score
cpu
avr
avr
iom128.h
1
12
13
* Copyright (c) 2002, Peter Jansen
14
* Copyright (c) 2007, Atmel Corporation
15
* All rights reserved.
16
17
18
* modification, are permitted provided that the following conditions are met:
19
20
* * Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
23
* * Redistributions in binary form must reproduce the above copyright
24
* notice, this list of conditions and the following disclaimer in
25
* the documentation and/or other materials provided with the
26
* distribution.
27
28
* * Neither the name of the copyright holders nor the names of
29
* contributors may be used to endorse or promote products derived
30
* from this software without specific prior written permission.
31
32
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42
* POSSIBILITY OF SUCH DAMAGE.
43
44
45
#ifndef _AVR_IOM128_H_
46
#define _AVR_IOM128_H_ 1
47
55
#ifndef _AVR_IO_H_
56
# error "Include <avr/io.h> instead of this file."
57
#endif
58
59
#ifndef _AVR_IOXXX_H_
60
# define _AVR_IOXXX_H_ "iom128.h"
61
#else
62
# error "Attempt to include more than one <avr/ioXXX.h> file."
63
#endif
64
65
/* I/O registers */
66
67
/* Input Pins, Port F */
68
#define PINF _SFR_IO8(0x00)
69
70
/* Input Pins, Port E */
71
#define PINE _SFR_IO8(0x01)
72
73
/* Data Direction Register, Port E */
74
#define DDRE _SFR_IO8(0x02)
75
76
/* Data Register, Port E */
77
#define PORTE _SFR_IO8(0x03)
78
79
/* ADC Data Register */
80
#define ADCW _SFR_IO16(0x04)
/* for backwards compatibility */
81
#ifndef __ASSEMBLER__
82
#define ADC _SFR_IO16(0x04)
83
#endif
84
#define ADCL _SFR_IO8(0x04)
85
#define ADCH _SFR_IO8(0x05)
86
87
/* ADC Control and status register */
88
#define ADCSR _SFR_IO8(0x06)
89
#define ADCSRA _SFR_IO8(0x06)
/* new name in datasheet (2467E-AVR-05/02) */
90
91
/* ADC Multiplexer select */
92
#define ADMUX _SFR_IO8(0x07)
93
94
/* Analog Comparator Control and Status Register */
95
#define ACSR _SFR_IO8(0x08)
96
97
/* USART0 Baud Rate Register Low */
98
#define UBRR0L _SFR_IO8(0x09)
99
100
/* USART0 Control and Status Register B */
101
#define UCSR0B _SFR_IO8(0x0A)
102
103
/* USART0 Control and Status Register A */
104
#define UCSR0A _SFR_IO8(0x0B)
105
106
/* USART0 I/O Data Register */
107
#define UDR0 _SFR_IO8(0x0C)
108
109
/* SPI Control Register */
110
#define SPCR _SFR_IO8(0x0D)
111
112
/* SPI Status Register */
113
#define SPSR _SFR_IO8(0x0E)
114
115
/* SPI I/O Data Register */
116
#define SPDR _SFR_IO8(0x0F)
117
118
/* Input Pins, Port D */
119
#define PIND _SFR_IO8(0x10)
120
121
/* Data Direction Register, Port D */
122
#define DDRD _SFR_IO8(0x11)
123
124
/* Data Register, Port D */
125
#define PORTD _SFR_IO8(0x12)
126
127
/* Input Pins, Port C */
128
#define PINC _SFR_IO8(0x13)
129
130
/* Data Direction Register, Port C */
131
#define DDRC _SFR_IO8(0x14)
132
133
/* Data Register, Port C */
134
#define PORTC _SFR_IO8(0x15)
135
136
/* Input Pins, Port B */
137
#define PINB _SFR_IO8(0x16)
138
139
/* Data Direction Register, Port B */
140
#define DDRB _SFR_IO8(0x17)
141
142
/* Data Register, Port B */
143
#define PORTB _SFR_IO8(0x18)
144
145
/* Input Pins, Port A */
146
#define PINA _SFR_IO8(0x19)
147
148
/* Data Direction Register, Port A */
149
#define DDRA _SFR_IO8(0x1A)
150
151
/* Data Register, Port A */
152
#define PORTA _SFR_IO8(0x1B)
153
154
/* EEPROM Control Register */
155
#define EECR _SFR_IO8(0x1C)
156
157
/* EEPROM Data Register */
158
#define EEDR _SFR_IO8(0x1D)
159
160
/* EEPROM Address Register */
161
#define EEAR _SFR_IO16(0x1E)
162
#define EEARL _SFR_IO8(0x1E)
163
#define EEARH _SFR_IO8(0x1F)
164
165
/* Special Function I/O Register */
166
#define SFIOR _SFR_IO8(0x20)
167
168
/* Watchdog Timer Control Register */
169
#define WDTCR _SFR_IO8(0x21)
170
171
/* On-chip Debug Register */
172
#define OCDR _SFR_IO8(0x22)
173
174
/* Timer2 Output Compare Register */
175
#define OCR2 _SFR_IO8(0x23)
176
177
/* Timer/Counter 2 */
178
#define TCNT2 _SFR_IO8(0x24)
179
180
/* Timer/Counter 2 Control register */
181
#define TCCR2 _SFR_IO8(0x25)
182
183
/* T/C 1 Input Capture Register */
184
#define ICR1 _SFR_IO16(0x26)
185
#define ICR1L _SFR_IO8(0x26)
186
#define ICR1H _SFR_IO8(0x27)
187
188
/* Timer/Counter1 Output Compare Register B */
189
#define OCR1B _SFR_IO16(0x28)
190
#define OCR1BL _SFR_IO8(0x28)
191
#define OCR1BH _SFR_IO8(0x29)
192
193
/* Timer/Counter1 Output Compare Register A */
194
#define OCR1A _SFR_IO16(0x2A)
195
#define OCR1AL _SFR_IO8(0x2A)
196
#define OCR1AH _SFR_IO8(0x2B)
197
198
/* Timer/Counter 1 */
199
#define TCNT1 _SFR_IO16(0x2C)
200
#define TCNT1L _SFR_IO8(0x2C)
201
#define TCNT1H _SFR_IO8(0x2D)
202
203
/* Timer/Counter 1 Control and Status Register */
204
#define TCCR1B _SFR_IO8(0x2E)
205
206
/* Timer/Counter 1 Control Register */
207
#define TCCR1A _SFR_IO8(0x2F)
208
209
/* Timer/Counter 0 Asynchronous Control & Status Register */
210
#define ASSR _SFR_IO8(0x30)
211
212
/* Output Compare Register 0 */
213
#define OCR0 _SFR_IO8(0x31)
214
215
/* Timer/Counter 0 */
216
#define TCNT0 _SFR_IO8(0x32)
217
218
/* Timer/Counter 0 Control Register */
219
#define TCCR0 _SFR_IO8(0x33)
220
221
/* MCU Status Register */
222
#define MCUSR _SFR_IO8(0x34)
223
#define MCUCSR _SFR_IO8(0x34)
224
225
/* MCU general Control Register */
226
#define MCUCR _SFR_IO8(0x35)
227
228
/* Timer/Counter Interrupt Flag Register */
229
#define TIFR _SFR_IO8(0x36)
230
231
/* Timer/Counter Interrupt MaSK register */
232
#define TIMSK _SFR_IO8(0x37)
233
234
/* External Interrupt Flag Register */
235
#define EIFR _SFR_IO8(0x38)
236
237
/* External Interrupt MaSK register */
238
#define EIMSK _SFR_IO8(0x39)
239
240
/* External Interrupt Control Register B */
241
#define EICRB _SFR_IO8(0x3A)
242
243
/* RAM Page Z select register */
244
#define RAMPZ _SFR_IO8(0x3B)
245
246
/* XDIV Divide control register */
247
#define XDIV _SFR_IO8(0x3C)
248
249
/* 0x3D..0x3E SP */
250
251
/* 0x3F SREG */
252
253
/* Extended I/O registers */
254
255
/* Data Direction Register, Port F */
256
#define DDRF _SFR_MEM8(0x61)
257
258
/* Data Register, Port F */
259
#define PORTF _SFR_MEM8(0x62)
260
261
/* Input Pins, Port G */
262
#define PING _SFR_MEM8(0x63)
263
264
/* Data Direction Register, Port G */
265
#define DDRG _SFR_MEM8(0x64)
266
267
/* Data Register, Port G */
268
#define PORTG _SFR_MEM8(0x65)
269
270
/* Store Program Memory Control and Status Register */
271
#define SPMCR _SFR_MEM8(0x68)
272
#define SPMCSR _SFR_MEM8(0x68)
273
274
/* External Interrupt Control Register A */
275
#define EICRA _SFR_MEM8(0x6A)
276
277
/* External Memory Control Register B */
278
#define XMCRB _SFR_MEM8(0x6C)
279
280
/* External Memory Control Register A */
281
#define XMCRA _SFR_MEM8(0x6D)
282
283
/* Oscillator Calibration Register */
284
#define OSCCAL _SFR_MEM8(0x6F)
285
286
/* 2-wire Serial Interface Bit Rate Register */
287
#define TWBR _SFR_MEM8(0x70)
288
289
/* 2-wire Serial Interface Status Register */
290
#define TWSR _SFR_MEM8(0x71)
291
292
/* 2-wire Serial Interface Address Register */
293
#define TWAR _SFR_MEM8(0x72)
294
295
/* 2-wire Serial Interface Data Register */
296
#define TWDR _SFR_MEM8(0x73)
297
298
/* 2-wire Serial Interface Control Register */
299
#define TWCR _SFR_MEM8(0x74)
300
301
/* Time Counter 1 Output Compare Register C */
302
#define OCR1C _SFR_MEM16(0x78)
303
#define OCR1CL _SFR_MEM8(0x78)
304
#define OCR1CH _SFR_MEM8(0x79)
305
306
/* Timer/Counter 1 Control Register C */
307
#define TCCR1C _SFR_MEM8(0x7A)
308
309
/* Extended Timer Interrupt Flag Register */
310
#define ETIFR _SFR_MEM8(0x7C)
311
312
/* Extended Timer Interrupt Mask Register */
313
#define ETIMSK _SFR_MEM8(0x7D)
314
315
/* Timer/Counter 3 Input Capture Register */
316
#define ICR3 _SFR_MEM16(0x80)
317
#define ICR3L _SFR_MEM8(0x80)
318
#define ICR3H _SFR_MEM8(0x81)
319
320
/* Timer/Counter 3 Output Compare Register C */
321
#define OCR3C _SFR_MEM16(0x82)
322
#define OCR3CL _SFR_MEM8(0x82)
323
#define OCR3CH _SFR_MEM8(0x83)
324
325
/* Timer/Counter 3 Output Compare Register B */
326
#define OCR3B _SFR_MEM16(0x84)
327
#define OCR3BL _SFR_MEM8(0x84)
328
#define OCR3BH _SFR_MEM8(0x85)
329
330
/* Timer/Counter 3 Output Compare Register A */
331
#define OCR3A _SFR_MEM16(0x86)
332
#define OCR3AL _SFR_MEM8(0x86)
333
#define OCR3AH _SFR_MEM8(0x87)
334
335
/* Timer/Counter 3 Counter Register */
336
#define TCNT3 _SFR_MEM16(0x88)
337
#define TCNT3L _SFR_MEM8(0x88)
338
#define TCNT3H _SFR_MEM8(0x89)
339
340
/* Timer/Counter 3 Control Register B */
341
#define TCCR3B _SFR_MEM8(0x8A)
342
343
/* Timer/Counter 3 Control Register A */
344
#define TCCR3A _SFR_MEM8(0x8B)
345
346
/* Timer/Counter 3 Control Register C */
347
#define TCCR3C _SFR_MEM8(0x8C)
348
349
/* USART0 Baud Rate Register High */
350
#define UBRR0H _SFR_MEM8(0x90)
351
352
/* USART0 Control and Status Register C */
353
#define UCSR0C _SFR_MEM8(0x95)
354
355
/* USART1 Baud Rate Register High */
356
#define UBRR1H _SFR_MEM8(0x98)
357
358
/* USART1 Baud Rate Register Low*/
359
#define UBRR1L _SFR_MEM8(0x99)
360
361
/* USART1 Control and Status Register B */
362
#define UCSR1B _SFR_MEM8(0x9A)
363
364
/* USART1 Control and Status Register A */
365
#define UCSR1A _SFR_MEM8(0x9B)
366
367
/* USART1 I/O Data Register */
368
#define UDR1 _SFR_MEM8(0x9C)
369
370
/* USART1 Control and Status Register C */
371
#define UCSR1C _SFR_MEM8(0x9D)
372
373
/* Interrupt vectors */
374
375
/* External Interrupt Request 0 */
376
#define INT0_vect _VECTOR(1)
377
#define SIG_INTERRUPT0 _VECTOR(1)
378
379
/* External Interrupt Request 1 */
380
#define INT1_vect _VECTOR(2)
381
#define SIG_INTERRUPT1 _VECTOR(2)
382
383
/* External Interrupt Request 2 */
384
#define INT2_vect _VECTOR(3)
385
#define SIG_INTERRUPT2 _VECTOR(3)
386
387
/* External Interrupt Request 3 */
388
#define INT3_vect _VECTOR(4)
389
#define SIG_INTERRUPT3 _VECTOR(4)
390
391
/* External Interrupt Request 4 */
392
#define INT4_vect _VECTOR(5)
393
#define SIG_INTERRUPT4 _VECTOR(5)
394
395
/* External Interrupt Request 5 */
396
#define INT5_vect _VECTOR(6)
397
#define SIG_INTERRUPT5 _VECTOR(6)
398
399
/* External Interrupt Request 6 */
400
#define INT6_vect _VECTOR(7)
401
#define SIG_INTERRUPT6 _VECTOR(7)
402
403
/* External Interrupt Request 7 */
404
#define INT7_vect _VECTOR(8)
405
#define SIG_INTERRUPT7 _VECTOR(8)
406
407
/* Timer/Counter2 Compare Match */
408
#define TIMER2_COMP_vect _VECTOR(9)
409
#define SIG_OUTPUT_COMPARE2 _VECTOR(9)
410
411
/* Timer/Counter2 Overflow */
412
#define TIMER2_OVF_vect _VECTOR(10)
413
#define SIG_OVERFLOW2 _VECTOR(10)
414
415
/* Timer/Counter1 Capture Event */
416
#define TIMER1_CAPT_vect _VECTOR(11)
417
#define SIG_INPUT_CAPTURE1 _VECTOR(11)
418
419
/* Timer/Counter1 Compare Match A */
420
#define TIMER1_COMPA_vect _VECTOR(12)
421
#define SIG_OUTPUT_COMPARE1A _VECTOR(12)
422
423
/* Timer/Counter Compare Match B */
424
#define TIMER1_COMPB_vect _VECTOR(13)
425
#define SIG_OUTPUT_COMPARE1B _VECTOR(13)
426
427
/* Timer/Counter1 Overflow */
428
#define TIMER1_OVF_vect _VECTOR(14)
429
#define SIG_OVERFLOW1 _VECTOR(14)
430
431
/* Timer/Counter0 Compare Match */
432
#define TIMER0_COMP_vect _VECTOR(15)
433
#define SIG_OUTPUT_COMPARE0 _VECTOR(15)
434
435
/* Timer/Counter0 Overflow */
436
#define TIMER0_OVF_vect _VECTOR(16)
437
#define SIG_OVERFLOW0 _VECTOR(16)
438
439
/* SPI Serial Transfer Complete */
440
#define SPI_STC_vect _VECTOR(17)
441
#define SIG_SPI _VECTOR(17)
442
443
/* USART0, Rx Complete */
444
#define USART0_RX_vect _VECTOR(18)
445
#define SIG_USART0_RECV _VECTOR(18)
446
#define SIG_UART0_RECV _VECTOR(18)
447
448
/* USART0 Data Register Empty */
449
#define USART0_UDRE_vect _VECTOR(19)
450
#define SIG_USART0_DATA _VECTOR(19)
451
#define SIG_UART0_DATA _VECTOR(19)
452
453
/* USART0, Tx Complete */
454
#define USART0_TX_vect _VECTOR(20)
455
#define SIG_USART0_TRANS _VECTOR(20)
456
#define SIG_UART0_TRANS _VECTOR(20)
457
458
/* ADC Conversion Complete */
459
#define ADC_vect _VECTOR(21)
460
#define SIG_ADC _VECTOR(21)
461
462
/* EEPROM Ready */
463
#define EE_READY_vect _VECTOR(22)
464
#define SIG_EEPROM_READY _VECTOR(22)
465
466
/* Analog Comparator */
467
#define ANALOG_COMP_vect _VECTOR(23)
468
#define SIG_COMPARATOR _VECTOR(23)
469
470
/* Timer/Counter1 Compare Match C */
471
#define TIMER1_COMPC_vect _VECTOR(24)
472
#define SIG_OUTPUT_COMPARE1C _VECTOR(24)
473
474
/* Timer/Counter3 Capture Event */
475
#define TIMER3_CAPT_vect _VECTOR(25)
476
#define SIG_INPUT_CAPTURE3 _VECTOR(25)
477
478
/* Timer/Counter3 Compare Match A */
479
#define TIMER3_COMPA_vect _VECTOR(26)
480
#define SIG_OUTPUT_COMPARE3A _VECTOR(26)
481
482
/* Timer/Counter3 Compare Match B */
483
#define TIMER3_COMPB_vect _VECTOR(27)
484
#define SIG_OUTPUT_COMPARE3B _VECTOR(27)
485
486
/* Timer/Counter3 Compare Match C */
487
#define TIMER3_COMPC_vect _VECTOR(28)
488
#define SIG_OUTPUT_COMPARE3C _VECTOR(28)
489
490
/* Timer/Counter3 Overflow */
491
#define TIMER3_OVF_vect _VECTOR(29)
492
#define SIG_OVERFLOW3 _VECTOR(29)
493
494
/* USART1, Rx Complete */
495
#define USART1_RX_vect _VECTOR(30)
496
#define SIG_USART1_RECV _VECTOR(30)
497
#define SIG_UART1_RECV _VECTOR(30)
498
499
/* USART1, Data Register Empty */
500
#define USART1_UDRE_vect _VECTOR(31)
501
#define SIG_USART1_DATA _VECTOR(31)
502
#define SIG_UART1_DATA _VECTOR(31)
503
504
/* USART1, Tx Complete */
505
#define USART1_TX_vect _VECTOR(32)
506
#define SIG_USART1_TRANS _VECTOR(32)
507
#define SIG_UART1_TRANS _VECTOR(32)
508
509
/* 2-wire Serial Interface */
510
#define TWI_vect _VECTOR(33)
511
#define SIG_2WIRE_SERIAL _VECTOR(33)
512
513
/* Store Program Memory Read */
514
#define SPM_READY_vect _VECTOR(34)
515
#define SIG_SPM_READY _VECTOR(34)
516
517
#define _VECTORS_SIZE 140
518
519
520
The Register Bit names are represented by their bit number (0-7).
521
522
523
/* 2-wire Control Register - TWCR */
524
#define TWINT 7
525
#define TWEA 6
526
#define TWSTA 5
527
#define TWSTO 4
528
#define TWWC 3
529
#define TWEN 2
530
#define TWIE 0
531
532
/* 2-wire Address Register - TWAR */
533
#define TWA6 7
534
#define TWA5 6
535
#define TWA4 5
536
#define TWA3 4
537
#define TWA2 3
538
#define TWA1 2
539
#define TWA0 1
540
#define TWGCE 0
541
542
/* 2-wire Status Register - TWSR */
543
#define TWS7 7
544
#define TWS6 6
545
#define TWS5 5
546
#define TWS4 4
547
#define TWS3 3
548
#define TWPS1 1
549
#define TWPS0 0
550
551
/* External Memory Control Register A - XMCRA */
552
#define SRL2 6
553
#define SRL1 5
554
#define SRL0 4
555
#define SRW01 3
556
#define SRW00 2
557
#define SRW11 1
558
559
/* External Memory Control Register B - XMCRA */
560
#define XMBK 7
561
#define XMM2 2
562
#define XMM1 1
563
#define XMM0 0
564
565
/* XDIV Divide control register - XDIV */
566
#define XDIVEN 7
567
#define XDIV6 6
568
#define XDIV5 5
569
#define XDIV4 4
570
#define XDIV3 3
571
#define XDIV2 2
572
#define XDIV1 1
573
#define XDIV0 0
574
575
/* RAM Page Z select register - RAMPZ */
576
#define RAMPZ0 0
577
578
/* External Interrupt Control Register A - EICRA */
579
#define ISC31 7
580
#define ISC30 6
581
#define ISC21 5
582
#define ISC20 4
583
#define ISC11 3
584
#define ISC10 2
585
#define ISC01 1
586
#define ISC00 0
587
588
/* External Interrupt Control Register B - EICRB */
589
#define ISC71 7
590
#define ISC70 6
591
#define ISC61 5
592
#define ISC60 4
593
#define ISC51 3
594
#define ISC50 2
595
#define ISC41 1
596
#define ISC40 0
597
598
/* Store Program Memory Control Register - SPMCSR, SPMCR */
599
#define SPMIE 7
600
#define RWWSB 6
601
#define RWWSRE 4
602
#define BLBSET 3
603
#define PGWRT 2
604
#define PGERS 1
605
#define SPMEN 0
606
607
/* External Interrupt MaSK register - EIMSK */
608
#define INT7 7
609
#define INT6 6
610
#define INT5 5
611
#define INT4 4
612
#define INT3 3
613
#define INT2 2
614
#define INT1 1
615
#define INT0 0
616
617
/* External Interrupt Flag Register - EIFR */
618
#define INTF7 7
619
#define INTF6 6
620
#define INTF5 5
621
#define INTF4 4
622
#define INTF3 3
623
#define INTF2 2
624
#define INTF1 1
625
#define INTF0 0
626
627
/* Timer/Counter Interrupt MaSK register - TIMSK */
628
#define OCIE2 7
629
#define TOIE2 6
630
#define TICIE1 5
631
#define OCIE1A 4
632
#define OCIE1B 3
633
#define TOIE1 2
634
#define OCIE0 1
635
#define TOIE0 0
636
637
/* Timer/Counter Interrupt Flag Register - TIFR */
638
#define OCF2 7
639
#define TOV2 6
640
#define ICF1 5
641
#define OCF1A 4
642
#define OCF1B 3
643
#define TOV1 2
644
#define OCF0 1
645
#define TOV0 0
646
647
/* Extended Timer Interrupt MaSK register - ETIMSK */
648
#define TICIE3 5
649
#define OCIE3A 4
650
#define OCIE3B 3
651
#define TOIE3 2
652
#define OCIE3C 1
653
#define OCIE1C 0
654
655
/* Extended Timer Interrupt Flag Register - ETIFR */
656
#define ICF3 5
657
#define OCF3A 4
658
#define OCF3B 3
659
#define TOV3 2
660
#define OCF3C 1
661
#define OCF1C 0
662
663
/* MCU general Control Register - MCUCR */
664
#define SRE 7
665
#define SRW 6
666
#define SRW10 6
667
#define SE 5
668
#define SM1 4
669
#define SM0 3
670
#define SM2 2
671
#define IVSEL 1
672
#define IVCE 0
673
674
/* MCU Status Register - MCUSR, MCUCSR */
675
#define JTD 7
676
#define JTRF 4
677
#define WDRF 3
678
#define BORF 2
679
#define EXTRF 1
680
#define PORF 0
681
682
/* Timer/Counter Control Register (generic) */
683
#define FOC 7
684
#define WGM0 6
685
#define COM1 5
686
#define COM0 4
687
#define WGM1 3
688
#define CS2 2
689
#define CS1 1
690
#define CS0 0
691
692
/* Timer/Counter 0 Control Register - TCCR0 */
693
#define FOC0 7
694
#define WGM00 6
695
#define COM01 5
696
#define COM00 4
697
#define WGM01 3
698
#define CS02 2
699
#define CS01 1
700
#define CS00 0
701
702
/* Timer/Counter 2 Control Register - TCCR2 */
703
#define FOC2 7
704
#define WGM20 6
705
#define COM21 5
706
#define COM20 4
707
#define WGM21 3
708
#define CS22 2
709
#define CS21 1
710
#define CS20 0
711
712
/* Timer/Counter 0 Asynchronous Control & Status Register - ASSR */
713
#define AS0 3
714
#define TCN0UB 2
715
#define OCR0UB 1
716
#define TCR0UB 0
717
718
/* Timer/Counter Control Register A (generic) */
719
#define COMA1 7
720
#define COMA0 6
721
#define COMB1 5
722
#define COMB0 4
723
#define COMC1 3
724
#define COMC0 2
725
#define WGMA1 1
726
#define WGMA0 0
727
728
/* Timer/Counter 1 Control and Status Register A - TCCR1A */
729
#define COM1A1 7
730
#define COM1A0 6
731
#define COM1B1 5
732
#define COM1B0 4
733
#define COM1C1 3
734
#define COM1C0 2
735
#define WGM11 1
736
#define WGM10 0
737
738
/* Timer/Counter 3 Control and Status Register A - TCCR3A */
739
#define COM3A1 7
740
#define COM3A0 6
741
#define COM3B1 5
742
#define COM3B0 4
743
#define COM3C1 3
744
#define COM3C0 2
745
#define WGM31 1
746
#define WGM30 0
747
748
/* Timer/Counter Control and Status Register B (generic) */
749
#define ICNC 7
750
#define ICES 6
751
#define WGMB3 4
752
#define WGMB2 3
753
#define CSB2 2
754
#define CSB1 1
755
#define CSB0 0
756
757
/* Timer/Counter 1 Control and Status Register B - TCCR1B */
758
#define ICNC1 7
759
#define ICES1 6
760
#define WGM13 4
761
#define WGM12 3
762
#define CS12 2
763
#define CS11 1
764
#define CS10 0
765
766
/* Timer/Counter 3 Control and Status Register B - TCCR3B */
767
#define ICNC3 7
768
#define ICES3 6
769
#define WGM33 4
770
#define WGM32 3
771
#define CS32 2
772
#define CS31 1
773
#define CS30 0
774
775
/* Timer/Counter Control Register C (generic) */
776
#define FOCA 7
777
#define FOCB 6
778
#define FOCC 5
779
780
/* Timer/Counter 3 Control Register C - TCCR3C */
781
#define FOC3A 7
782
#define FOC3B 6
783
#define FOC3C 5
784
785
/* Timer/Counter 1 Control Register C - TCCR1C */
786
#define FOC1A 7
787
#define FOC1B 6
788
#define FOC1C 5
789
790
/* On-chip Debug Register - OCDR */
791
#define IDRD 7
792
#define OCDR7 7
793
#define OCDR6 6
794
#define OCDR5 5
795
#define OCDR4 4
796
#define OCDR3 3
797
#define OCDR2 2
798
#define OCDR1 1
799
#define OCDR0 0
800
801
/* Watchdog Timer Control Register - WDTCR */
802
#define WDCE 4
803
#define WDE 3
804
#define WDP2 2
805
#define WDP1 1
806
#define WDP0 0
807
808
809
The ADHSM bit has been removed from all documentation,
810
as being not needed at all since the comparator has proven
811
to be fast enough even without feeding it more power.
812
813
814
/* Special Function I/O Register - SFIOR */
815
#define TSM 7
816
#define ACME 3
817
#define PUD 2
818
#define PSR0 1
819
#define PSR321 0
820
821
/* SPI Status Register - SPSR */
822
#define SPIF 7
823
#define WCOL 6
824
#define SPI2X 0
825
826
/* SPI Control Register - SPCR */
827
#define SPIE 7
828
#define SPE 6
829
#define DORD 5
830
#define MSTR 4
831
#define CPOL 3
832
#define CPHA 2
833
#define SPR1 1
834
#define SPR0 0
835
836
/* USART Register C (generic) */
837
#define UMSEL 6
838
#define UPM1 5
839
#define UPM0 4
840
#define USBS 3
841
#define UCSZ1 2
842
#define UCSZ0 1
843
#define UCPOL 0
844
845
/* USART1 Register C - UCSR1C */
846
#define UMSEL1 6
847
#define UPM11 5
848
#define UPM10 4
849
#define USBS1 3
850
#define UCSZ11 2
851
#define UCSZ10 1
852
#define UCPOL1 0
853
854
/* USART0 Register C - UCSR0C */
855
#define UMSEL0 6
856
#define UPM01 5
857
#define UPM00 4
858
#define USBS0 3
859
#define UCSZ01 2
860
#define UCSZ00 1
861
#define UCPOL0 0
862
863
/* USART Status Register A (generic) */
864
#define RXC 7
865
#define TXC 6
866
#define UDRE 5
867
#define FE 4
868
#define DOR 3
869
#define UPE 2
870
#define U2X 1
871
#define MPCM 0
872
873
/* USART1 Status Register A - UCSR1A */
874
#define RXC1 7
875
#define TXC1 6
876
#define UDRE1 5
877
#define FE1 4
878
#define DOR1 3
879
#define UPE1 2
880
#define U2X1 1
881
#define MPCM1 0
882
883
/* USART0 Status Register A - UCSR0A */
884
#define RXC0 7
885
#define TXC0 6
886
#define UDRE0 5
887
#define FE0 4
888
#define DOR0 3
889
#define UPE0 2
890
#define U2X0 1
891
#define MPCM0 0
892
893
/* USART Control Register B (generic) */
894
#define RXCIE 7
895
#define TXCIE 6
896
#define UDRIE 5
897
#define RXEN 4
898
#define TXEN 3
899
#define UCSZ 2
900
#define UCSZ2 2
901
#define RXB8 1
902
#define TXB8 0
903
904
/* USART1 Control Register B - UCSR1B */
905
#define RXCIE1 7
906
#define TXCIE1 6
907
#define UDRIE1 5
908
#define RXEN1 4
909
#define TXEN1 3
910
#define UCSZ12 2
911
#define RXB81 1
912
#define TXB81 0
913
914
/* USART0 Control Register B - UCSR0B */
915
#define RXCIE0 7
916
#define TXCIE0 6
917
#define UDRIE0 5
918
#define RXEN0 4
919
#define TXEN0 3
920
#define UCSZ02 2
921
#define RXB80 1
922
#define TXB80 0
923
924
/* Analog Comparator Control and Status Register - ACSR */
925
#define ACD 7
926
#define ACBG 6
927
#define ACO 5
928
#define ACI 4
929
#define ACIE 3
930
#define ACIC 2
931
#define ACIS1 1
932
#define ACIS0 0
933
934
/* ADC Control and status register - ADCSRA */
935
#define ADEN 7
936
#define ADSC 6
937
#define ADFR 5
938
#define ADIF 4
939
#define ADIE 3
940
#define ADPS2 2
941
#define ADPS1 1
942
#define ADPS0 0
943
944
/* ADC Multiplexer select - ADMUX */
945
#define REFS1 7
946
#define REFS0 6
947
#define ADLAR 5
948
#define MUX4 4
949
#define MUX3 3
950
#define MUX2 2
951
#define MUX1 1
952
#define MUX0 0
953
954
/* Port A Data Register - PORTA */
955
#define PA7 7
956
#define PA6 6
957
#define PA5 5
958
#define PA4 4
959
#define PA3 3
960
#define PA2 2
961
#define PA1 1
962
#define PA0 0
963
964
/* Port A Data Direction Register - DDRA */
965
#define DDA7 7
966
#define DDA6 6
967
#define DDA5 5
968
#define DDA4 4
969
#define DDA3 3
970
#define DDA2 2
971
#define DDA1 1
972
#define DDA0 0
973
974
/* Port A Input Pins - PINA */
975
#define PINA7 7
976
#define PINA6 6
977
#define PINA5 5
978
#define PINA4 4
979
#define PINA3 3
980
#define PINA2 2
981
#define PINA1 1
982
#define PINA0 0
983
984
/* Port B Data Register - PORTB */
985
#define PB7 7
986
#define PB6 6
987
#define PB5 5
988
#define PB4 4
989
#define PB3 3
990
#define PB2 2
991
#define PB1 1
992
#define PB0 0
993
994
/* Port B Data Direction Register - DDRB */
995
#define DDB7 7
996
#define DDB6 6
997
#define DDB5 5
998
#define DDB4 4
999
#define DDB3 3
1000
#define DDB2 2
1001
#define DDB1 1
1002
#define DDB0 0
1003
1004
/* Port B Input Pins - PINB */
1005
#define PINB7 7
1006
#define PINB6 6
1007
#define PINB5 5
1008
#define PINB4 4
1009
#define PINB3 3
1010
#define PINB2 2
1011
#define PINB1 1
1012
#define PINB0 0
1013
1014
/* Port C Data Register - PORTC */
1015
#define PC7 7
1016
#define PC6 6
1017
#define PC5 5
1018
#define PC4 4
1019
#define PC3 3
1020
#define PC2 2
1021
#define PC1 1
1022
#define PC0 0
1023
1024
/* Port C Data Direction Register - DDRC */
1025
#define DDC7 7
1026
#define DDC6 6
1027
#define DDC5 5
1028
#define DDC4 4
1029
#define DDC3 3
1030
#define DDC2 2
1031
#define DDC1 1
1032
#define DDC0 0
1033
1034
/* Port C Input Pins - PINC */
1035
#define PINC7 7
1036
#define PINC6 6
1037
#define PINC5 5
1038
#define PINC4 4
1039
#define PINC3 3
1040
#define PINC2 2
1041
#define PINC1 1
1042
#define PINC0 0
1043
1044
/* Port D Data Register - PORTD */
1045
#define PD7 7
1046
#define PD6 6
1047
#define PD5 5
1048
#define PD4 4
1049
#define PD3 3
1050
#define PD2 2
1051
#define PD1 1
1052
#define PD0 0
1053
1054
/* Port D Data Direction Register - DDRD */
1055
#define DDD7 7
1056
#define DDD6 6
1057
#define DDD5 5
1058
#define DDD4 4
1059
#define DDD3 3
1060
#define DDD2 2
1061
#define DDD1 1
1062
#define DDD0 0
1063
1064
/* Port D Input Pins - PIND */
1065
#define PIND7 7
1066
#define PIND6 6
1067
#define PIND5 5
1068
#define PIND4 4
1069
#define PIND3 3
1070
#define PIND2 2
1071
#define PIND1 1
1072
#define PIND0 0
1073
1074
/* Port E Data Register - PORTE */
1075
#define PE7 7
1076
#define PE6 6
1077
#define PE5 5
1078
#define PE4 4
1079
#define PE3 3
1080
#define PE2 2
1081
#define PE1 1
1082
#define PE0 0
1083
1084
/* Port E Data Direction Register - DDRE */
1085
#define DDE7 7
1086
#define DDE6 6
1087
#define DDE5 5
1088
#define DDE4 4
1089
#define DDE3 3
1090
#define DDE2 2
1091
#define DDE1 1
1092
#define DDE0 0
1093
1094
/* Port E Input Pins - PINE */
1095
#define PINE7 7
1096
#define PINE6 6
1097
#define PINE5 5
1098
#define PINE4 4
1099
#define PINE3 3
1100
#define PINE2 2
1101
#define PINE1 1
1102
#define PINE0 0
1103
1104
/* Port F Data Register - PORTF */
1105
#define PF7 7
1106
#define PF6 6
1107
#define PF5 5
1108
#define PF4 4
1109
#define PF3 3
1110
#define PF2 2
1111
#define PF1 1
1112
#define PF0 0
1113
1114
/* Port F Data Direction Register - DDRF */
1115
#define DDF7 7
1116
#define DDF6 6
1117
#define DDF5 5
1118
#define DDF4 4
1119
#define DDF3 3
1120
#define DDF2 2
1121
#define DDF1 1
1122
#define DDF0 0
1123
1124
/* Port F Input Pins - PINF */
1125
#define PINF7 7
1126
#define PINF6 6
1127
#define PINF5 5
1128
#define PINF4 4
1129
#define PINF3 3
1130
#define PINF2 2
1131
#define PINF1 1
1132
#define PINF0 0
1133
1134
/* Port G Data Register - PORTG */
1135
#define PG4 4
1136
#define PG3 3
1137
#define PG2 2
1138
#define PG1 1
1139
#define PG0 0
1140
1141
/* Port G Data Direction Register - DDRG */
1142
#define DDG4 4
1143
#define DDG3 3
1144
#define DDG2 2
1145
#define DDG1 1
1146
#define DDG0 0
1147
1148
/* Port G Input Pins - PING */
1149
#define PING4 4
1150
#define PING3 3
1151
#define PING2 2
1152
#define PING1 1
1153
#define PING0 0
1154
1155
1156
#define EERIE 3
1157
#define EEMWE 2
1158
#define EEWE 1
1159
#define EERE 0
1160
1161
/* Constants */
1162
#define SPM_PAGESIZE 256
1163
#define RAMEND 0x10FF
/* Last On-Chip SRAM Location */
1164
#define XRAMEND 0xFFFF
1165
#define E2END 0x0FFF
1166
#define E2PAGESIZE 8
1167
#define FLASHEND 0x1FFFF
1168
1169
1170
/* Fuses */
1171
1172
#define FUSE_MEMORY_SIZE 3
1173
1174
/* Low Fuse Byte */
1175
#define FUSE_CKSEL0 (unsigned char)~_BV(0)
1176
#define FUSE_CKSEL1 (unsigned char)~_BV(1)
1177
#define FUSE_CKSEL2 (unsigned char)~_BV(2)
1178
#define FUSE_CKSEL3 (unsigned char)~_BV(3)
1179
#define FUSE_SUT0 (unsigned char)~_BV(4)
1180
#define FUSE_SUT1 (unsigned char)~_BV(5)
1181
#define FUSE_BODEN (unsigned char)~_BV(6)
1182
#define FUSE_BODLEVEL (unsigned char)~_BV(7)
1183
#define LFUSE_DEFAULT (FUSE_CKSEL1 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0)
1184
1185
/* High Fuse Byte */
1186
#define FUSE_BOOTRST (unsigned char)~_BV(0)
1187
#define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
1188
#define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
1189
#define FUSE_EESAVE (unsigned char)~_BV(3)
1190
#define FUSE_CKOPT (unsigned char)~_BV(4)
1191
#define FUSE_SPIEN (unsigned char)~_BV(5)
1192
#define FUSE_JTAGEN (unsigned char)~_BV(6)
1193
#define FUSE_OCDEN (unsigned char)~_BV(7)
1194
#define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
1195
1196
/* Extended Fuse Byte */
1197
#define FUSE_WDTON (unsigned char)~_BV(0)
1198
#define FUSE_M103C (unsigned char)~_BV(1)
1199
#define EFUSE_DEFAULT (FUSE_M103C)
1200
1201
1202
/* Lock Bits */
1203
#define __LOCK_BITS_EXIST
1204
#define __BOOT_LOCK_BITS_0_EXIST
1205
#define __BOOT_LOCK_BITS_1_EXIST
1206
1207
1208
/* Signature */
1209
#define SIGNATURE_0 0x1E
1210
#define SIGNATURE_1 0x97
1211
#define SIGNATURE_2 0x02
1212
1213
1215
#endif
/* _AVR_IOM128_H_ */
