Definitions for AT90PWM216. More...
| #define | _AVR_IOXXX_H_ "io90pwm216.h" |
| #define | PINB _SFR_IO8(0x03) |
| #define | PINB0 0 |
| #define | PINB1 1 |
| #define | PINB2 2 |
| #define | PINB3 3 |
| #define | PINB4 4 |
| #define | PINB5 5 |
| #define | PINB6 6 |
| #define | PINB7 7 |
| #define | DDRB _SFR_IO8(0x04) |
| #define | DDB0 0 |
| #define | DDB1 1 |
| #define | DDB2 2 |
| #define | DDB3 3 |
| #define | DDB4 4 |
| #define | DDB5 5 |
| #define | DDB6 6 |
| #define | DDB7 7 |
| #define | PORTB _SFR_IO8(0x05) |
| #define | PB0 0 |
| #define | PB1 1 |
| #define | PB2 2 |
| #define | PB3 3 |
| #define | PB4 4 |
| #define | PB5 5 |
| #define | PB6 6 |
| #define | PB7 7 |
| #define | PINC _SFR_IO8(0x06) |
| #define | PINC0 0 |
| #define | PINC1 1 |
| #define | PINC2 2 |
| #define | PINC3 3 |
| #define | PINC4 4 |
| #define | PINC5 5 |
| #define | PINC6 6 |
| #define | PINC7 7 |
| #define | DDRC _SFR_IO8(0x07) |
| #define | DDC0 0 |
| #define | DDC1 1 |
| #define | DDC2 2 |
| #define | DDC3 3 |
| #define | DDC4 4 |
| #define | DDC5 5 |
| #define | DDC6 6 |
| #define | DDC7 7 |
| #define | PORTC _SFR_IO8(0x08) |
| #define | PC0 0 |
| #define | PC1 1 |
| #define | PC2 2 |
| #define | PC3 3 |
| #define | PC4 4 |
| #define | PC5 5 |
| #define | PC6 6 |
| #define | PC7 7 |
| #define | PIND _SFR_IO8(0x09) |
| #define | PIND0 0 |
| #define | PIND1 1 |
| #define | PIND2 2 |
| #define | PIND3 3 |
| #define | PIND4 4 |
| #define | PIND5 5 |
| #define | PIND6 6 |
| #define | PIND7 7 |
| #define | DDRD _SFR_IO8(0x0A) |
| #define | DDD0 0 |
| #define | DDD1 1 |
| #define | DDD2 2 |
| #define | DDD3 3 |
| #define | DDD4 4 |
| #define | DDD5 5 |
| #define | DDD6 6 |
| #define | DDD7 7 |
| #define | PORTD _SFR_IO8(0x0B) |
| #define | PD0 0 |
| #define | PD1 1 |
| #define | PD2 2 |
| #define | PD3 3 |
| #define | PD4 4 |
| #define | PD5 5 |
| #define | PD6 6 |
| #define | PD7 7 |
| #define | PINE _SFR_IO8(0x0C) |
| #define | PINE0 0 |
| #define | PINE1 1 |
| #define | PINE2 2 |
| #define | DDRE _SFR_IO8(0x0D) |
| #define | DDE0 0 |
| #define | DDE1 1 |
| #define | DDE2 2 |
| #define | PORTE _SFR_IO8(0x0E) |
| #define | PE0 0 |
| #define | PE1 1 |
| #define | PE2 2 |
| #define | TIFR0 _SFR_IO8(0x15) |
| #define | TOV0 0 /* Overflow Flag */ |
| #define | OCF0A 1 /* Output Compare Flag 0A */ |
| #define | OCF0B 2 /* Output Compare Flag 0B */ |
| #define | TIFR1 _SFR_IO8(0x16) |
| #define | TOV1 0 /* Overflow Flag */ |
| #define | OCF1A 1 /* Output Compare Flag 1A*/ |
| #define | OCF1B 2 /* Output Compare Flag 1B*/ |
| #define | ICF1 5 /* Input Capture Flag 1 */ |
| #define | GPIOR1 _SFR_IO8(0x19) |
| #define | GPIOR10 0 |
| #define | GPIOR11 1 |
| #define | GPIOR12 2 |
| #define | GPIOR13 3 |
| #define | GPIOR14 4 |
| #define | GPIOR15 5 |
| #define | GPIOR16 6 |
| #define | GPIOR17 7 |
| #define | GPIOR2 _SFR_IO8(0x1A) |
| #define | GPIOR20 0 |
| #define | GPIOR21 1 |
| #define | GPIOR22 2 |
| #define | GPIOR23 3 |
| #define | GPIOR24 4 |
| #define | GPIOR25 5 |
| #define | GPIOR26 6 |
| #define | GPIOR27 7 |
| #define | GPIOR3 _SFR_IO8(0x1B) |
| #define | GPIOR30 0 |
| #define | GPIOR31 1 |
| #define | GPIOR32 2 |
| #define | GPIOR33 3 |
| #define | GPIOR34 4 |
| #define | GPIOR35 5 |
| #define | GPIOR36 6 |
| #define | GPIOR37 7 |
| #define | EIFR _SFR_IO8(0x1C) |
| #define | INTF0 0 |
| #define | INTF1 1 |
| #define | INTF2 2 |
| #define | INTF3 3 |
| #define | EIMSK _SFR_IO8(0x1D) |
| #define | INT0 0 /* External Interrupt Request 0 Enable */ |
| #define | INT1 1 /* External Interrupt Request 1 Enable */ |
| #define | INT2 2 /* External Interrupt Request 2 Enable */ |
| #define | INT3 3 /* External Interrupt Request 3 Enable */ |
| #define | GPIOR0 _SFR_IO8(0x1E) |
| #define | GPIOR00 0 |
| #define | GPIOR01 1 |
| #define | GPIOR02 2 |
| #define | GPIOR03 3 |
| #define | GPIOR04 4 |
| #define | GPIOR05 5 |
| #define | GPIOR06 6 |
| #define | GPIOR07 7 |
| #define | EECR _SFR_IO8(0x1F) |
| #define | EERE 0 /* EEPROM Read Enable */ |
| #define | EEWE 1 /* EEPROM Write Enable */ |
| #define | EEMWE 2 /* EEPROM Master Write Enable */ |
| #define | EERIE 3 /* EEPROM Ready Interrupt Enable */ |
| #define | EEDR _SFR_IO8(0x20) |
| #define | EEDR0 0 |
| #define | EEDR1 1 |
| #define | EEDR2 2 |
| #define | EEDR3 3 |
| #define | EEDR4 4 |
| #define | EEDR5 5 |
| #define | EEDR6 6 |
| #define | EEDR7 7 |
| #define | EEAR _SFR_IO16(0x21) |
| #define | EEARL _SFR_IO8(0x21) |
| #define | EEAR0 0 |
| #define | EEAR1 1 |
| #define | EEAR2 2 |
| #define | EEAR3 3 |
| #define | EEAR4 4 |
| #define | EEAR5 5 |
| #define | EEAR6 6 |
| #define | EEAR7 7 |
| #define | EEARH _SFR_IO8(0x22) |
| #define | EEAR8 0 |
| #define | EEAR9 1 |
| #define | EEAR10 2 |
| #define | EEAR11 3 |
| #define | __EEPROM_REG_LOCATIONS__ 1F2021 |
| #define | GTCCR _SFR_IO8(0x23) |
| #define | PSR10 0 /* Prescaler Reset Timer/Counter1 and Timer/Counter0 */ |
| #define | ICPSEL1 6 /* Timer1 Input Capture Selection Bit */ |
| #define | TSM 7 /* Timer/Counter Synchronization Mode */ |
| #define | TCCR0A _SFR_IO8(0x24) |
| #define | WGM00 0 /* Waveform Generation Mode */ |
| #define | WGM01 1 /* Waveform Generation Mode */ |
| #define | COM0B0 4 /* Compare Output Mode, Fast PWm */ |
| #define | COM0B1 5 /* Compare Output Mode, Fast PWm */ |
| #define | COM0A0 6 /* Compare Output Mode, Phase Correct PWM Mode */ |
| #define | COM0A1 7 /* Compare Output Mode, Phase Correct PWM Mode */ |
| #define | TCCR0B _SFR_IO8(0x25) |
| #define | CS00 0 /* Clock Select */ |
| #define | CS01 1 /* Clock Select */ |
| #define | CS02 2 /* Clock Select */ |
| #define | WGM02 3 /* Waveform Generation Mode */ |
| #define | FOC0B 6 /* Force Output Compare B */ |
| #define | FOC0A 7 /* Force Output Compare A */ |
| #define | TCNT0 _SFR_IO8(0x26) |
| #define | TCNT00 0 |
| #define | TCNT01 1 |
| #define | TCNT02 2 |
| #define | TCNT03 3 |
| #define | TCNT04 4 |
| #define | TCNT05 5 |
| #define | TCNT06 6 |
| #define | TCNT07 7 |
| #define | OCR0A _SFR_IO8(0x27) |
| #define | OCR0A0 0 |
| #define | OCR0A1 1 |
| #define | OCR0A2 2 |
| #define | OCR0A3 3 |
| #define | OCR0A4 4 |
| #define | OCR0A5 5 |
| #define | OCR0A6 6 |
| #define | OCR0A7 7 |
| #define | OCR0B _SFR_IO8(0x28) |
| #define | OCR0B0 0 |
| #define | OCR0B1 1 |
| #define | OCR0B2 2 |
| #define | OCR0B3 3 |
| #define | OCR0B4 4 |
| #define | OCR0B5 5 |
| #define | OCR0B6 6 |
| #define | OCR0B7 7 |
| #define | PLLCSR _SFR_IO8(0x29) |
| #define | PLOCK 0 /* PLL Lock Detector */ |
| #define | PLLE 1 /* PLL Enable */ |
| #define | PLLF 2 /* PLL Factor */ |
| #define | SPCR _SFR_IO8(0x2C) |
| #define | SPR0 0 /* SPI Clock Rate Select 0 */ |
| #define | SPR1 1 /* SPI Clock Rate Select 1 */ |
| #define | CPHA 2 /* Clock Phase */ |
| #define | CPOL 3 /* Clock polarity */ |
| #define | MSTR 4 /* Master/Slave Select */ |
| #define | DORD 5 /* Data Order */ |
| #define | SPE 6 /* SPI Enable */ |
| #define | SPIE 7 /* SPI Interrupt Enable */ |
| #define | SPSR _SFR_IO8(0x2D) |
| #define | SPI2X 0 /* Double SPI Speed Bit */ |
| #define | WCOL 6 /* Write Collision Flag */ |
| #define | SPIF 7 /* SPI Interrupt Flag */ |
| #define | SPDR _SFR_IO8(0x2E) |
| #define | SPD0 0 |
| #define | SPD1 1 |
| #define | SPD2 2 |
| #define | SPD3 3 |
| #define | SPD4 4 |
| #define | SPD5 5 |
| #define | SPD6 6 |
| #define | SPD7 7 |
| #define | ACSR _SFR_IO8(0x30) |
| #define | AC0O 0 /* Analog Comparator 0 Output Bit */ |
| #define | AC1O 1 /* Analog Comparator 1 Output Bit */ |
| #define | AC2O 2 /* Analog Comparator 2 Output Bit */ |
| #define | AC0IF 4 /* Analog Comparator 0 Interrupt Flag Bit */ |
| #define | AC1IF 5 /* Analog Comparator 1 Interrupt Flag Bit */ |
| #define | AC2IF 6 /* Analog Comparator 2 Interrupt Flag Bit */ |
| #define | ACCKDIV 7 /* Analog Comparator Clock Divider */ |
| #define | SMCR _SFR_IO8(0x33) |
| #define | SE 0 /* Sleep Enable */ |
| #define | SM0 1 /* Sleep Mode Select bit0 */ |
| #define | SM1 2 /* Sleep Mode Select bit1 */ |
| #define | SM2 3 /* Sleep Mode Select bit2 */ |
| #define | MCUSR _SFR_IO8(0x34) |
| #define | PORF 0 /* Power-on reset flag */ |
| #define | EXTRF 1 /* External Reset Flag */ |
| #define | BORF 2 /* Brown-out Reset Flag */ |
| #define | WDRF 3 /* Watchdog Reset Flag */ |
| #define | MCUCR _SFR_IO8(0x35) |
| #define | IVCE 0 /* Interrupt Vector Change Enable */ |
| #define | IVSEL 1 /* Interrupt Vector Select */ |
| #define | PUD 4 /* Pull-up disable */ |
| #define | SPIPS 7 /* SPI Pin Select */ |
| #define | SPMCSR _SFR_IO8(0x37) |
| #define | SPMEN 0 /* Store Program Memory Enable */ |
| #define | PGERS 1 /* Page Erase */ |
| #define | PGWRT 2 /* Page Write */ |
| #define | BLBSET 3 /* Boot Lock Bit Set */ |
| #define | RWWSRE 4 /* Read While Write section read enable */ |
| #define | RWWSB 6 /* Read While Write Section Busy */ |
| #define | SPMIE 7 /* SPM Interrupt Enable */ |
| #define | WDTCSR _SFR_MEM8(0x60) |
| #define | WDP0 0 /* Watchdog Timer Prescaler bit0 */ |
| #define | WDP1 1 /* Watchdog Timer Prescaler bit1 */ |
| #define | WDP2 2 /* Watchdog Timer Prescaler bit2 */ |
| #define | WDE 3 /* Watchdog Enable */ |
| #define | WDCE 4 /* Watchdog Change Enable */ |
| #define | WDP3 5 /* Watchdog Timer Prescaler bit3 */ |
| #define | WDIE 6 /* Watchdog Timeout Interrupt Enable */ |
| #define | WDIF 7 /* Watchdog Timeout Interrupt Flag */ |
| #define | CLKPR _SFR_MEM8(0x61) |
| #define | CLKPS0 0 /* Clock Prescaler Select bit0 */ |
| #define | CLKPS1 1 /* Clock Prescaler Select bit1 */ |
| #define | CLKPS2 2 /* Clock Prescaler Select bit2 */ |
| #define | CLKPS3 3 /* Clock Prescaler Select bit3 */ |
| #define | CLKPCE 7 /* Clock Prescaler Change Enable */ |
| #define | PRR _SFR_MEM8(0x64) |
| #define | PRADC 0 /* Power Reduction ADC */ |
| #define | PRUSART 1 /* Power Reduction USART */ |
| #define | PRSPI 2 /* Power Reduction Serial Peripheral Interface */ |
| #define | PRTIM0 3 /* Power Reduction Timer/Counter0 */ |
| #define | PRTIM1 4 /* Power Reduction Timer/Counter1 */ |
| #define | PRPSC0 5 /* Power Reduction PSC0 */ |
| #define | PRPSC1 6 /* Power Reduction PSC1 */ |
| #define | PRPSC2 7 /* Power Reduction PSC2 */ |
| #define | OSCCAL _SFR_MEM8(0x66) |
| #define | CAL0 0 |
| #define | CAL1 1 |
| #define | CAL2 2 |
| #define | CAL3 3 |
| #define | CAL4 4 |
| #define | CAL5 5 |
| #define | CAL6 6 |
| #define | EICRA _SFR_MEM8(0x69) |
| #define | ISC00 0 |
| #define | ISC01 1 |
| #define | ISC10 2 |
| #define | ISC11 3 |
| #define | ISC20 4 |
| #define | ISC21 5 |
| #define | ISC30 6 |
| #define | ISC31 7 |
| #define | TIMSK0 _SFR_MEM8(0x6E) |
| #define | TOIE0 0 /* Overflow Interrupt Enable */ |
| #define | OCIE0A 1 /* Output Compare Match A Interrupt Enable */ |
| #define | OCIE0B 2 /* Output Compare Match B Interrupt Enable */ |
| #define | TIMSK1 _SFR_MEM8(0x6F) |
| #define | TOIE1 0 /* Overflow Interrupt Enable */ |
| #define | OCIE1A 1 /* Output Compare Match A Interrupt Enable */ |
| #define | OCIE1B 2 /* Output Compare Match B Interrupt Enable */ |
| #define | ICIE1 5 /* Input Capture Interrupt Enable */ |
| #define | AMP0CSR _SFR_MEM8(0x76) |
| #define | AMP0TS0 0 |
| #define | AMP0TS1 1 |
| #define | AMP0G0 4 |
| #define | AMP0G1 5 |
| #define | AMP0IS 6 |
| #define | AMP0EN 7 |
| #define | AMP1CSR _SFR_MEM8(0x77) |
| #define | AMP1TS0 0 |
| #define | AMP1TS1 1 |
| #define | AMP1G0 4 |
| #define | AMP1G1 5 |
| #define | AMP1IS 6 |
| #define | AMP1EN 7 |
| #define | ADC _SFR_MEM16(0x78) |
| #define | ADCW _SFR_MEM16(0x78) |
| #define | ADCL _SFR_MEM8(0x78) |
| #define | ADCH _SFR_MEM8(0x79) |
| #define | ADCSRA _SFR_MEM8(0x7A) |
| #define | ADPS0 0 /* ADC Prescaler Select bit0 */ |
| #define | ADPS1 1 /* ADC Prescaler Select bit1 */ |
| #define | ADPS2 2 /* ADC Prescaler Select bit2 */ |
| #define | ADIE 3 /* ADC Interrupt Enable */ |
| #define | ADIF 4 /* ADC Interrupt Flag */ |
| #define | ADATE 5 /* ADC Auto Trigger Enable */ |
| #define | ADSC 6 /* ADC Start Conversion */ |
| #define | ADEN 7 /* ADC Enable */ |
| #define | ADCSRB _SFR_MEM8(0x7B) |
| #define | ADTS0 0 /* ADC Auto Trigger Source 0 */ |
| #define | ADTS1 1 /* ADC Auto Trigger Source 1 */ |
| #define | ADTS2 2 /* ADC Auto Trigger Source 2 */ |
| #define | ADTS3 3 /* ADC Auto Trigger Source 3 */ |
| #define | ADHSM 7 /* ADC High Speed Mode */ |
| #define | ADMUX _SFR_MEM8(0x7C) |
| #define | MUX0 0 /* Analog Channel and Gain Selection bit0 */ |
| #define | MUX1 1 /* Analog Channel and Gain Selection bit1 */ |
| #define | MUX2 2 /* Analog Channel and Gain Selection bit2 */ |
| #define | MUX3 3 /* Analog Channel and Gain Selection bit3 */ |
| #define | ADLAR 5 /* Left Adjust Result */ |
| #define | REFS0 6 /* Reference Selection bit0 */ |
| #define | REFS1 7 /* Reference Selection bit1 */ |
| #define | DIDR0 _SFR_MEM8(0x7E) |
| #define | ADC0D 0 /* ADC0 Digital input Disable */ |
| #define | ADC1D 1 /* ADC1 Digital input Disable */ |
| #define | ADC2D 2 /* ADC2 Digital input Disable */ |
| #define | ADC3D 3 /* ADC3 Digital input Disable */ |
| #define | ADC4D 4 /* ADC4 Digital input Disable */ |
| #define | ADC5D 5 /* ADC5 Digital input Disable */ |
| #define | ADC6D 6 /* ADC6 Digital input Disable */ |
| #define | ADC7D 7 /* ADC7 Digital input Disable */ |
| #define | DIDR1 _SFR_MEM8(0x7F) |
| #define | ADC8D 0 /* ADC8 Digital input Disable */ |
| #define | ADC9D 1 /* ADC9 Digital input Disable */ |
| #define | ADC10D 2 /* ADC10 Digital input Disable */ |
| #define | AMP0ND 3 |
| #define | AMP0PD 4 |
| #define | ACMP0D 5 |
| #define | TCCR1A _SFR_MEM8(0x80) |
| #define | WGM10 0 /* Waveform Generation Mode */ |
| #define | WGM11 1 /* Waveform Generation Mode */ |
| #define | COM1B0 4 /* Compare Output Mode 1B, bit 0 */ |
| #define | COM1B1 5 /* Compare Output Mode 1B, bit 1 */ |
| #define | COM1A0 6 /* Comparet Ouput Mode 1A, bit 0 */ |
| #define | COM1A1 7 /* Comparet Ouput Mode 1A, bit 1 */ |
| #define | TCCR1B _SFR_MEM8(0x81) |
| #define | CS10 0 /* Prescaler source of Timer/Counter 1 */ |
| #define | CS11 1 /* Prescaler source of Timer/Counter 1 */ |
| #define | CS12 2 /* Prescaler source of Timer/Counter 1 */ |
| #define | WGM12 3 /* Waveform Generation Mode */ |
| #define | WGM13 4 /* Waveform Generation Mode */ |
| #define | ICES1 6 /* Input Capture 1 Edge Select */ |
| #define | ICNC1 7 /* Input Capture 1 Noise Canceler */ |
| #define | TCCR1C _SFR_MEM8(0x82) |
| #define | FOC1B 6 /* Force Output Compare for Channel B */ |
| #define | FOC1A 7 /* Force Output Compare for Channel A */ |
| #define | TCNT1 _SFR_MEM16(0x84) |
| #define | TCNT1L _SFR_MEM8(0x84) |
| #define | TCNT10 0 |
| #define | TCNT11 1 |
| #define | TCNT12 2 |
| #define | TCNT13 3 |
| #define | TCNT14 4 |
| #define | TCNT15 5 |
| #define | TCNT16 6 |
| #define | TCNT17 7 |
| #define | TCNT1H _SFR_MEM8(0x85) |
| #define | TCNT18 0 |
| #define | TCNT19 1 |
| #define | TCNT110 2 |
| #define | TCNT111 3 |
| #define | TCNT112 4 |
| #define | TCNT113 5 |
| #define | TCNT114 6 |
| #define | TCNT115 7 |
| #define | ICR1 _SFR_MEM16(0x86) |
| #define | ICR1L _SFR_MEM8(0x86) |
| #define | ICR17 7 |
| #define | ICR16 6 |
| #define | ICR15 5 |
| #define | ICR14 4 |
| #define | ICR13 3 |
| #define | ICR12 2 |
| #define | ICR11 1 |
| #define | ICR10 0 |
| #define | ICR1H _SFR_MEM8(0x87) |
| #define | ICR115 7 |
| #define | ICR114 6 |
| #define | ICR113 5 |
| #define | ICR112 4 |
| #define | ICR111 3 |
| #define | ICR110 2 |
| #define | ICR19 1 |
| #define | ICR18 0 |
| #define | OCR1A _SFR_MEM16(0x88) |
| #define | OCR1AL _SFR_MEM8(0x88) |
| #define | OCR1A0 0 |
| #define | OCR1A1 1 |
| #define | OCR1A2 2 |
| #define | OCR1A3 3 |
| #define | OCR1A4 4 |
| #define | OCR1A5 5 |
| #define | OCR1A6 6 |
| #define | OCR1A7 7 |
| #define | OCR1AH _SFR_MEM8(0x89) |
| #define | OCR1A8 0 |
| #define | OCR1A9 1 |
| #define | OCR1A10 2 |
| #define | OCR1A11 3 |
| #define | OCR1A12 4 |
| #define | OCR1A13 5 |
| #define | OCR1A14 6 |
| #define | OCR1A15 7 |
| #define | OCR1B _SFR_MEM16(0x8A) |
| #define | OCR1BL _SFR_MEM8(0x8A) |
| #define | OCR1B0 0 |
| #define | OCR1B1 1 |
| #define | OCR1B2 2 |
| #define | OCR1B3 3 |
| #define | OCR1B4 4 |
| #define | OCR1B5 5 |
| #define | OCR1B6 6 |
| #define | OCR1B7 7 |
| #define | OCR1BH _SFR_MEM8(0x8B) |
| #define | OCR1B8 0 |
| #define | OCR1B9 1 |
| #define | OCR1B10 2 |
| #define | OCR1B11 3 |
| #define | OCR1B12 4 |
| #define | OCR1B13 5 |
| #define | OCR1B14 6 |
| #define | OCR1B15 7 |
| #define | PIFR0 _SFR_MEM8(0xA0) |
| #define | PEOP0 0 /* End Of PSC0 Interrupt */ |
| #define | PRN00 1 /* PSC0 Ramp Number bit0 */ |
| #define | PRN01 2 /* PSC0 Ramp Number bit1 */ |
| #define | PEV0A 3 /* PSC0 External Event A Interrupt */ |
| #define | PEV0B 4 /* PSC0 External Event B Interrupt */ |
| #define | PSEI0 5 /* PSC0 Synchro Error Interrupt */ |
| #define | POAC0A 6 /* PSC0 Output A Activity */ |
| #define | POAC0B 7 /* PSC0 Output B Activity */ |
| #define | PIM0 _SFR_MEM8(0xA1) |
| #define | PEOPE0 0 /* PSC0 End Of Cycle Interrupt Enable */ |
| #define | PEVE0A 3 /* PSC0 External Event A Interrupt Enable */ |
| #define | PEVE0B 4 /* PSC0 External Event B Interrupt Enable */ |
| #define | PSEIE0 5 /* PSC0 Synchro Error Interrupt Enable */ |
| #define | PIFR1 _SFR_MEM8(0xA2) |
| #define | PIM1 _SFR_MEM8(0xA3) |
| #define | PIFR2 _SFR_MEM8(0xA4) |
| #define | PEOP2 0 /* End Of PSC2 Interrupt */ |
| #define | PRN20 1 /* PSC2 Ramp Number bit0 */ |
| #define | PRN21 2 /* PSC2 Ramp Number bit1 */ |
| #define | PEV2A 3 /* PSC2 External Event A Interrupt */ |
| #define | PEV2B 4 /* PSC2 External Event B Interrupt */ |
| #define | PSEI2 5 /* PSC2 Synchro Error Interrupt */ |
| #define | POAC2A 6 /* PSC2 Output A Activity */ |
| #define | POAC2B 7 /* PSC2 Output B Activity */ |
| #define | PIM2 _SFR_MEM8(0xA5) |
| #define | PEOPE2 0 /* PSC2 End Of Cycle Interrupt Enable */ |
| #define | PEVE2A 3 /* PSC2 External Event A Interrupt Enable */ |
| #define | PEVE2B 4 /* PSC2 External Event B Interrupt Enable */ |
| #define | PSEIE2 5 /* PSC2 Synchro Error Interrupt Enable */ |
| #define | DACON _SFR_MEM8(0xAA) |
| #define | DAEN 0 /* Digital to Analog Enable bit */ |
| #define | DAOE 1 /* Digital to Analog Output Enable bit */ |
| #define | DALA 2 /* Digital to Analog Left Adjust */ |
| #define | DATS0 4 /* DAC Trigger Selection bit0 */ |
| #define | DATS1 5 /* DAC Trigger Selection bit1 */ |
| #define | DATS2 6 /* DAC Trigger Selection bit2 */ |
| #define | DAATE 7 /* DAC Auto Trigger Enable bit */ |
| #define | DAC _SFR_MEM16(0xAB) |
| #define | DACL _SFR_MEM8(0xAB) |
| #define | DACH _SFR_MEM8(0xAC) |
| #define | AC0CON _SFR_MEM8(0xAD) |
| #define | AC0M0 0 /* Analog Comparator 0 Multiplexer register bit0 */ |
| #define | AC0M1 1 /* Analog Comparator 0 Multiplexer register bit1 */ |
| #define | AC0M2 2 /* Analog Comparator 0 Multiplexer register bit2 */ |
| #define | AC0IS0 4 /* Analog Comparator 0 Interrupt Select bit0 */ |
| #define | AC0IS1 5 /* Analog Comparator 0 Interrupt Select bit1 */ |
| #define | AC0IE 6 /* Analog Comparator 0 Interrupt Enable bit */ |
| #define | AC0EN 7 /* Analog Comparator 0 Enable Bit */ |
| #define | AC1CON _SFR_MEM8(0xAE) |
| #define | AC1M0 0 /* Analog Comparator 1 Multiplexer register bit0 */ |
| #define | AC1M1 1 /* Analog Comparator 1 Multiplexer register bit1 */ |
| #define | AC1M2 2 /* Analog Comparator 1 Multiplexer register bit2 */ |
| #define | AC1ICE 3 /* Analog Comparator 1 Interrupt Capture Enable bit */ |
| #define | AC1IS0 4 /* Analog Comparator 1 Interrupt Select bit0 */ |
| #define | AC1IS1 5 /* Analog Comparator 1 Interrupt Select bit1 */ |
| #define | AC1IE 6 /* Analog Comparator 1 Interrupt Enable bit */ |
| #define | AC1EN 7 /* Analog Comparator 1 Enable Bit */ |
| #define | AC2CON _SFR_MEM8(0xAF) |
| #define | AC2M0 0 /* Analog Comparator 2 Multiplexer register bit0 */ |
| #define | AC2M1 1 /* Analog Comparator 2 Multiplexer register bit1 */ |
| #define | AC2M2 2 /* Analog Comparator 2 Multiplexer register bit2 */ |
| #define | AC2IS0 4 /* Analog Comparator 2 Interrupt Select bit0 */ |
| #define | AC2IS1 5 /* Analog Comparator 2 Interrupt Select bit1 */ |
| #define | AC2IE 6 /* Analog Comparator 2 Interrupt Enable bit */ |
| #define | AC2EN 7 /* Analog Comparator 2 Enable Bit */ |
| #define | UCSRA _SFR_MEM8(0xC0) |
| #define | MPCM 0 /* Multi-processor Communication Mode */ |
| #define | U2X 1 /* Double the USART Transmission Speed */ |
| #define | UPE 2 /* USART Parity Error */ |
| #define | DOR 3 /* Data OverRun */ |
| #define | FE 4 /* Frame Error */ |
| #define | UDRE 5 /* USART Data Register Empty */ |
| #define | TXC 6 /* USART Transmit Complete */ |
| #define | RXC 7 /* USART Receive Complete */ |
| #define | UCSRB _SFR_MEM8(0xC1) |
| #define | TXB8 0 /* Transmit Data Bit 8 */ |
| #define | RXB8 1 /* Receive Data Bit 8 */ |
| #define | UCSZ2 2 /* Character Size */ |
| #define | TXEN 3 /* Transmitter Enable */ |
| #define | RXEN 4 /* Receiver Enable */ |
| #define | UDRIE 5 /* USART Data Register Empty Interrupt Enable */ |
| #define | TXCIE 6 /* TX Complete Interrupt Enable */ |
| #define | RXCIE 7 /* RX Complete Interrupt Enable */ |
| #define | UCSRC _SFR_MEM8(0xC2) |
| #define | UCPOL 0 /* Clock Polarity */ |
| #define | UCSZ0 1 /* Character Size bit0 */ |
| #define | UCSZ1 2 /* Character Size bit1 */ |
| #define | USBS 3 /* Stop Bit Select */ |
| #define | UPM0 4 /* Parity Mode bit0 */ |
| #define | UPM1 5 /* Parity Mode bit1 */ |
| #define | UMSEL 6 /* USART Mode Select */ |
| #define | UBRR _SFR_MEM16(0xC4) |
| #define | UBRRL _SFR_MEM8(0xC4) |
| #define | UBRRH _SFR_MEM8(0xC5) |
| #define | UDR _SFR_MEM8(0xC6) |
| #define | EUCSRA _SFR_MEM8(0xC8) |
| #define | URxS0 0 /* EUSART Receive Character Size bit0 */ |
| #define | URxS1 1 /* EUSART Receive Character Size bit1 */ |
| #define | URxS2 2 /* EUSART Receive Character Size bit2 */ |
| #define | URxS3 3 /* EUSART Receive Character Size bit3 */ |
| #define | UTxS0 4 /* EUSART Transmit Character Size bit0 */ |
| #define | UTxS1 5 /* EUSART Transmit Character Size bit1 */ |
| #define | UTxS2 6 /* EUSART Transmit Character Size bit2 */ |
| #define | UTxS3 7 /* EUSART Transmit Character Size bit3 */ |
| #define | EUCSRB _SFR_MEM8(0xC9) |
| #define | BODR 0 /* Bit Order */ |
| #define | EMCH 1 /* Manchester mode */ |
| #define | EUSBS 3 /* EUSBS Enable Bit */ |
| #define | EUSART 4 /* EUSART Enable Bit */ |
| #define | EUCSRC _SFR_MEM8(0xCA) |
| #define | STP0 0 /* Stop bits values bit0 */ |
| #define | STP1 1 /* Stop bits values bit1 */ |
| #define | F1617 2 |
| #define | FEM 3 /* Frame Error Manchester */ |
| #define | MUBRR _SFR_MEM16(0xCC) |
| #define | MUBRRL _SFR_MEM8(0xCC) |
| #define | MUBRRH _SFR_MEM8(0xCD) |
| #define | EUDR _SFR_MEM8(0xCE) |
| #define | PSOC0 _SFR_MEM8(0xD0) |
| #define | POEN0A 0 /* PSC 0 OUT Part A Output Enable */ |
| #define | POEN0B 2 /* PSC 0 OUT Part B Output Enable */ |
| #define | PSYNC00 4 /* Synchronization Out for ADC Selection bit0 */ |
| #define | PSYNC01 5 /* Synchronization Out for ADC Selection bit1 */ |
| #define | OCR0SA _SFR_MEM16(0xD2) |
| #define | OCR0SAL _SFR_MEM8(0xD2) |
| #define | OCR0SAH _SFR_MEM8(0xD3) |
| #define | OCR0RA _SFR_MEM16(0xD4) |
| #define | OCR0RAL _SFR_MEM8(0xD4) |
| #define | OCR0RAH _SFR_MEM8(0xD5) |
| #define | OCR0SB _SFR_MEM16(0xD6) |
| #define | OCR0SBL _SFR_MEM8(0xD6) |
| #define | OCR0SBH _SFR_MEM8(0xD7) |
| #define | OCR0RB _SFR_MEM16(0xD8) |
| #define | OCR0RBL _SFR_MEM8(0xD8) |
| #define | OCR0RBH _SFR_MEM8(0xD9) |
| #define | PCNF0 _SFR_MEM8(0xDA) |
| #define | PCLKSEL0 1 /* PSC 0 Input Clock Select */ |
| #define | POP0 2 /* PSC 0 Output Polarity */ |
| #define | PMODE00 3 /* PSC 0 Mode bit0 */ |
| #define | PMODE01 4 /* PSC 0 Mode bit1 */ |
| #define | PLOCK0 5 /* PSC 0 Lock */ |
| #define | PALOCK0 6 /* PSC 0 Autolock */ |
| #define | PFIFTY0 7 /* PSC 0 Fifty */ |
| #define | PCTL0 _SFR_MEM8(0xDB) |
| #define | PRUN0 0 /* PSC 0 Run */ |
| #define | PCCYC0 1 /* PSC 0 Complete Cycle */ |
| #define | PARUN0 2 /* PSC 0 Autorun */ |
| #define | PAOC0A 3 /* PSC 0 Asynchronous Output Control A */ |
| #define | PAOC0B 4 /* PSC 0 Asynchronous Output Control B */ |
| #define | PBFM0 5 /* Balance Flank Width Modulation */ |
| #define | PPRE00 6 /* PSC 0 Prescaler Select bit0 */ |
| #define | PPRE01 7 /* PSC 0 Prescaler Select bit1 */ |
| #define | PFRC0A _SFR_MEM8(0xDC) |
| #define | PRFM0A0 0 /* PSC 0 Fault Mode bit0 */ |
| #define | PRFM0A1 1 /* PSC 0 Fault Mode bit1 */ |
| #define | PRFM0A2 2 /* PSC 0 Fault Mode bit2 */ |
| #define | PRFM0A3 3 /* PSC 0 Fault Mode bit3 */ |
| #define | PFLTE0A 4 /* PSC 0 Filter Enable on Input Part A */ |
| #define | PELEV0A 5 /* PSC 0 Edge Level Selector of Input Part A */ |
| #define | PISEL0A 6 /* PSC 0 Input Select for Part A */ |
| #define | PCAE0A 7 /* PSC 0 Capture Enable Input Part A */ |
| #define | PFRC0B _SFR_MEM8(0xDD) |
| #define | PRFM0B0 0 /* PSC 0 Fault Mode bit0 */ |
| #define | PRFM0B1 1 /* PSC 0 Fault Mode bit1 */ |
| #define | PRFM0B2 2 /* PSC 0 Fault Mode bit2 */ |
| #define | PRFM0B3 3 /* PSC 0 Fault Mode bit3 */ |
| #define | PFLTE0B 4 /* PSC 0 Filter Enable on Input Part B */ |
| #define | PELEV0B 5 /* PSC 0 Edge Level Selector of Input Part B */ |
| #define | PISEL0B 6 /* PSC 0 Input Select for Part B */ |
| #define | PCAE0B 7 /* PSC 0 Capture Enable Input Part B */ |
| #define | PICR0 _SFR_MEM16(0xDE) |
| #define | PICR0L _SFR_MEM8(0xDE) |
| #define | PICR0H _SFR_MEM8(0xDF) |
| #define | PCST0 7 /* PSC Capture Software Trig bit */ |
| #define | PSOC1 _SFR_MEM8(0xE0) |
| #define | OCR1SA _SFR_MEM16(0xE2) |
| #define | OCR1SAL _SFR_MEM8(0xE2) |
| #define | OCR1SAH _SFR_MEM8(0xE3) |
| #define | OCR1RA _SFR_MEM16(0xE4) |
| #define | OCR1RAL _SFR_MEM8(0xE4) |
| #define | OCR1RAH _SFR_MEM8(0xE5) |
| #define | OCR1SB _SFR_MEM16(0xE6) |
| #define | OCR1SBL _SFR_MEM8(0xE6) |
| #define | OCR1SBH _SFR_MEM8(0xE7) |
| #define | OCR1RB _SFR_MEM16(0xE8) |
| #define | OCR1RBL _SFR_MEM8(0xE8) |
| #define | OCR1RBH _SFR_MEM8(0xE9) |
| #define | PCNF1 _SFR_MEM8(0xEA) |
| #define | PCTL1 _SFR_MEM8(0xEB) |
| #define | PFRC1A _SFR_MEM8(0xEC) |
| #define | PFRC1B _SFR_MEM8(0xED) |
| #define | PICR1 _SFR_MEM16(0xEE) |
| #define | PICR1L _SFR_MEM8(0xEE) |
| #define | PICR1H _SFR_MEM8(0xEF) |
| #define | PSOC2 _SFR_MEM8(0xF0) |
| #define | POEN2A 0 /* PSC 2 OUT Part A Output Enable */ |
| #define | POEN2C 1 /* PSCOUT22 Output Enable */ |
| #define | POEN2B 2 /* PSC 2 OUT Part B Output Enable */ |
| #define | POEN2D 3 /* PSCOUT23 Output Enable */ |
| #define | PSYNC20 4 /* Synchronization Out for ADC Selection bit0 */ |
| #define | PSYNC21 5 /* Synchronization Out for ADC Selection bit1 */ |
| #define | POS22 6 /* PSCOUT22 Selection */ |
| #define | POS23 7 /* PSCOUT23 Selection */ |
| #define | POM2 _SFR_MEM8(0xF1) |
| #define | POMV2A0 0 /* Output Matrix Output A Ramp 0 */ |
| #define | POMV2A1 1 /* Output Matrix Output A Ramp 1 */ |
| #define | POMV2A2 2 /* Output Matrix Output A Ramp 2 */ |
| #define | POMV2A3 3 /* Output Matrix Output A Ramp 3 */ |
| #define | POMV2B0 4 /* Output Matrix Output B Ramp 0 */ |
| #define | POMV2B1 5 /* Output Matrix Output B Ramp 1 */ |
| #define | POMV2B2 6 /* Output Matrix Output B Ramp 2 */ |
| #define | POMV2B3 7 /* Output Matrix Output B Ramp 3 */ |
| #define | OCR2SA _SFR_MEM16(0xF2) |
| #define | OCR2SAL _SFR_MEM8(0xF2) |
| #define | OCR2SAH _SFR_MEM8(0xF3) |
| #define | OCR2RA _SFR_MEM16(0xF4) |
| #define | OCR2RAL _SFR_MEM8(0xF4) |
| #define | OCR2RAH _SFR_MEM8(0xF5) |
| #define | OCR2SB _SFR_MEM16(0xF6) |
| #define | OCR2SBL _SFR_MEM8(0xF6) |
| #define | OCR2SBH _SFR_MEM8(0xF7) |
| #define | OCR2RB _SFR_MEM16(0xF8) |
| #define | OCR2RBL _SFR_MEM8(0xF8) |
| #define | OCR2RBH _SFR_MEM8(0xF9) |
| #define | PCNF2 _SFR_MEM8(0xFA) |
| #define | POME2 0 /* PSC 2 Output Matrix Enable */ |
| #define | PCLKSEL2 1 /* PSC 2 Input Clock Select */ |
| #define | POP2 2 /* PSC 2 Output Polarity */ |
| #define | PMODE20 3 /* PSC 2 Mode bit0 */ |
| #define | PMODE21 4 /* PSC 2 Mode bit1 */ |
| #define | PLOCK2 5 /* PSC 2 Lock */ |
| #define | PALOCK2 6 /* PSC 2 Autolock */ |
| #define | PFIFTY2 7 /* PSC 2 Fifty */ |
| #define | PCTL2 _SFR_MEM8(0xFB) |
| #define | PRUN2 0 /* PSC 2 Run */ |
| #define | PCCYC2 1 /* PSC 2 Complete Cycle */ |
| #define | PARUN2 2 /* PSC 2 Autorun */ |
| #define | PAOC2A 3 /* PSC 2 Asynchronous Output Control A */ |
| #define | PAOC2B 4 /* PSC 2 Asynchronous Output Control B */ |
| #define | PBFM2 5 /* Balance Flank Width Modulation */ |
| #define | PPRE20 6 /* PSC 2 Prescaler Select bit0 */ |
| #define | PPRE21 7 /* PSC 2 Prescaler Select bit1 */ |
| #define | PFRC2A _SFR_MEM8(0xFC) |
| #define | PRFM2A0 0 /* PSC 2 Fault Mode bit0 */ |
| #define | PRFM2A1 1 /* PSC 2 Fault Mode bit1 */ |
| #define | PRFM2A2 2 /* PSC 2 Fault Mode bit2 */ |
| #define | PRFM2A3 3 /* PSC 2 Fault Mode bit3 */ |
| #define | PFLTE2A 4 /* PSC 2 Filter Enable on Input Part A */ |
| #define | PELEV2A 5 /* PSC 2 Edge Level Selector of Input Part A */ |
| #define | PISEL2A 6 /* PSC 2 Input Select for Part A */ |
| #define | PCAE2A 7 /* PSC 2 Capture Enable Input Part A */ |
| #define | PFRC2B _SFR_MEM8(0xFD) |
| #define | PRFM2B0 0 /* PSC 2 Fault Mode bit0 */ |
| #define | PRFM2B1 1 /* PSC 2 Fault Mode bit1 */ |
| #define | PRFM2B2 2 /* PSC 2 Fault Mode bit2 */ |
| #define | PRFM2B3 3 /* PSC 2 Fault Mode bit3 */ |
| #define | PFLTE2B 4 /* PSC 2 Filter Enable on Input Part B */ |
| #define | PELEV2B 5 /* PSC 2 Edge Level Selector of Input Part B */ |
| #define | PISEL2B 6 /* PSC 2 Input Select for Part B */ |
| #define | PCAE2B 7 /* PSC 2 Capture Enable Input Part B */ |
| #define | PICR2 _SFR_MEM16(0xFE) |
| #define | PICR2L _SFR_MEM8(0xFE) |
| #define | PICR2H _SFR_MEM8(0xFF) |
| #define | PCST2 7 /* PSC Capture Software Trig bit */ |
| #define | PSC2_CAPT_vect _VECTOR(1) |
| #define | PSC2_EC_vect _VECTOR(2) |
| #define | PSC1_CAPT_vect _VECTOR(3) |
| #define | PSC1_EC_vect _VECTOR(4) |
| #define | PSC0_CAPT_vect _VECTOR(5) |
| #define | PSC0_EC_vect _VECTOR(6) |
| #define | ANALOG_COMP_0_vect _VECTOR(7) |
| #define | ANALOG_COMP_1_vect _VECTOR(8) |
| #define | ANALOG_COMP_2_vect _VECTOR(9) |
| #define | INT0_vect _VECTOR(10) |
| #define | TIMER1_CAPT_vect _VECTOR(11) |
| #define | TIMER1_COMPA_vect _VECTOR(12) |
| #define | TIMER1_COMPB_vect _VECTOR(13) |
| #define | TIMER1_OVF_vect _VECTOR(15) |
| #define | TIMER0_COMP_A_vect _VECTOR(16) |
| #define | TIMER0_OVF_vect _VECTOR(17) |
| #define | ADC_vect _VECTOR(18) |
| #define | INT1_vect _VECTOR(19) |
| #define | SPI_STC_vect _VECTOR(20) |
| #define | USART_RX_vect _VECTOR(21) |
| #define | USART_UDRE_vect _VECTOR(22) |
| #define | USART_TX_vect _VECTOR(23) |
| #define | INT2_vect _VECTOR(24) |
| #define | WDT_vect _VECTOR(25) |
| #define | EE_READY_vect _VECTOR(26) |
| #define | TIMER0_COMPB_vect _VECTOR(27) |
| #define | INT3_vect _VECTOR(28) |
| #define | SPM_READY_vect _VECTOR(31) |
| #define | _VECTORS_SIZE (4 * 32) |
| #define | RAMEND 0x4FF |
| #define | XRAMSIZE 0 |
| #define | XRAMEND RAMEND |
| #define | E2END 0x1FF |
| #define | E2PAGESIZE 4 |
| #define | FLASHEND 0x3FFF |
| #define | SPM_PAGESIZE 128 |
| #define | FUSE_MEMORY_SIZE 3 |
| #define | FUSE_CKSEL0 (unsigned char)~_BV(0) /* Select Clock Source */ |
| #define | FUSE_CKSEL1 (unsigned char)~_BV(1) /* Select Clock Source */ |
| #define | FUSE_CKSEL2 (unsigned char)~_BV(2) /* Select Clock Source */ |
| #define | FUSE_CKSEL3 (unsigned char)~_BV(3) /* Select Clock Source */ |
| #define | FUSE_SUT0 (unsigned char)~_BV(4) /* Select start-up time */ |
| #define | FUSE_SUT1 (unsigned char)~_BV(5) /* Select start-up time */ |
| #define | FUSE_CKOUT (unsigned char)~_BV(6) /* Oscillator output option */ |
| #define | FUSE_CKDIV8 (unsigned char)~_BV(7) /* Divide clock by 8 */ |
| #define | LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8) |
| #define | FUSE_BODLEVEL0 (unsigned char)~_BV(0) |
| #define | FUSE_BODLEVEL1 (unsigned char)~_BV(1) |
| #define | FUSE_BODLEVEL2 (unsigned char)~_BV(2) |
| #define | FUSE_EESAVE (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */ |
| #define | FUSE_WDTON (unsigned char)~_BV(4) /* Watchdog timer always on */ |
| #define | FUSE_SPIEN (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */ |
| #define | FUSE_DWEN (unsigned char)~_BV(6) /* debugWIRE Enable */ |
| #define | FUSE_RSTDISBL (unsigned char)~_BV(7) /* External Reset Diasble */ |
| #define | HFUSE_DEFAULT (FUSE_SPIEN) |
| #define | FUSE_BOOTRST (unsigned char)~_BV(0) /* Select Reset Vector */ |
| #define | FUSE_BOOTSZ0 (unsigned char)~_BV(1) /* Select Boot Size */ |
| #define | FUSE_BOOTSZ1 (unsigned char)~_BV(2) /* Select Boot Size */ |
| #define | FUSE_PSCRV (unsigned char)~_BV(4) |
| #define | FUSE_PSC0RB (unsigned char)~_BV(5) |
| #define | FUSE_PSC1RB (unsigned char)~_BV(6) |
| #define | FUSE_PSC2RB (unsigned char)~_BV(7) |
| #define | EFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1) |
| #define | __LOCK_BITS_EXIST |
| #define | __BOOT_LOCK_BITS_0_EXIST |
| #define | __BOOT_LOCK_BITS_1_EXIST |
| #define | SIGNATURE_0 0x1E |
| #define | SIGNATURE_1 0x94 |
| #define | SIGNATURE_2 0x83 |
This file should only be included from <avr/io.h>, never directly.
