score
cpu
avr
avr
io8515.h
1
/* Copyright (c) 2002, Marek Michalkiewicz
2
All rights reserved.
3
4
Redistribution and use in source and binary forms, with or without
5
modification, are permitted provided that the following conditions are met:
6
7
* Redistributions of source code must retain the above copyright
8
notice, this list of conditions and the following disclaimer.
9
10
* Redistributions in binary form must reproduce the above copyright
11
notice, this list of conditions and the following disclaimer in
12
the documentation and/or other materials provided with the
13
distribution.
14
15
* Neither the name of the copyright holders nor the names of
16
contributors may be used to endorse or promote products derived
17
from this software without specific prior written permission.
18
19
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
20
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
23
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
24
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
25
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
26
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
27
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
28
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
29
POSSIBILITY OF SUCH DAMAGE. */
30
31
32
/* avr/io8515.h - definitions for AT90S8515 */
33
34
#ifndef _AVR_IO8515_H_
35
#define _AVR_IO8515_H_ 1
36
37
/* This file should only be included from <avr/io.h>, never directly. */
38
39
#ifndef _AVR_IO_H_
40
# error "Include <avr/io.h> instead of this file."
41
#endif
42
43
#ifndef _AVR_IOXXX_H_
44
# define _AVR_IOXXX_H_ "io8515.h"
45
#else
46
# error "Attempt to include more than one <avr/ioXXX.h> file."
47
#endif
48
49
/* I/O registers */
50
51
/* Analog Comparator Control and Status Register */
52
#define ACSR _SFR_IO8(0x08)
53
54
/* UART Baud Rate Register */
55
#define UBRR _SFR_IO8(0x09)
56
57
/* UART Control Register */
58
#define UCR _SFR_IO8(0x0A)
59
60
/* UART Status Register */
61
#define USR _SFR_IO8(0x0B)
62
63
/* UART I/O Data Register */
64
#define UDR _SFR_IO8(0x0C)
65
66
/* SPI Control Register */
67
#define SPCR _SFR_IO8(0x0D)
68
69
/* SPI Status Register */
70
#define SPSR _SFR_IO8(0x0E)
71
72
/* SPI I/O Data Register */
73
#define SPDR _SFR_IO8(0x0F)
74
75
/* Input Pins, Port D */
76
#define PIND _SFR_IO8(0x10)
77
78
/* Data Direction Register, Port D */
79
#define DDRD _SFR_IO8(0x11)
80
81
/* Data Register, Port D */
82
#define PORTD _SFR_IO8(0x12)
83
84
/* Input Pins, Port C */
85
#define PINC _SFR_IO8(0x13)
86
87
/* Data Direction Register, Port C */
88
#define DDRC _SFR_IO8(0x14)
89
90
/* Data Register, Port C */
91
#define PORTC _SFR_IO8(0x15)
92
93
/* Input Pins, Port B */
94
#define PINB _SFR_IO8(0x16)
95
96
/* Data Direction Register, Port B */
97
#define DDRB _SFR_IO8(0x17)
98
99
/* Data Register, Port B */
100
#define PORTB _SFR_IO8(0x18)
101
102
/* Input Pins, Port A */
103
#define PINA _SFR_IO8(0x19)
104
105
/* Data Direction Register, Port A */
106
#define DDRA _SFR_IO8(0x1A)
107
108
/* Data Register, Port A */
109
#define PORTA _SFR_IO8(0x1B)
110
111
/* EEPROM Control Register */
112
#define EECR _SFR_IO8(0x1C)
113
114
/* EEPROM Data Register */
115
#define EEDR _SFR_IO8(0x1D)
116
117
/* EEPROM Address Register */
118
#define EEAR _SFR_IO16(0x1E)
119
#define EEARL _SFR_IO8(0x1E)
120
#define EEARH _SFR_IO8(0x1F)
121
122
/* Watchdog Timer Control Register */
123
#define WDTCR _SFR_IO8(0x21)
124
125
/* T/C 1 Input Capture Register */
126
#define ICR1 _SFR_IO16(0x24)
127
#define ICR1L _SFR_IO8(0x24)
128
#define ICR1H _SFR_IO8(0x25)
129
130
/* Timer/Counter1 Output Compare Register B */
131
#define OCR1B _SFR_IO16(0x28)
132
#define OCR1BL _SFR_IO8(0x28)
133
#define OCR1BH _SFR_IO8(0x29)
134
135
/* Timer/Counter1 Output Compare Register A */
136
#define OCR1A _SFR_IO16(0x2A)
137
#define OCR1AL _SFR_IO8(0x2A)
138
#define OCR1AH _SFR_IO8(0x2B)
139
140
/* Timer/Counter 1 */
141
#define TCNT1 _SFR_IO16(0x2C)
142
#define TCNT1L _SFR_IO8(0x2C)
143
#define TCNT1H _SFR_IO8(0x2D)
144
145
/* Timer/Counter 1 Control and Status Register */
146
#define TCCR1B _SFR_IO8(0x2E)
147
148
/* Timer/Counter 1 Control Register */
149
#define TCCR1A _SFR_IO8(0x2F)
150
151
/* Timer/Counter 0 */
152
#define TCNT0 _SFR_IO8(0x32)
153
154
/* Timer/Counter 0 Control Register */
155
#define TCCR0 _SFR_IO8(0x33)
156
157
/* MCU general Control Register */
158
#define MCUCR _SFR_IO8(0x35)
159
160
/* Timer/Counter Interrupt Flag register */
161
#define TIFR _SFR_IO8(0x38)
162
163
/* Timer/Counter Interrupt MaSK register */
164
#define TIMSK _SFR_IO8(0x39)
165
166
/* General Interrupt Flag Register */
167
#define GIFR _SFR_IO8(0x3A)
168
169
/* General Interrupt MaSK register */
170
#define GIMSK _SFR_IO8(0x3B)
171
172
/* 0x3D..0x3E SP */
173
174
/* 0x3F SREG */
175
176
/* Interrupt vectors */
177
178
/* External Interrupt Request 0 */
179
#define INT0_vect _VECTOR(1)
180
#define SIG_INTERRUPT0 _VECTOR(1)
181
182
/* External Interrupt Request 1 */
183
#define INT1_vect _VECTOR(2)
184
#define SIG_INTERRUPT1 _VECTOR(2)
185
186
/* Timer/Counter Capture Event */
187
#define TIMER1_CAPT_vect _VECTOR(3)
188
#define SIG_INPUT_CAPTURE1 _VECTOR(3)
189
190
/* Timer/Counter1 Compare Match A */
191
#define TIMER1_COMPA_vect _VECTOR(4)
192
#define SIG_OUTPUT_COMPARE1A _VECTOR(4)
193
194
/* Timer/Counter1 Compare MatchB */
195
#define TIMER1_COMPB_vect _VECTOR(5)
196
#define SIG_OUTPUT_COMPARE1B _VECTOR(5)
197
198
/* Timer/Counter1 Overflow */
199
#define TIMER1_OVF_vect _VECTOR(6)
200
#define SIG_OVERFLOW1 _VECTOR(6)
201
202
/* Timer/Counter0 Overflow */
203
#define TIMER0_OVF_vect _VECTOR(7)
204
#define SIG_OVERFLOW0 _VECTOR(7)
205
206
/* Serial Transfer Complete */
207
#define SPI_STC_vect _VECTOR(8)
208
#define SIG_SPI _VECTOR(8)
209
210
/* UART, Rx Complete */
211
#define UART_RX_vect _VECTOR(9)
212
#define SIG_UART_RECV _VECTOR(9)
213
214
/* UART Data Register Empty */
215
#define UART_UDRE_vect _VECTOR(10)
216
#define SIG_UART_DATA _VECTOR(10)
217
218
/* UART, Tx Complete */
219
#define UART_TX_vect _VECTOR(11)
220
#define SIG_UART_TRANS _VECTOR(11)
221
222
/* Analog Comparator */
223
#define ANA_COMP_vect _VECTOR(12)
224
#define SIG_COMPARATOR _VECTOR(12)
225
226
#define _VECTORS_SIZE 26
227
228
229
The Register Bit names are represented by their bit number (0-7).
230
231
232
233
#define INT1 7
234
#define INT0 6
235
236
237
#define INTF1 7
238
#define INTF0 6
239
240
241
#define TOIE1 7
242
#define OCIE1A 6
243
#define OCIE1B 5
244
#define TICIE1 3
245
#define TOIE0 1
246
247
248
#define TOV1 7
249
#define OCF1A 6
250
#define OCF1B 5
251
#define ICF1 3
252
#define TOV0 1
253
254
255
#define SRE 7
256
#define SRW 6
257
#define SE 5
258
#define SM 4
259
#define ISC11 3
260
#define ISC10 2
261
#define ISC01 1
262
#define ISC00 0
263
264
265
#define CS02 2
266
#define CS01 1
267
#define CS00 0
268
269
270
#define COM1A1 7
271
#define COM1A0 6
272
#define COM1B1 5
273
#define COM1B0 4
274
#define PWM11 1
275
#define PWM10 0
276
277
278
#define ICNC1 7
279
#define ICES1 6
280
#define CTC1 3
281
#define CS12 2
282
#define CS11 1
283
#define CS10 0
284
285
286
#define WDTOE 4
287
#define WDE 3
288
#define WDP2 2
289
#define WDP1 1
290
#define WDP0 0
291
292
293
#define PA7 7
294
#define PA6 6
295
#define PA5 5
296
#define PA4 4
297
#define PA3 3
298
#define PA2 2
299
#define PA1 1
300
#define PA0 0
301
302
303
#define DDA7 7
304
#define DDA6 6
305
#define DDA5 5
306
#define DDA4 4
307
#define DDA3 3
308
#define DDA2 2
309
#define DDA1 1
310
#define DDA0 0
311
312
313
#define PINA7 7
314
#define PINA6 6
315
#define PINA5 5
316
#define PINA4 4
317
#define PINA3 3
318
#define PINA2 2
319
#define PINA1 1
320
#define PINA0 0
321
322
323
#define PB7 7
324
#define PB6 6
325
#define PB5 5
326
#define PB4 4
327
#define PB3 3
328
#define PB2 2
329
#define PB1 1
330
#define PB0 0
331
332
333
#define DDB7 7
334
#define DDB6 6
335
#define DDB5 5
336
#define DDB4 4
337
#define DDB3 3
338
#define DDB2 2
339
#define DDB1 1
340
#define DDB0 0
341
342
343
#define PINB7 7
344
#define PINB6 6
345
#define PINB5 5
346
#define PINB4 4
347
#define PINB3 3
348
#define PINB2 2
349
#define PINB1 1
350
#define PINB0 0
351
352
353
#define PC7 7
354
#define PC6 6
355
#define PC5 5
356
#define PC4 4
357
#define PC3 3
358
#define PC2 2
359
#define PC1 1
360
#define PC0 0
361
362
363
#define DDC7 7
364
#define DDC6 6
365
#define DDC5 5
366
#define DDC4 4
367
#define DDC3 3
368
#define DDC2 2
369
#define DDC1 1
370
#define DDC0 0
371
372
373
#define PINC7 7
374
#define PINC6 6
375
#define PINC5 5
376
#define PINC4 4
377
#define PINC3 3
378
#define PINC2 2
379
#define PINC1 1
380
#define PINC0 0
381
382
383
#define PD7 7
384
#define PD6 6
385
#define PD5 5
386
#define PD4 4
387
#define PD3 3
388
#define PD2 2
389
#define PD1 1
390
#define PD0 0
391
392
393
#define DDD7 7
394
#define DDD6 6
395
#define DDD5 5
396
#define DDD4 4
397
#define DDD3 3
398
#define DDD2 2
399
#define DDD1 1
400
#define DDD0 0
401
402
403
#define PIND7 7
404
#define PIND6 6
405
#define PIND5 5
406
#define PIND4 4
407
#define PIND3 3
408
#define PIND2 2
409
#define PIND1 1
410
#define PIND0 0
411
412
413
#define SPIF 7
414
#define WCOL 6
415
416
417
#define SPIE 7
418
#define SPE 6
419
#define DORD 5
420
#define MSTR 4
421
#define CPOL 3
422
#define CPHA 2
423
#define SPR1 1
424
#define SPR0 0
425
426
427
#define RXC 7
428
#define TXC 6
429
#define UDRE 5
430
#define FE 4
431
#define DOR 3
432
433
434
#define RXCIE 7
435
#define TXCIE 6
436
#define UDRIE 5
437
#define RXEN 4
438
#define TXEN 3
439
#define CHR9 2
440
#define RXB8 1
441
#define TXB8 0
442
443
444
#define ACD 7
445
#define ACO 5
446
#define ACI 4
447
#define ACIE 3
448
#define ACIC 2
449
#define ACIS1 1
450
#define ACIS0 0
451
452
453
#define EERIE 3
454
#define EEMWE 2
455
#define EEWE 1
456
#define EERE 0
457
458
/* Constants */
459
#define RAMEND 0x25F
/* Last On-Chip SRAM Location */
460
#define XRAMEND 0xFFFF
461
#define E2END 0x1FF
462
#define E2PAGESIZE 0
463
#define FLASHEND 0x1FFF
464
465
466
/* Fuses */
467
#define FUSE_MEMORY_SIZE 1
468
469
/* Low Fuse Byte */
470
#define FUSE_SPIEN ~_BV(1)
/* Serial Program Downloading Enabled */
471
#define FUSE_FSTRT ~_BV(2)
/* Short Start-up time selected */
472
#define LFUSE_DEFAULT (0xFF)
473
474
475
/* Lock Bits */
476
#define __LOCK_BITS_EXIST
477
478
479
/* Signature */
480
#define SIGNATURE_0 0x1E
481
#define SIGNATURE_1 0x93
482
#define SIGNATURE_2 0x01
483
484
485
#endif
/* _AVR_IO8515_H_ */
