ifaddrs.h
1 /* $FreeBSD: src/include/ifaddrs.h,v 1.3 2003/11/14 18:53:22 bms Exp $ */
2
3 /*
4  * Copyright (c) 1995, 1999
5  * Berkeley Software Design, Inc. All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  *
13  * THIS SOFTWARE IS PROVIDED BY Berkeley Software Design, Inc. ``AS IS'' AND
14  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16  * ARE DISCLAIMED. IN NO EVENT SHALL Berkeley Software Design, Inc. BE LIABLE
17  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23  * SUCH DAMAGE.
24  *
25  * BSDI ifaddrs.h,v 2.5 2000/02/23 14:51:59 dab Exp
26  */
27
28 #ifndef _IFADDRS_H_
29 #define _IFADDRS_H_
30
31 struct ifaddrs {
32  struct ifaddrs *ifa_next;
33  char *ifa_name;
34  u_int ifa_flags;
35  struct sockaddr *ifa_addr;
36  struct sockaddr *ifa_netmask;
37  struct sockaddr *ifa_dstaddr;
38  void *ifa_data;
39 };
40
41 /*
42  * This may have been defined in <net/if.h>. Note that if <net/if.h> is
43  * to be included it must be included before this header file.
44  */
45 #ifndef ifa_broadaddr
46 #define ifa_broadaddr ifa_dstaddr /* broadcast address interface */
47 #endif
48
49 #include <sys/cdefs.h>
50
51 __BEGIN_DECLS
52 extern int getifaddrs(struct ifaddrs **);
53 extern void freeifaddrs(struct ifaddrs *);
54 __END_DECLS
55
56 #endif
Definition: socket.h:180
Definition: ifaddrs.h:32
