#define | _AVR_IOXXX_H_ "ioat94k.h" |
#define | UBRR1 _SFR_IO8(0x00) |
#define | UCSR1B _SFR_IO8(0x01) |
#define | UCSR1A _SFR_IO8(0x02) |
#define | UDR1 _SFR_IO8(0x03) |
#define | PINE _SFR_IO8(0x05) |
#define | DDRE _SFR_IO8(0x06) |
#define | PORTE _SFR_IO8(0x07) |
#define | OCDR _SFR_IO8(0x08) |
#define | UBRR0 _SFR_IO8(0x09) |
#define | UCSR0B _SFR_IO8(0x0A) |
#define | UCSR0A _SFR_IO8(0x0B) |
#define | UDR0 _SFR_IO8(0x0C) |
#define | PIND _SFR_IO8(0x10) |
#define | DDRD _SFR_IO8(0x11) |
#define | PORTD _SFR_IO8(0x12) |
#define | FISCR _SFR_IO8(0x13) |
#define | FISUA _SFR_IO8(0x14) |
#define | FISUB _SFR_IO8(0x15) |
#define | FISUC _SFR_IO8(0x16) |
#define | FISUD _SFR_IO8(0x17) |
#define | FPGAX _SFR_IO8(0x18) |
#define | FPGAY _SFR_IO8(0x19) |
#define | FPGAZ _SFR_IO8(0x1A) |
#define | FPGAD _SFR_IO8(0x1B) |
#define | TWBR _SFR_IO8(0x1C) |
#define | TWSR _SFR_IO8(0x1D) |
#define | TWAR _SFR_IO8(0x1E) |
#define | TWDR _SFR_IO8(0x1F) |
#define | UBRRH _SFR_IO8(0x20) |
#define | UBRRHI UBRRH /* New name in datasheet (1138F-FPSLI-06/02) */ |
#define | WDTCR _SFR_IO8(0x21) |
#define | OCR2 _SFR_IO8(0x22) |
#define | TCNT2 _SFR_IO8(0x23) |
#define | ICR1 _SFR_IO16(0x24) |
#define | ICR1L _SFR_IO8(0x24) |
#define | ICR1H _SFR_IO8(0x25) |
#define | ASSR _SFR_IO8(0x26) |
#define | TCCR2 _SFR_IO8(0x27) |
#define | OCR1B _SFR_IO16(0x28) |
#define | OCR1BL _SFR_IO8(0x28) |
#define | OCR1BH _SFR_IO8(0x29) |
#define | OCR1A _SFR_IO16(0x2A) |
#define | OCR1AL _SFR_IO8(0x2A) |
#define | OCR1AH _SFR_IO8(0x2B) |
#define | TCNT1 _SFR_IO16(0x2C) |
#define | TCNT1L _SFR_IO8(0x2C) |
#define | TCNT1H _SFR_IO8(0x2D) |
#define | TCCR1B _SFR_IO8(0x2E) |
#define | TCCR1A _SFR_IO8(0x2F) |
#define | SFIOR _SFR_IO8(0x30) |
#define | OCR0 _SFR_IO8(0x31) |
#define | TCNT0 _SFR_IO8(0x32) |
#define | TCCR0 _SFR_IO8(0x33) |
#define | MCUR _SFR_IO8(0x35) |
#define | TWCR _SFR_IO8(0x36) |
#define | TIFR _SFR_IO8(0x38) |
#define | TIMSK _SFR_IO8(0x39) |
#define | SFTCR _SFR_IO8(0x3A) |
#define | EIMF _SFR_IO8(0x3B) |
#define | SIG_FPGA_INTERRUPT0 _VECTOR(1) /* FPGA_INT0 */ |
#define | SIG_INTERRUPT0 _VECTOR(2) /* EXT_INT0 */ |
#define | SIG_FPGA_INTERRUPT1 _VECTOR(3) /* FPGA_INT1 */ |
#define | SIG_INTERRUPT1 _VECTOR(4) /* EXT_INT1 */ |
#define | SIG_FPGA_INTERRUPT2 _VECTOR(5) /* FPGA_INT2 */ |
#define | SIG_INTERRUPT2 _VECTOR(6) /* EXT_INT2 */ |
#define | SIG_FPGA_INTERRUPT3 _VECTOR(7) /* FPGA_INT3 */ |
#define | SIG_INTERRUPT3 _VECTOR(8) /* EXT_INT3 */ |
#define | SIG_OUTPUT_COMPARE2 _VECTOR(9) /* TIM2_COMP */ |
#define | SIG_OVERFLOW2 _VECTOR(10) /* TIM2_OVF */ |
#define | SIG_INPUT_CAPTURE1 _VECTOR(11) /* TIM1_CAPT */ |
#define | SIG_OUTPUT_COMPARE1A _VECTOR(12) /* TIM1_COMPA */ |
#define | SIG_OUTPUT_COMPARE1B _VECTOR(13) /* TIM1_COMPB */ |
#define | SIG_OVERFLOW1 _VECTOR(14) /* TIM1_OVF */ |
#define | SIG_OUTPUT_COMPARE0 _VECTOR(15) /* TIM0_COMP */ |
#define | SIG_OVERFLOW0 _VECTOR(16) /* TIM0_OVF */ |
#define | SIG_FPGA_INTERRUPT4 _VECTOR(17) /* FPGA_INT4 */ |
#define | SIG_FPGA_INTERRUPT5 _VECTOR(18) /* FPGA_INT5 */ |
#define | SIG_FPGA_INTERRUPT6 _VECTOR(19) /* FPGA_INT6 */ |
#define | SIG_FPGA_INTERRUPT7 _VECTOR(20) /* FPGA_INT7 */ |
#define | SIG_UART0_RECV _VECTOR(21) /* UART0_RXC */ |
#define | SIG_UART0_DATA _VECTOR(22) /* UART0_DRE */ |
#define | SIG_UART0_TRANS _VECTOR(23) /* UART0_TXC */ |
#define | SIG_FPGA_INTERRUPT8 _VECTOR(24) /* FPGA_INT8 */ |
#define | SIG_FPGA_INTERRUPT9 _VECTOR(25) /* FPGA_INT9 */ |
#define | SIG_FPGA_INTERRUPT10 _VECTOR(26) /* FPGA_INT10 */ |
#define | SIG_FPGA_INTERRUPT11 _VECTOR(27) /* FPGA_INT11 */ |
#define | SIG_UART1_RECV _VECTOR(28) /* UART1_RXC */ |
#define | SIG_UART1_DATA _VECTOR(29) /* UART1_DRE */ |
#define | SIG_UART1_TRANS _VECTOR(30) /* UART1_TXC */ |
#define | SIG_FPGA_INTERRUPT12 _VECTOR(31) /* FPGA_INT12 */ |
#define | SIG_FPGA_INTERRUPT13 _VECTOR(32) /* FPGA_INT13 */ |
#define | SIG_FPGA_INTERRUPT14 _VECTOR(33) /* FPGA_INT14 */ |
#define | SIG_FPGA_INTERRUPT15 _VECTOR(34) /* FPGA_INT15 */ |
#define | SIG_2WIRE_SERIAL _VECTOR(35) /* TWS_INT */ |
#define | _VECTORS_SIZE 144 |
#define | AS2 3 |
#define | TCN2UB 2 |
#define | OCR2UB 1 |
#define | TCR2UB 0 |
#define | DDD7 7 |
#define | DDD6 6 |
#define | DDD5 5 |
#define | DDD4 4 |
#define | DDD3 3 |
#define | DDD2 2 |
#define | DDD1 1 |
#define | DDD0 0 |
#define | DDE7 7 |
#define | DDE6 6 |
#define | DDE5 5 |
#define | DDE4 4 |
#define | DDE3 3 |
#define | DDE2 2 |
#define | DDE1 1 |
#define | DDE0 0 |
#define | INTF3 7 |
#define | INTF2 6 |
#define | INTF1 5 |
#define | INTF0 4 |
#define | INT3 3 |
#define | INT2 2 |
#define | INT1 1 |
#define | INT0 0 |
#define | FIADR 7 |
#define | XFIS1 1 |
#define | XFIS0 0 |
#define | FIF3 7 |
#define | FIF2 6 |
#define | FIF1 5 |
#define | FIF0 4 |
#define | FINT3 3 |
#define | FINT2 2 |
#define | FINT1 1 |
#define | FINT0 0 |
#define | FIF7 7 |
#define | FIF6 6 |
#define | FIF5 5 |
#define | FIF4 4 |
#define | FINT7 3 |
#define | FINT6 2 |
#define | FINT5 1 |
#define | FINT4 0 |
#define | FIF11 7 |
#define | FIF10 6 |
#define | FIF9 5 |
#define | FIF8 4 |
#define | FINT11 3 |
#define | FINT10 2 |
#define | FINT9 1 |
#define | FINT8 0 |
#define | FIF15 7 |
#define | FIF14 6 |
#define | FIF13 5 |
#define | FIF12 4 |
#define | FINT15 3 |
#define | FINT14 2 |
#define | FINT13 1 |
#define | FINT12 0 |
#define | JTRF 7 |
#define | JTD 6 |
#define | SE 5 |
#define | SM1 4 |
#define | SM0 3 |
#define | PORF 2 |
#define | WDRF 1 |
#define | EXTRF 0 |
#define | IDRD 7 |
#define | PIND7 7 |
#define | PIND6 6 |
#define | PIND5 5 |
#define | PIND4 4 |
#define | PIND3 3 |
#define | PIND2 2 |
#define | PIND1 1 |
#define | PIND0 0 |
#define | PINE7 7 |
#define | PINE6 6 |
#define | PINE5 5 |
#define | PINE4 4 |
#define | PINE3 3 |
#define | PINE2 2 |
#define | PINE1 1 |
#define | PINE0 0 |
#define | PD7 7 |
#define | PD6 6 |
#define | PD5 5 |
#define | PD4 4 |
#define | PD3 3 |
#define | PD2 2 |
#define | PD1 1 |
#define | PD0 0 |
#define | PE7 7 |
#define | PE6 6 |
#define | PE5 5 |
#define | PE4 4 |
#define | PE3 3 |
#define | PE2 2 |
#define | PE1 1 |
#define | PE0 0 |
#define | PSR2 1 |
#define | PSR10 0 |
#define | FMXOR 3 |
#define | WDTS 2 |
#define | DBG 1 |
#define | SRST 0 |
#define | FOC0 7 |
#define | PWM0 6 |
#define | COM01 5 |
#define | COM00 4 |
#define | CTC0 3 |
#define | CS02 2 |
#define | CS01 1 |
#define | CS00 0 |
#define | COM1A1 7 |
#define | COM1A0 6 |
#define | COM1B1 5 |
#define | COM1B0 4 |
#define | FOC1A 3 |
#define | FOC1B 2 |
#define | PWM11 1 |
#define | PWM10 0 |
#define | ICNC1 7 |
#define | ICES1 6 |
#define | ICPE 5 |
#define | CTC1 3 |
#define | CS12 2 |
#define | CS11 1 |
#define | CS10 0 |
#define | FOC2 7 |
#define | PWM2 6 |
#define | COM21 5 |
#define | COM20 4 |
#define | CTC2 3 |
#define | CS22 2 |
#define | CS21 1 |
#define | CS20 0 |
#define | TOV1 7 |
#define | OCF1A 6 |
#define | OCF1B 5 |
#define | TOV2 4 |
#define | ICF1 3 |
#define | OCF2 2 |
#define | TOV0 1 |
#define | OCF0 0 |
#define | TOIE1 7 |
#define | OCIE1A 6 |
#define | OCIE1B 5 |
#define | TOIE2 4 |
#define | TICIE1 3 |
#define | OCIE2 2 |
#define | TOIE0 1 |
#define | OCIE0 0 |
#define | TWGCE 0 |
#define | TWINT 7 |
#define | TWEA 6 |
#define | TWSTA 5 |
#define | TWSTO 4 |
#define | TWWC 3 |
#define | TWEN 2 |
#define | TWIE 0 |
#define | TWS7 7 |
#define | TWS6 6 |
#define | TWS5 5 |
#define | TWS4 4 |
#define | TWS3 3 |
#define | RXC0 7 |
#define | TXC0 6 |
#define | UDRE0 5 |
#define | FE0 4 |
#define | OR0 3 |
#define | U2X0 1 |
#define | MPCM0 0 |
#define | RXCIE0 7 |
#define | TXCIE0 6 |
#define | UDRIE0 5 |
#define | RXEN0 4 |
#define | TXEN0 3 |
#define | CHR90 2 |
#define | RXB80 1 |
#define | TXB80 0 |
#define | RXC1 7 |
#define | TXC1 6 |
#define | UDRE1 5 |
#define | FE1 4 |
#define | OR1 3 |
#define | U2X1 1 |
#define | MPCM1 0 |
#define | RXCIE1 7 |
#define | TXCIE1 6 |
#define | UDRIE1 5 |
#define | RXEN1 4 |
#define | TXEN1 3 |
#define | CHR91 2 |
#define | RXB81 1 |
#define | TXB81 0 |
#define | WDTOE 4 |
#define | WDE 3 |
#define | WDP2 2 |
#define | WDP1 1 |
#define | WDP0 0 |
#define | RAMEND 0x0FFF |
#define | XRAMEND RAMEND |
#define | E2END 0 |
#define | FLASHEND 0x7FFF |
Definitions for AT94K Series FPSLIC(tm)
This file should only be included from <avr/io.h>, never directly.
