEN 0
480
481
482
483 /* EMCUCR bit definitions */
484
485 #define SM0 7
486 #define SRL2 6
487 #define SRL1 5
488 #define SRL0 4
489 #define SRW01 3
490 #define SRW00 2
491 #define SRW11 1
492 #define ISC2 0
493
494
495
496 /* MCUCR bit definitions */
497
498 #define SRE 7
499 #define SRW10 6
500 #define SE 5
501 #define SM1 4
502 #define ISC11 3
503 #define ISC10 2
504 #define ISC01 1
505 #define ISC00 0
506
507
508
509 /* MCUCSR bit definitions */
510
511 #define JTD 7
512 #define SM2 5
513 #define JTRF 4
514 #define WDRF 3
515 #define BORF 2
516 #define EXTRF 1
517 #define PORF 0
518
519
520
521 /* TCCR0 bit definitions */
522
523 #define FOC0 7
524 #define WGM00 6
525 #define COM01 5
526 #define COM00 4
527 #define WGM01 3
528 #define CS02 2
529 #define CS01 1
530 #define CS00 0
531
532
533
534 /* SFIOR bit definitions */
535
536 #define TSM 7
537 #define XMBK 6
538 #define XMM2 5
539 #define XMM1 4
540 #define XMM0 3
541 #define PUD 2
542 #define PSR2 1
543 #define PSR310 0
544
545
546
547 /* TCCR1A bit definitions */
548
549 #define COM1A1 7
550 #define COM1A0 6
551 #define COM1B1 5
552 #define COM1B0 4
553 #define FOC1A 3
554 #define FOC1B 2
555 #define WGM11 1
556 #define WGM10 0
557
558
559
560
561 /* TCCR1B bit definitions */
562
563 #define ICNC1 7 /* Input Capture Noise Canceler */
564 #define ICES1 6 /* Input Capture Edge Select */
565 #define WGM13 4 /* Waveform Generation Mode 3 */
566 #define WGM12 3 /* Waveform Generation Mode 2 */
567 #define CS12 2 /* Clock Select 2 */
568 #define CS11 1 /* Clock Select 1 */
569 #define CS10 0 /* Clock Select 0 */
570
571
572
573 /* TCCR2 bit definitions */
574
575 #define FOC2 7
576 #define WGM20 6
577 #define COM21 5
578 #define COM20 4
579 #define WGM21 3
580 #define CS22 2
581 #define CS21 1
582 #define CS20 0
583
584
585
586 /* ASSR bit definitions */
587
588 #define AS2 3
589 #define TCN2UB 2
590 #define TCON2UB 2 /* Kept for backwards compatibility. */
591 #define OCR2UB 1
592 #define TCR2UB 0
593
594
595
596 /* WDTCR bit definitions */
597
598 #define WDCE 4
599 #define WDE 3
600 #define WDP2 2
601 #define WDP1 1
602 #define WDP0 0
603
604
605
606 /* UBRR0H bif definitions */
607
608 #define URSEL0 7
609 #define UBRR011 3
610 #define UBRR010 2
611 #define UBRR09 1
612 #define UBRR08 0
613
614
615
616 /* UCSR0C bit definitions */
617
618 #define URSEL0 7
619 #define UMSEL0 6
620 #define UPM01 5
621 #define UPM00 4
622 #define USBS0 3
623 #define UCSZ01 2
624 #define UCSZ00 1
625 #define UCPOL0 0
626
627
628
629 /* EEARH bit definitions */
630
631 #define EEAR8 0
632
633
634
635 /* EECR bit definitions */
636
637 #define EERIE 3
638 #define EEMWE 2
639 #define EEWE 1
640 #define EERE 0
641
642
643
644 /* PORTA bit definitions */
645
646 #define PA7 7
647 #define PA6 6
648 #define PA5 5
649 #define PA4 4
650 #define PA3 3
651 #define PA2 2
652 #define PA1 1
653 #define PA0 0
654
655
656
657 /* DDRA bit definitions */
658
659 #define DDA7 7
660 #define DDA6 6
661 #define DDA5 5
662 #define DDA4 4
663 #define DDA3 3
664 #define DDA2 2
665 #define DDA1 1
666 #define DDA0 0
667
668
669
670 /* PINA bit definitions */
671
672 #define PINA7 7
673 #define PINA6 6
674 #define PINA5 5
675 #define PINA4 4
676 #define PINA3 3
677 #define PINA2 2
678 #define PINA1 1
679 #define PINA0 0
680
681
682 /* PORTB bit definitions */
683
684 #define PB7 7
685 #define PB6 6
686 #define PB5 5
687 #define PB4 4
688 #define PB3 3
689 #define PB2 2
690 #define PB1 1
691 #define PB0 0
692
693
694
695 /* DDRB bit definitions */
696
697 #define DDB7 7
698 #define DDB6 6
699 #define DDB5 5
700 #define DDB4 4
701 #define DDB3 3
702 #define DDB2 2
703 #define DDB1 1
704 #define DDB0 0
705
706
707
708 /* PINB bit definitions */
709
710 #define PINB7 7
711 #define PINB6 6
712 #define PINB5 5
713 #define PINB4 4
714 #define PINB3 3
715 #define PINB2 2
716 #define PINB1 1
717 #define PINB0 0
718
719
720
721 /* PORTC bit definitions */
722
723 #define PC7 7
724 #define PC6 6
725 #define PC5 5
726 #define PC4 4
727 #define PC3 3
728 #define PC2 2
729 #define PC1 1
730 #define PC0 0
731
732
733
734 /* DDRC bit definitions */
735
736 #define DDC7 7
737 #define DDC6 6
738 #define DDC5 5
739 #define DDC4 4
740 #define DDC3 3
741 #define DDC2 2
742 #define DDC1 1
743 #define DDC0 0
744
745
746
747 /* PINC bit definitions */
748
749 #define PINC7 7
750 #define PINC6 6
751 #define PINC5 5
752 #define PINC4 4
753 #define PINC3 3
754 #define PINC2 2
755 #define PINC1 1
756 #define PINC0 0
757
758
759
760 /* PORTD bit definitions */
761
762 #define PD7 7
763 #define PD6 6
764 #define PD5 5
765 #define PD4 4
766 #define PD3 3
767 #define PD2 2
768 #define PD1 1
769 #define PD0 0
770
771
772
773 /* DDRD bit definitions */
774
775 #define DDD7 7
776 #define DDD6 6
777 #define DDD5 5
778 #define DDD4 4
779 #define DDD3 3
780 #define DDD2 2
781 #define DDD1 1
782 #define DDD0 0
783
784
785
786 /* PIND bit definitions */
787
788 #define PIND7 7
789 #define PIND6 6
790 #define PIND5 5
791 #define PIND4 4
792 #define PIND3 3
793 #define PIND2 2
794 #define PIND1 1
795 #define PIND0 0
796
797
798
799 /* SPSR bit definitions */
800
801 #define SPIF 7
802 #define WCOL 6
803 #define SPI2X 0
804
805
806
807 /* SPCR bit definitions */
808
809 #define SPIE 7
810 #define SPE 6
811 #define DORD 5
812 #define MSTR 4
813 #define CPOL 3
814 #define CPHA 2
815 #define SPR1 1
816 #define SPR0 0
817
818
819
820 /* UCSR0A bit definitions */
821
822 #define RXC0 7
823 #define TXC0 6
824 #define UDRE0 5
825 #define FE0 4
826 #define DOR0 3
827 #define UPE0 2
828 #define U2X0 1
829 #define MPCM0 0
830
831
832
833 /* UCSR0B bit definitions */
834
835 #define RXCIE0 7
836 #define TXCIE0 6
837 #define UDRIE0 5
838 #define RXEN0 4
839 #define TXEN0 3
840 #define UCSZ02 2
841 #define RXB80 1
842 #define TXB80 0
843
844
845
846 /* ACSR bit definitions */
847
848 #define ACD 7
849 #define ACBG 6
850 #define ACO 5
851 #define ACI 4
852 #define ACIE 3
853 #define ACIC 2
854 #define ACIS1 1
855 #define ACIS0 0
856
857
858
859 /* PORTE bit definitions */
860
861 #define PE2 2
862 #define PE1 1
863 #define PE0 0
864
865
866
867 /* DDRE bit definitions */
868
869 #define DDE2 2
870 #define DDE1 1
871 #define DDE0 0
872
873
874
875 /* PINE bit definitions */
876
877 #define PINE2 2
878 #define PINE1 1
879 #define PINE0 0
880
881
882
883 /* UCSR1A bit definitions */
884
885 #define RXC1 7
886 #define TXC1 6
887 #define UDRE1 5
888 #define FE1 4
889 #define DOR1 3
890 #define UPE1 2
891 #define U2X1 1
892 #define MPCM1 0
893
894
895
896 /* UCSR1B bit definitions */
897
898 #define RXCIE1 7
899 #define TXCIE1 6
900 #define UDRIE1 5
901 #define RXEN1 4
902 #define TXEN1 3
903 #define UCSZ12 2
904 #define RXB81 1
905 #define TXB81 0
906
907
908 /* Constants */
909 #define SPM_PAGESIZE 128
910 #define RAMEND 0x4FF
911 #define XRAMEND 0xFFFF
912 #define E2END 0x1FF
913 #define E2PAGESIZE 4
914 #define FLASHEND 0x3FFF
915
916
917 /* Fuses */
918
919 #define FUSE_MEMORY_SIZE 3
920
921 /* Low Fuse Byte */
922 #define FUSE_CKSEL0 (unsigned char)~_BV(0)
923 #define FUSE_CKSEL1 (unsigned char)~_BV(1)
924 #define FUSE_CKSEL2 (unsigned char)~_BV(2)
925 #define FUSE_CKSEL3 (unsigned char)~_BV(3)
926 #define FUSE_SUT0 (unsigned char)~_BV(4)
927 #define FUSE_SUT1 (unsigned char)~_BV(5)
928 #define FUSE_CKOUT (unsigned char)~_BV(6)
929 #define FUSE_CKDIV8 (unsigned char)~_BV(7)
930 #define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
931
932 /* High Fuse Byte */
933 #define FUSE_BOOTRST (unsigned char)~_BV(0)
934 #define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
935 #define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
936 #define FUSE_EESAVE (unsigned char)~_BV(3)
937 #define FUSE_WDTON (unsigned char)~_BV(4)
938 #define FUSE_SPIEN (unsigned char)~_BV(5)
939 #define FUSE_JTAGEN (unsigned char)~_BV(6)
940 #define FUSE_OCDEN (unsigned char)~_BV(7)
941 #define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
942
943 /* Extended Fuse Byte */
944 #define FUSE_BODLEVEL0 (unsigned char)~_BV(1)
945 #define FUSE_BODLEVEL1 (unsigned char)~_BV(2)
946 #define FUSE_BODLEVEL2 (unsigned char)~_BV(3)
947 #define FUSE_M161C (unsigned char)~_BV(4)
948 #define EFUSE_DEFAULT (0xFF)
949
950
951 /* Lock Bits */
952 #define __LOCK_BITS_EXIST
953 #define __BOOT_LOCK_BITS_0_EXIST
954 #define __BOOT_LOCK_BITS_1_EXIST
955
956
957 /* Signature */
958 #define SIGNATURE_0 0x1E
959 #define SIGNATURE_1 0x94
960 #define SIGNATURE_2 0x04
961
962
964 #endif /* _AVR_IOM162_H_ */
