if_types.h File Reference
#define IFT_OTHER   0x1 /* none of the following */
#define IFT_1822   0x2 /* old-style arpanet imp */
#define IFT_HDH1822   0x3 /* HDH arpanet imp */
#define IFT_X25DDN   0x4 /* x25 to imp */
#define IFT_X25   0x5 /* PDN X25 interface (RFC877) */
#define IFT_ETHER   0x6 /* Ethernet CSMA/CD */
#define IFT_ISO88023   0x7 /* CMSA/CD */
#define IFT_ISO88024   0x8 /* Token Bus */
#define IFT_ISO88025   0x9 /* Token Ring */
#define IFT_ISO88026   0xa /* MAN */
#define IFT_STARLAN   0xb
#define IFT_P10   0xc /* Proteon 10MBit ring */
#define IFT_P80   0xd /* Proteon 80MBit ring */
#define IFT_HY   0xe /* Hyperchannel */
#define IFT_FDDI   0xf
#define IFT_LAPB   0x10
#define IFT_SDLC   0x11
#define IFT_T1   0x12
#define IFT_CEPT   0x13 /* E1 - european T1 */
#define IFT_ISDNBASIC   0x14
#define IFT_ISDNPRIMARY   0x15
#define IFT_PTPSERIAL   0x16 /* Proprietary PTP serial */
#define IFT_PPP   0x17 /* RFC 1331 */
#define IFT_LOOP   0x18 /* loopback */
#define IFT_EON   0x19 /* ISO over IP */
#define IFT_XETHER   0x1a /* obsolete 3MB experimental ethernet */
#define IFT_NSIP   0x1b /* XNS over IP */
#define IFT_SLIP   0x1c /* IP over generic TTY */
#define IFT_ULTRA   0x1d /* Ultra Technologies */
#define IFT_DS3   0x1e /* Generic T3 */
#define IFT_SIP   0x1f /* SMDS */
#define IFT_FRELAY   0x20 /* Frame Relay DTE only */
#define IFT_RS232   0x21
#define IFT_PARA   0x22 /* parallel-port */
#define IFT_ARCNET   0x23
#define IFT_ARCNETPLUS   0x24
#define IFT_ATM   0x25 /* ATM cells */
#define IFT_MIOX25   0x26
#define IFT_SONET   0x27 /* SONET or SDH */
#define IFT_X25PLE   0x28
#define IFT_ISO88022LLC   0x29
#define IFT_LOCALTALK   0x2a
#define IFT_SMDSDXI   0x2b
#define IFT_FRELAYDCE   0x2c /* Frame Relay DCE */
#define IFT_V35   0x2d
#define IFT_HSSI   0x2e
#define IFT_HIPPI   0x2f
#define IFT_MODEM   0x30 /* Generic Modem */
#define IFT_AAL5   0x31 /* AAL5 over ATM */
#define IFT_SONETPATH   0x32
#define IFT_SONETVT   0x33
#define IFT_SMDSICIP   0x34 /* SMDS InterCarrier Interface */
#define IFT_PROPVIRTUAL   0x35 /* Proprietary Virtual/internal */
#define IFT_PROPMUX   0x36 /* Proprietary Multiplexing */
#define IFT_IEEE80212   0x37 /* 100BaseVG */
#define IFT_FIBRECHANNEL   0x38 /* Fibre Channel */
#define IFT_HIPPIINTERFACE   0x39 /* HIPPI interfaces */
#define IFT_FRAMERELAYINTERCONNECT   0x3a /* Obsolete, use either 0x20 or 0x2c */
#define IFT_AFLANE8023   0x3b /* ATM Emulated LAN for 802.3 */
#define IFT_AFLANE8025   0x3c /* ATM Emulated LAN for 802.5 */
#define IFT_CCTEMUL   0x3d /* ATM Emulated circuit */
#define IFT_FASTETHER   0x3e /* Fast Ethernet (100BaseT) */
#define IFT_ISDN   0x3f /* ISDN and X.25 */
#define IFT_V11   0x40 /* CCITT V.11/X.21 */
#define IFT_V36   0x41 /* CCITT V.36 */
#define IFT_G703AT64K   0x42 /* CCITT G703 at 64Kbps */
#define IFT_G703AT2MB   0x43 /* Obsolete see DS1-MIB */
#define IFT_QLLC   0x44 /* SNA QLLC */
#define IFT_FASTETHERFX   0x45 /* Fast Ethernet (100BaseFX) */
#define IFT_CHANNEL   0x46 /* channel */
#define IFT_IEEE80211   0x47 /* radio spread spectrum */
#define IFT_IBM370PARCHAN   0x48 /* IBM System 360/370 OEMI Channel */
#define IFT_ESCON   0x49 /* IBM Enterprise Systems Connection */
#define IFT_DLSW   0x4a /* Data Link Switching */
#define IFT_ISDNS   0x4b /* ISDN S/T interface */
#define IFT_ISDNU   0x4c /* ISDN U interface */
#define IFT_LAPD   0x4d /* Link Access Protocol D */
#define IFT_IPSWITCH   0x4e /* IP Switching Objects */
#define IFT_RSRB   0x4f /* Remote Source Route Bridging */
#define IFT_ATMLOGICAL   0x50 /* ATM Logical Port */
#define IFT_DS0   0x51 /* Digital Signal Level 0 */
#define IFT_DS0BUNDLE   0x52 /* group of ds0s on the same ds1 */
#define IFT_BSC   0x53 /* Bisynchronous Protocol */
#define IFT_ASYNC   0x54 /* Asynchronous Protocol */
#define IFT_CNR   0x55 /* Combat Net Radio */
#define IFT_ISO88025DTR   0x56 /* ISO 802.5r DTR */
#define IFT_EPLRS   0x57 /* Ext Pos Loc Report Sys */
#define IFT_ARAP   0x58 /* Appletalk Remote Access Protocol */
#define IFT_PROPCNLS   0x59 /* Proprietary Connectionless Protocol*/
#define IFT_HOSTPAD   0x5a /* CCITT-ITU X.29 PAD Protocol */
#define IFT_TERMPAD   0x5b /* CCITT-ITU X.3 PAD Facility */
#define IFT_FRAMERELAYMPI   0x5c /* Multiproto Interconnect over FR */
#define IFT_X213   0x5d /* CCITT-ITU X213 */
#define IFT_ADSL   0x5e /* Asymmetric Digital Subscriber Loop */
#define IFT_RADSL   0x5f /* Rate-Adapt. Digital Subscriber Loop*/
#define IFT_SDSL   0x60 /* Symmetric Digital Subscriber Loop */
#define IFT_VDSL   0x61 /* Very H-Speed Digital Subscrib. Loop*/
#define IFT_ISO88025CRFPINT   0x62 /* ISO 802.5 CRFP */
#define IFT_MYRINET   0x63 /* Myricom Myrinet */
#define IFT_VOICEEM   0x64 /* voice recEive and transMit */
#define IFT_VOICEFXO   0x65 /* voice Foreign Exchange Office */
#define IFT_VOICEFXS   0x66 /* voice Foreign Exchange Station */
#define IFT_VOICEENCAP   0x67 /* voice encapsulation */
#define IFT_VOICEOVERIP   0x68 /* voice over IP encapsulation */
#define IFT_ATMDXI   0x69 /* ATM DXI */
#define IFT_ATMFUNI   0x6a /* ATM FUNI */
#define IFT_ATMIMA   0x6b /* ATM IMA */
#define IFT_PPPMULTILINKBUNDLE   0x6c /* PPP Multilink Bundle */
#define IFT_IPOVERCDLC   0x6d /* IBM ipOverCdlc */
#define IFT_IPOVERCLAW   0x6e /* IBM Common Link Access to Workstn */
#define IFT_STACKTOSTACK   0x6f /* IBM stackToStack */
#define IFT_VIRTUALIPADDRESS   0x70 /* IBM VIPA */
#define IFT_MPC   0x71 /* IBM multi-protocol channel support */
#define IFT_IPOVERATM   0x72 /* IBM ipOverAtm */
#define IFT_ISO88025FIBER   0x73 /* ISO 802.5j Fiber Token Ring */
#define IFT_TDLC   0x74 /* IBM twinaxial data link control */
#define IFT_GIGABITETHERNET   0x75 /* Gigabit Ethernet */
#define IFT_HDLC   0x76 /* HDLC */
#define IFT_LAPF   0x77 /* LAP F */
#define IFT_V37   0x78 /* V.37 */
#define IFT_X25MLP   0x79 /* Multi-Link Protocol */
#define IFT_X25HUNTGROUP   0x7a /* X25 Hunt Group */
#define IFT_TRANSPHDLC   0x7b /* Transp HDLC */
#define IFT_INTERLEAVE   0x7c /* Interleave channel */
#define IFT_FAST   0x7d /* Fast channel */
#define IFT_IP   0x7e /* IP (for APPN HPR in IP networks) */
#define IFT_DOCSCABLEMACLAYER   0x7f /* CATV Mac Layer */
#define IFT_DOCSCABLEDOWNSTREAM   0x80 /* CATV Downstream interface */
#define IFT_DOCSCABLEUPSTREAM   0x81 /* CATV Upstream interface */
#define IFT_A12MPPSWITCH   0x82 /* Avalon Parallel Processor */
#define IFT_TUNNEL   0x83 /* Encapsulation interface */
#define IFT_COFFEE   0x84 /* coffee pot */
#define IFT_CES   0x85 /* Circiut Emulation Service */
#define IFT_ATMSUBINTERFACE   0x86 /* (x) ATM Sub Interface */
#define IFT_L2VLAN   0x87 /* Layer 2 Virtual LAN using 802.1Q */
#define IFT_L3IPVLAN   0x88 /* Layer 3 Virtual LAN - IP Protocol */
#define IFT_L3IPXVLAN   0x89 /* Layer 3 Virtual LAN - IPX Prot. */
#define IFT_DIGITALPOWERLINE   0x8a /* IP over Power Lines */
#define IFT_MEDIAMAILOVERIP   0x8b /* (xxx) Multimedia Mail over IP */
#define IFT_DTM   0x8c /* Dynamic synchronous Transfer Mode */
#define IFT_DCN   0x8d /* Data Communications Network */
#define IFT_IPFORWARD   0x8e /* IP Forwarding Interface */
#define IFT_MSDSL   0x8f /* Multi-rate Symmetric DSL */
#define IFT_IEEE1394   0x90 /* IEEE1394 High Performance SerialBus*/
#define IFT_IFGSN   0x91 /* HIPPI-6400 */
#define IFT_DVBRCCMACLAYER   0x92 /* DVB-RCC MAC Layer */
#define IFT_DVBRCCDOWNSTREAM   0x93 /* DVB-RCC Downstream Channel */
#define IFT_DVBRCCUPSTREAM   0x94 /* DVB-RCC Upstream Channel */
#define IFT_ATMVIRTUAL   0x95 /* ATM Virtual Interface */
#define IFT_MPLSTUNNEL   0x96 /* MPLS Tunnel Virtual Interface */
#define IFT_SRP   0x97 /* Spatial Reuse Protocol */
#define IFT_VOICEOVERATM   0x98 /* Voice over ATM */
#define IFT_VOICEOVERFRAMERELAY   0x99 /* Voice Over Frame Relay */
#define IFT_IDSL   0x9a /* Digital Subscriber Loop over ISDN */
#define IFT_COMPOSITELINK   0x9b /* Avici Composite Link Interface */
#define IFT_SS7SIGLINK   0x9c /* SS7 Signaling Link */
#define IFT_PROPWIRELESSP2P   0x9d /* Prop. P2P wireless interface */
#define IFT_FRFORWARD   0x9e /* Frame forward Interface */
#define IFT_RFC1483   0x9f /* Multiprotocol over ATM AAL5 */
#define IFT_USB   0xa0 /* USB Interface */
#define IFT_IEEE8023ADLAG   0xa1 /* IEEE 802.3ad Link Aggregate*/
#define IFT_BGPPOLICYACCOUNTING   0xa2 /* BGP Policy Accounting */
#define IFT_FRF16MFRBUNDLE   0xa3 /* FRF.16 Multilik Frame Relay*/
#define IFT_H323GATEKEEPER   0xa4 /* H323 Gatekeeper */
#define IFT_H323PROXY   0xa5 /* H323 Voice and Video Proxy */
#define IFT_MPLS   0xa6 /* MPLS */
#define IFT_MFSIGLINK   0xa7 /* Multi-frequency signaling link */
#define IFT_HDSL2   0xa8 /* High Bit-Rate DSL, 2nd gen. */
#define IFT_SHDSL   0xa9 /* Multirate HDSL2 */
#define IFT_DS1FDL   0xaa /* Facility Data Link (4Kbps) on a DS1*/
#define IFT_POS   0xab /* Packet over SONET/SDH Interface */
#define IFT_DVBASILN   0xac /* DVB-ASI Input */
#define IFT_DVBASIOUT   0xad /* DVB-ASI Output */
#define IFT_PLC   0xae /* Power Line Communications */
#define IFT_NFAS   0xaf /* Non-Facility Associated Signaling */
#define IFT_TR008   0xb0 /* TROO8 */
#define IFT_GR303RDT   0xb1 /* Remote Digital Terminal */
#define IFT_GR303IDT   0xb2 /* Integrated Digital Terminal */
#define IFT_ISUP   0xb3 /* ISUP */
#define IFT_PROPDOCSWIRELESSMACLAYER   0xb4 /* prop/Wireless MAC Layer */
#define IFT_PROPDOCSWIRELESSDOWNSTREAM   0xb5 /* prop/Wireless Downstream */
#define IFT_PROPDOCSWIRELESSUPSTREAM   0xb6 /* prop/Wireless Upstream */
#define IFT_HIPERLAN2   0xb7 /* HIPERLAN Type 2 Radio Interface */
#define IFT_PROPBWAP2MP   0xb8 /* PropBroadbandWirelessAccess P2MP*/
#define IFT_SONETOVERHEADCHANNEL   0xb9 /* SONET Overhead Channel */
#define IFT_DIGITALWRAPPEROVERHEADCHANNEL   0xba /* Digital Wrapper Overhead */
#define IFT_AAL2   0xbb /* ATM adaptation layer 2 */
#define IFT_RADIOMAC   0xbc /* MAC layer over radio links */
#define IFT_ATMRADIO   0xbd /* ATM over radio links */
#define IFT_IMT   0xbe /* Inter-Machine Trunks */
#define IFT_MVL   0xbf /* Multiple Virtual Lines DSL */
#define IFT_REACHDSL   0xc0 /* Long Reach DSL */
#define IFT_FRDLCIENDPT   0xc1 /* Frame Relay DLCI End Point */
#define IFT_ATMVCIENDPT   0xc2 /* ATM VCI End Point */
#define IFT_OPTICALCHANNEL   0xc3 /* Optical Channel */
#define IFT_OPTICALTRANSPORT   0xc4 /* Optical Transport */
#define IFT_STF   0xd7 /* 6to4 interface */
#define IFT_GIF   0xf0
#define IFT_PVC   0xf1
#define IFT_FAITH   0xf2
#define IFT_PFLOG   0xf6
#define IFT_PFSYNC   0xf7
#define IFT_CARP   0xf8 /* Common Address Redundancy Protocol */
