| #define | _AVR_IOXXX_H_ "io2313.h" |
| #define | ACSR _SFR_IO8(0x08) |
| #define | UBRR _SFR_IO8(0x09) |
| #define | UCR _SFR_IO8(0x0A) |
| #define | USR _SFR_IO8(0x0B) |
| #define | UDR _SFR_IO8(0x0C) |
| #define | PIND _SFR_IO8(0x10) |
| #define | DDRD _SFR_IO8(0x11) |
| #define | PORTD _SFR_IO8(0x12) |
| #define | PINB _SFR_IO8(0x16) |
| #define | DDRB _SFR_IO8(0x17) |
| #define | PORTB _SFR_IO8(0x18) |
| #define | EECR _SFR_IO8(0x1C) |
| #define | EEDR _SFR_IO8(0x1D) |
| #define | EEAR _SFR_IO8(0x1E) |
| #define | EEARL _SFR_IO8(0x1E) |
| #define | WDTCR _SFR_IO8(0x21) |
| #define | ICR1 _SFR_IO16(0x24) |
| #define | ICR1L _SFR_IO8(0x24) |
| #define | ICR1H _SFR_IO8(0x25) |
| #define | OCR1 _SFR_IO16(0x2A) |
| #define | OCR1L _SFR_IO8(0x2A) |
| #define | OCR1H _SFR_IO8(0x2B) |
| #define | OCR1A _SFR_IO16(0x2A) |
| #define | OCR1AL _SFR_IO8(0x2A) |
| #define | OCR1AH _SFR_IO8(0x2B) |
| #define | TCNT1 _SFR_IO16(0x2C) |
| #define | TCNT1L _SFR_IO8(0x2C) |
| #define | TCNT1H _SFR_IO8(0x2D) |
| #define | TCCR1B _SFR_IO8(0x2E) |
| #define | TCCR1A _SFR_IO8(0x2F) |
| #define | TCNT0 _SFR_IO8(0x32) |
| #define | TCCR0 _SFR_IO8(0x33) |
| #define | MCUCR _SFR_IO8(0x35) |
| #define | TIFR _SFR_IO8(0x38) |
| #define | TIMSK _SFR_IO8(0x39) |
| #define | GIFR _SFR_IO8(0x3A) |
| #define | GIMSK _SFR_IO8(0x3B) |
| #define | INT0_vect _VECTOR(1) |
| #define | SIG_INTERRUPT0 _VECTOR(1) |
| #define | INT1_vect _VECTOR(2) |
| #define | SIG_INTERRUPT1 _VECTOR(2) |
| #define | TIMER1_CAPT1_vect _VECTOR(3) |
| #define | SIG_INPUT_CAPTURE1 _VECTOR(3) |
| #define | TIMER1_COMP1_vect _VECTOR(4) |
| #define | SIG_OUTPUT_COMPARE1A _VECTOR(4) |
| #define | TIMER1_OVF1_vect _VECTOR(5) |
| #define | SIG_OVERFLOW1 _VECTOR(5) |
| #define | TIMER0_OVF0_vect _VECTOR(6) |
| #define | SIG_OVERFLOW0 _VECTOR(6) |
| #define | UART_RX_vect _VECTOR(7) |
| #define | SIG_UART_RECV _VECTOR(7) |
| #define | UART_UDRE_vect _VECTOR(8) |
| #define | SIG_UART_DATA _VECTOR(8) |
| #define | UART_TX_vect _VECTOR(9) |
| #define | SIG_UART_TRANS _VECTOR(9) |
| #define | ANA_COMP_vect _VECTOR(10) |
| #define | SIG_COMPARATOR _VECTOR(10) |
| #define | _VECTORS_SIZE 22 |
| #define | INT1 7 |
| #define | INT0 6 |
| #define | INTF1 7 |
| #define | INTF0 6 |
| #define | TOIE1 7 |
| #define | OCIE1A 6 |
| #define | TICIE 3 /* old name */ |
| #define | TICIE1 3 |
| #define | TOIE0 1 |
| #define | TOV1 7 |
| #define | OCF1A 6 |
| #define | ICF1 3 |
| #define | TOV0 1 |
| #define | SE 5 |
| #define | SM 4 |
| #define | ISC11 3 |
| #define | ISC10 2 |
| #define | ISC01 1 |
| #define | ISC00 0 |
| #define | CS02 2 |
| #define | CS01 1 |
| #define | CS00 0 |
| #define | COM1A1 7 |
| #define | COM1A0 6 |
| #define | PWM11 1 |
| #define | PWM10 0 |
| #define | ICNC1 7 |
| #define | ICES1 6 |
| #define | CTC1 3 |
| #define | CS12 2 |
| #define | CS11 1 |
| #define | CS10 0 |
| #define | WDTOE 4 |
| #define | WDE 3 |
| #define | WDP2 2 |
| #define | WDP1 1 |
| #define | WDP0 0 |
| #define | EEMWE 2 |
| #define | EEWE 1 |
| #define | EERE 0 |
| #define | PB7 7 |
| #define | PB6 6 |
| #define | PB5 5 |
| #define | PB4 4 |
| #define | PB3 3 |
| #define | PB2 2 |
| #define | PB1 1 |
| #define | PB0 0 |
| #define | DDB7 7 |
| #define | DDB6 6 |
| #define | DDB5 5 |
| #define | DDB4 4 |
| #define | DDB3 3 |
| #define | DDB2 2 |
| #define | DDB1 1 |
| #define | DDB0 0 |
| #define | PINB7 7 |
| #define | PINB6 6 |
| #define | PINB5 5 |
| #define | PINB4 4 |
| #define | PINB3 3 |
| #define | PINB2 2 |
| #define | PINB1 1 |
| #define | PINB0 0 |
| #define | PD6 6 |
| #define | PD5 5 |
| #define | PD4 4 |
| #define | PD3 3 |
| #define | PD2 2 |
| #define | PD1 1 |
| #define | PD0 0 |
| #define | DDD6 6 |
| #define | DDD5 5 |
| #define | DDD4 4 |
| #define | DDD3 3 |
| #define | DDD2 2 |
| #define | DDD1 1 |
| #define | DDD0 0 |
| #define | PIND6 6 |
| #define | PIND5 5 |
| #define | PIND4 4 |
| #define | PIND3 3 |
| #define | PIND2 2 |
| #define | PIND1 1 |
| #define | PIND0 0 |
| #define | RXC 7 |
| #define | TXC 6 |
| #define | UDRE 5 |
| #define | FE 4 |
| #define | DOR 3 |
| #define | RXCIE 7 |
| #define | TXCIE 6 |
| #define | UDRIE 5 |
| #define | RXEN 4 |
| #define | TXEN 3 |
| #define | CHR9 2 |
| #define | RXB8 1 |
| #define | TXB8 0 |
| #define | ACD 7 |
| #define | ACO 5 |
| #define | ACI 4 |
| #define | ACIE 3 |
| #define | ACIC 2 |
| #define | ACIS1 1 |
| #define | ACIS0 0 |
| #define | EERIE 3 |
| #define | EEMWE 2 |
| #define | EEWE 1 |
| #define | EERE 0 |
| #define | RAMEND 0xDF |
| #define | XRAMEND RAMEND |
| #define | E2END 0x7F |
| #define | E2PAGESIZE 0 |
| #define | FLASHEND 0x07FF |
| #define | FUSE_MEMORY_SIZE 1 |
| #define | FUSE_FSTRT (unsigned char)~_BV(0) |
| #define | FUSE_SPIEN (unsigned char)~_BV(5) |
| #define | LFUSE_DEFAULT (0xFF) |
| #define | __LOCK_BITS_EXIST |
| #define | SIGNATURE_0 0x1E |
| #define | SIGNATURE_1 0x91 |
| #define | SIGNATURE_2 0x01 |
