if_media.h
1 /* $NetBSD: if_media.h,v 1.3 1997/03/26 01:19:27 thorpej Exp $ */
2 /* $FreeBSD: src/sys/net/if_media.h,v 1.26 2004/01/26 11:52:32 harti Exp $ */
3
4 /*
5  * Copyright (c) 1997
6  * Jonathan Stone and Jason R. Thorpe. All rights reserved.
7  *
8  * This software is derived from information provided by Matt Thomas.
9  *
10  * Redistribution and use in source and binary forms, with or without
11  * modification, are permitted provided that the following conditions
12  * are met:
13  * 1. Redistributions of source code must retain the above copyright
14  * notice, this list of conditions and the following disclaimer.
15  * 2. Redistributions in binary form must reproduce the above copyright
16  * notice, this list of conditions and the following disclaimer in the
17  * documentation and/or other materials provided with the distribution.
18  * 3. All advertising materials mentioning features or use of this software
19  * must display the following acknowledgement:
20  * This product includes software developed by Jonathan Stone
21  * and Jason R. Thorpe for the NetBSD Project.
22  * 4. The names of the authors may not be used to endorse or promote products
23  * derived from this software without specific prior written permission.
24  *
25  * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
26  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
27  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
28  * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
29  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
30  * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
31  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
32  * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
33  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
34  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
35  * SUCH DAMAGE.
36  */
37
38 #ifndef _NET_IF_MEDIA_H_
39 #define _NET_IF_MEDIA_H_
40
41 /*
42  * Prototypes and definitions for BSD/OS-compatible network interface
43  * media selection.
44  *
45  * Where it is safe to do so, this code strays slightly from the BSD/OS
46  * design. Software which uses the API (device drivers, basically)
47  * shouldn't notice any difference.
48  *
49  * Many thanks to Matt Thomas for providing the information necessary
50  * to implement this interface.
51  */
52
53 #ifdef _KERNEL
54
55 #include <sys/queue.h>
56
57 /*
58  * Driver callbacks for media status and change requests.
59  */
60 typedef int (*ifm_change_cb_t)(struct ifnet *ifp);
61 typedef void (*ifm_stat_cb_t)(struct ifnet *ifp, struct ifmediareq *req);
62
63 /*
64  * In-kernel representation of a single supported media type.
65  */
66 struct ifmedia_entry {
67  LIST_ENTRY(ifmedia_entry) ifm_list;
68  int ifm_media; /* description of this media attachment */
69  int ifm_data; /* for driver-specific use */
70  void *ifm_aux; /* for driver-specific use */
71 };
72
73 /*
74  * One of these goes into a network interface's softc structure.
75  * It is used to keep general media state.
76  */
77 struct ifmedia {
78  int ifm_mask; /* mask of changes we don't care about */
79  int ifm_media; /* current user-set media word */
80  struct ifmedia_entry *ifm_cur; /* currently selected media */
81  LIST_HEAD(, ifmedia_entry) ifm_list; /* list of all supported media */
82  ifm_change_cb_t ifm_change; /* media change driver callback */
83  ifm_stat_cb_t ifm_status; /* media status driver callback */
84 };
85
86 /* Initialize an interface's struct if_media field. */
87 void ifmedia_init(struct ifmedia *ifm, int dontcare_mask,
88  ifm_change_cb_t change_callback, ifm_stat_cb_t status_callback);
89
90 /* Remove all mediums from a struct ifmedia. */
91 void ifmedia_removeall( struct ifmedia *ifm);
92
93 /* Add one supported medium to a struct ifmedia. */
94 void ifmedia_add(struct ifmedia *ifm, int mword, int data, void *aux);
95
96 /* Add an array (of ifmedia_entry) media to a struct ifmedia. */
97 void ifmedia_list_add(struct ifmedia *mp, struct ifmedia_entry *lp,
98  int count);
99
100 /* Set default media type on initialization. */
101 void ifmedia_set(struct ifmedia *ifm, int mword);
102
103 /* Common ioctl function for getting/setting media, called by driver. */
104 int ifmedia_ioctl(struct ifnet *ifp, struct ifreq *ifr,
105  struct ifmedia *ifm, u_long cmd);
106
107 #endif /*_KERNEL */
108
109 /*
110  * if_media Options word:
111  * Bits Use
112  * ---- -------
113  * 0-4 Media variant
114  * 5-7 Media type
115  * 8-15 Type specific options
116  * 16-18 Mode (for multi-mode devices)
117  * 19 RFU
118  * 20-27 Shared (global) options
119  * 28-31 Instance
120  */
121
122 /*
123  * Ethernet
124  */
125 #define IFM_ETHER 0x00000020
126 #define IFM_10_T 3 /* 10BaseT - RJ45 */
127 #define IFM_10_2 4 /* 10Base2 - Thinnet */
128 #define IFM_10_5 5 /* 10Base5 - AUI */
129 #define IFM_100_TX 6 /* 100BaseTX - RJ45 */
130 #define IFM_100_FX 7 /* 100BaseFX - Fiber */
131 #define IFM_100_T4 8 /* 100BaseT4 - 4 pair cat 3 */
132 #define IFM_100_VG 9 /* 100VG-AnyLAN */
133 #define IFM_100_T2 10 /* 100BaseT2 */
134 #define IFM_1000_SX 11 /* 1000BaseSX - multi-mode fiber */
135 #define IFM_10_STP 12 /* 10BaseT over shielded TP */
136 #define IFM_10_FL 13 /* 10BaseFL - Fiber */
137 #define IFM_1000_LX 14 /* 1000baseLX - single-mode fiber */
138 #define IFM_1000_CX 15 /* 1000baseCX - 150ohm STP */
139 #define IFM_1000_T 16 /* 1000baseT - 4 pair cat 5 */
140 #define IFM_HPNA_1 17 /* HomePNA 1.0 (1Mb/s) */
141 /* note 31 is the max! */
142
143 #define IFM_ETH_MASTER 0x00000100 /* master mode (1000baseT) */
144
145 /*
146  * Token ring
147  */
148 #define IFM_TOKEN 0x00000040
149 #define IFM_TOK_STP4 3 /* Shielded twisted pair 4m - DB9 */
150 #define IFM_TOK_STP16 4 /* Shielded twisted pair 16m - DB9 */
151 #define IFM_TOK_UTP4 5 /* Unshielded twisted pair 4m - RJ45 */
152 #define IFM_TOK_UTP16 6 /* Unshielded twisted pair 16m - RJ45 */
153 #define IFM_TOK_STP100 7 /* Shielded twisted pair 100m - DB9 */
154 #define IFM_TOK_UTP100 8 /* Unshielded twisted pair 100m - RJ45 */
155 #define IFM_TOK_ETR 0x00000200 /* Early token release */
156 #define IFM_TOK_SRCRT 0x00000400 /* Enable source routing features */
157 #define IFM_TOK_ALLR 0x00000800 /* All routes / Single route bcast */
158 #define IFM_TOK_DTR 0x00002000 /* Dedicated token ring */
159 #define IFM_TOK_CLASSIC 0x00004000 /* Classic token ring */
160 #define IFM_TOK_AUTO 0x00008000 /* Automatic Dedicate/Classic token ring */
161
162 /*
163  * FDDI
164  */
165 #define IFM_FDDI 0x00000060
166 #define IFM_FDDI_SMF 3 /* Single-mode fiber */
167 #define IFM_FDDI_MMF 4 /* Multi-mode fiber */
168 #define IFM_FDDI_UTP 5 /* CDDI / UTP */
169 #define IFM_FDDI_DA 0x00000100 /* Dual attach / single attach */
170
171 /*
172  * IEEE 802.11 Wireless
173  */
174 #define IFM_IEEE80211 0x00000080
175 /* NB: 0,1,2 are auto, manual, none defined below */
176 #define IFM_IEEE80211_FH1 3 /* Frequency Hopping 1Mbps */
177 #define IFM_IEEE80211_FH2 4 /* Frequency Hopping 2Mbps */
178 #define IFM_IEEE80211_DS1 5 /* Direct Sequence 1Mbps */
179 #define IFM_IEEE80211_DS2 6 /* Direct Sequence 2Mbps */
180 #define IFM_IEEE80211_DS5 7 /* Direct Sequence 5.5Mbps */
181 #define IFM_IEEE80211_DS11 8 /* Direct Sequence 11Mbps */
182 #define IFM_IEEE80211_DS22 9 /* Direct Sequence 22Mbps */
183 #define IFM_IEEE80211_OFDM6 10 /* OFDM 6Mbps */
184 #define IFM_IEEE80211_OFDM9 11 /* OFDM 9Mbps */
185 #define IFM_IEEE80211_OFDM12 12 /* OFDM 12Mbps */
186 #define IFM_IEEE80211_OFDM18 13 /* OFDM 18Mbps */
187 #define IFM_IEEE80211_OFDM24 14 /* OFDM 24Mbps */
188 #define IFM_IEEE80211_OFDM36 15 /* OFDM 36Mbps */
189 #define IFM_IEEE80211_OFDM48 16 /* OFDM 48Mbps */
190 #define IFM_IEEE80211_OFDM54 17 /* OFDM 54Mbps */
191 #define IFM_IEEE80211_OFDM72 18 /* OFDM 72Mbps */
192
193 #define IFM_IEEE80211_ADHOC 0x00000100 /* Operate in Adhoc mode */
194 #define IFM_IEEE80211_HOSTAP 0x00000200 /* Operate in Host AP mode */
195 #define IFM_IEEE80211_IBSS 0x00000400 /* Operate in IBSS mode */
196 #define IFM_IEEE80211_IBSSMASTER 0x00000800 /* Operate as an IBSS master */
197 #define IFM_IEEE80211_TURBO 0x00001000 /* Operate in turbo mode */
198 #define IFM_IEEE80211_MONITOR 0x00002000 /* Operate in monitor mode */
199
200 /* operating mode for multi-mode devices */
201 #define IFM_IEEE80211_11A 0x00010000 /* 5Ghz, OFDM mode */
202 #define IFM_IEEE80211_11B 0x00020000 /* Direct Sequence mode */
203 #define IFM_IEEE80211_11G 0x00030000 /* 2Ghz, CCK mode */
204 #define IFM_IEEE80211_FH 0x00040000 /* 2Ghz, GFSK mode */
205
206 /*
207  * ATM
208  */
209 #define IFM_ATM 0x000000a0
210 #define IFM_ATM_UNKNOWN 3
211 #define IFM_ATM_UTP_25 4
212 #define IFM_ATM_TAXI_100 5
213 #define IFM_ATM_TAXI_140 6
214 #define IFM_ATM_MM_155 7
215 #define IFM_ATM_SM_155 8
216 #define IFM_ATM_UTP_155 9
217 #define IFM_ATM_MM_622 10
218 #define IFM_ATM_SM_622 11
219 #define IFM_ATM_VIRTUAL 12
220 #define IFM_ATM_SDH 0x00000100 /* SDH instead of SONET */
221 #define IFM_ATM_NOSCRAMB 0x00000200 /* no scrambling */
222 #define IFM_ATM_UNASSIGNED 0x00000400 /* unassigned cells */
223
224 /*
225  * Shared media sub-types
226  */
227 #define IFM_AUTO 0 /* Autoselect best media */
228 #define IFM_MANUAL 1 /* Jumper/dipswitch selects media */
229 #define IFM_NONE 2 /* Deselect all media */
230
231 /*
232  * Shared options
233  */
234 #define IFM_FDX 0x00100000 /* Force full duplex */
235 #define IFM_HDX 0x00200000 /* Force half duplex */
236 #define IFM_FLAG0 0x01000000 /* Driver defined flag */
237 #define IFM_FLAG1 0x02000000 /* Driver defined flag */
238 #define IFM_FLAG2 0x04000000 /* Driver defined flag */
239 #define IFM_LOOP 0x08000000 /* Put hardware in loopback */
240
241 /*
242  * Masks
243  */
244 #define IFM_NMASK 0x000000e0 /* Network type */
245 #define IFM_TMASK 0x0000001f /* Media sub-type */
246 #define IFM_IMASK 0xf0000000 /* Instance */
247 #define IFM_ISHIFT 28 /* Instance shift */
248 #define IFM_OMASK 0x0000ff00 /* Type specific options */
249 #define IFM_MMASK 0x00070000 /* Mode */
250 #define IFM_MSHIFT 16 /* Mode shift */
251 #define IFM_GMASK 0x0ff00000 /* Global options */
252
253 /*
254  * Status bits
255  */
256 /*
257  * FIXME: This is a hack to get the libbsdport interface drivers working. See
258  * also rtems_mii_ioctl.h.
259  */
260 #define IFM_AVALID IFM_FLAG0 /* Active bit valid */
261 #define IFM_ACTIVE IFM_FLAG0 /* Interface attached to working net */
262
263 /*
264  * Macros to extract various bits of information from the media word.
265  */
266 #define IFM_TYPE(x) ((x) & IFM_NMASK)
267 #define IFM_SUBTYPE(x) ((x) & IFM_TMASK)
268 #define IFM_TYPE_OPTIONS(x) ((x) & IFM_OMASK)
269 #define IFM_INST(x) (((x) & IFM_IMASK) >> IFM_ISHIFT)
270 #define IFM_OPTIONS(x) ((x) & (IFM_OMASK|IFM_GMASK))
271 #define IFM_MODE(x) ((x) & IFM_MMASK)
272
273 #define IFM_INST_MAX IFM_INST(IFM_IMASK)
274
275 /*
276  * Macro to create a media word.
277  */
278 #define IFM_MAKEWORD(type, subtype, options, instance) \
279  ((type) | (subtype) | (options) | ((uint32_t)(instance) << IFM_ISHIFT))
280 #define IFM_MAKEMODE(mode) \
281  (((mode) << IFM_MSHIFT) & IFM_MMASK)
282
283 /*
284  * NetBSD extension not defined in the BSDI API. This is used in various
285  * places to get the canonical description for a given type/subtype.
286  *
287  * NOTE: all but the top-level type descriptions must contain NO whitespace!
288  * Otherwise, parsing these in ifconfig(8) would be a nightmare.
289  */
290 struct ifmedia_description {
291  int ifmt_word; /* word value; may be masked */
292  const char *ifmt_string; /* description */
293 };
294
295 #define IFM_TYPE_DESCRIPTIONS { \
296  { IFM_ETHER, "Ethernet" }, \
297  { IFM_TOKEN, "Token ring" }, \
298  { IFM_FDDI, "FDDI" }, \
299  { IFM_IEEE80211, "IEEE 802.11 Wireless Ethernet" }, \
300  { IFM_ATM, "ATM" }, \
301  { 0, NULL }, \
302 }
303
304 #define IFM_SUBTYPE_ETHERNET_DESCRIPTIONS { \
305  { IFM_10_T, "10baseT/UTP" }, \
306  { IFM_10_2, "10base2/BNC" }, \
307  { IFM_10_5, "10base5/AUI" }, \
308  { IFM_100_TX, "100baseTX" }, \
309  { IFM_100_FX, "100baseFX" }, \
310  { IFM_100_T4, "100baseT4" }, \
311  { IFM_100_VG, "100baseVG" }, \
312  { IFM_100_T2, "100baseT2" }, \
313  { IFM_10_STP, "10baseSTP" }, \
314  { IFM_10_FL, "10baseFL" }, \
315  { IFM_1000_SX, "1000baseSX" }, \
316  { IFM_1000_LX, "1000baseLX" }, \
317  { IFM_1000_CX, "1000baseCX" }, \
318  { IFM_1000_T, "1000baseTX" }, \
319  { IFM_1000_T, "1000baseT" }, \
320  { IFM_HPNA_1, "homePNA" }, \
321  { 0, NULL }, \
322 }
323
324 #define IFM_SUBTYPE_ETHERNET_ALIASES { \
325  { IFM_10_T, "UTP" }, \
326  { IFM_10_T, "10UTP" }, \
327  { IFM_10_2, "BNC" }, \
328  { IFM_10_2, "10BNC" }, \
329  { IFM_10_5, "AUI" }, \
330  { IFM_10_5, "10AUI" }, \
331  { IFM_100_TX, "100TX" }, \
332  { IFM_100_T4, "100T4" }, \
333  { IFM_100_VG, "100VG" }, \
334  { IFM_100_T2, "100T2" }, \
335  { IFM_10_STP, "10STP" }, \
336  { IFM_10_FL, "10FL" }, \
337  { IFM_1000_SX, "1000SX" }, \
338  { IFM_1000_LX, "1000LX" }, \
339  { IFM_1000_CX, "1000CX" }, \
340  { IFM_1000_T, "1000TX" }, \
341  { IFM_1000_T, "1000T" }, \
342  { 0, NULL }, \
343 }
344
345 #define IFM_SUBTYPE_ETHERNET_OPTION_DESCRIPTIONS { \
346  { 0, NULL }, \
347 }
348
349 #define IFM_SUBTYPE_TOKENRING_DESCRIPTIONS { \
350  { IFM_TOK_STP4, "DB9/4Mbit" }, \
351  { IFM_TOK_STP16, "DB9/16Mbit" }, \
352  { IFM_TOK_UTP4, "UTP/4Mbit" }, \
353  { IFM_TOK_UTP16, "UTP/16Mbit" }, \
354  { IFM_TOK_STP100, "STP/100Mbit" }, \
355  { IFM_TOK_UTP100, "UTP/100Mbit" }, \
356  { 0, NULL }, \
357 }
358
359 #define IFM_SUBTYPE_TOKENRING_ALIASES { \
360  { IFM_TOK_STP4, "4STP" }, \
361  { IFM_TOK_STP16, "16STP" }, \
362  { IFM_TOK_UTP4, "4UTP" }, \
363  { IFM_TOK_UTP16, "16UTP" }, \
364  { IFM_TOK_STP100, "100STP" }, \
365  { IFM_TOK_UTP100, "100UTP" }, \
366  { 0, NULL }, \
367 }
368
369 #define IFM_SUBTYPE_TOKENRING_OPTION_DESCRIPTIONS { \
370  { IFM_TOK_ETR, "EarlyTokenRelease" }, \
371  { IFM_TOK_SRCRT, "SourceRouting" }, \
372  { IFM_TOK_ALLR, "AllRoutes" }, \
373  { IFM_TOK_DTR, "Dedicated" }, \
374  { IFM_TOK_CLASSIC,"Classic" }, \
375  { IFM_TOK_AUTO, " " }, \
376  { 0, NULL }, \
377 }
378
379 #define IFM_SUBTYPE_FDDI_DESCRIPTIONS { \
380  { IFM_FDDI_SMF, "Single-mode" }, \
381  { IFM_FDDI_MMF, "Multi-mode" }, \
382  { IFM_FDDI_UTP, "UTP" }, \
383  { 0, NULL }, \
384 }
385
386 #define IFM_SUBTYPE_FDDI_ALIASES { \
387  { IFM_FDDI_SMF, "SMF" }, \
388  { IFM_FDDI_MMF, "MMF" }, \
389  { IFM_FDDI_UTP, "CDDI" }, \
390  { 0, NULL }, \
391 }
392
393 #define IFM_SUBTYPE_FDDI_OPTION_DESCRIPTIONS { \
394  { IFM_FDDI_DA, "Dual-attach" }, \
395  { 0, NULL }, \
396 }
397
398 #define IFM_SUBTYPE_IEEE80211_DESCRIPTIONS { \
399  { IFM_IEEE80211_FH1, "FH/1Mbps" }, \
400  { IFM_IEEE80211_FH2, "FH/2Mbps" }, \
401  { IFM_IEEE80211_DS1, "DS/1Mbps" }, \
402  { IFM_IEEE80211_DS2, "DS/2Mbps" }, \
403  { IFM_IEEE80211_DS5, "DS/5.5Mbps" }, \
404  { IFM_IEEE80211_DS11, "DS/11Mbps" }, \
405  { IFM_IEEE80211_DS22, "DS/22Mbps" }, \
406  { IFM_IEEE80211_OFDM6, "OFDM/6Mbps" }, \
407  { IFM_IEEE80211_OFDM9, "OFDM/9Mbps" }, \
408  { IFM_IEEE80211_OFDM12, "OFDM/12Mbps" }, \
409  { IFM_IEEE80211_OFDM18, "OFDM/18Mbps" }, \
410  { IFM_IEEE80211_OFDM24, "OFDM/24Mbps" }, \
411  { IFM_IEEE80211_OFDM36, "OFDM/36Mbps" }, \
412  { IFM_IEEE80211_OFDM48, "OFDM/48Mbps" }, \
413  { IFM_IEEE80211_OFDM54, "OFDM/54Mbps" }, \
414  { IFM_IEEE80211_OFDM72, "OFDM/72Mbps" }, \
415  { 0, NULL }, \
416 }
417
418 #define IFM_SUBTYPE_IEEE80211_ALIASES { \
419  { IFM_IEEE80211_FH1, "FH1" }, \
420  { IFM_IEEE80211_FH2, "FH2" }, \
421  { IFM_IEEE80211_FH1, "FrequencyHopping/1Mbps" }, \
422  { IFM_IEEE80211_FH2, "FrequencyHopping/2Mbps" }, \
423  { IFM_IEEE80211_DS1, "DS1" }, \
424  { IFM_IEEE80211_DS2, "DS2" }, \
425  { IFM_IEEE80211_DS5, "DS5.5" }, \
426  { IFM_IEEE80211_DS11, "DS11" }, \
427  { IFM_IEEE80211_DS22, "DS22" }, \
428  { IFM_IEEE80211_DS1, "DirectSequence/1Mbps" }, \
429  { IFM_IEEE80211_DS2, "DirectSequence/2Mbps" }, \
430  { IFM_IEEE80211_DS5, "DirectSequence/5.5Mbps" }, \
431  { IFM_IEEE80211_DS11, "DirectSequence/11Mbps" }, \
432  { IFM_IEEE80211_DS22, "DirectSequence/22Mbps" }, \
433  { IFM_IEEE80211_OFDM6, "OFDM6" }, \
434  { IFM_IEEE80211_OFDM9, "OFDM9" }, \
435  { IFM_IEEE80211_OFDM12, "OFDM12" }, \
436  { IFM_IEEE80211_OFDM18, "OFDM18" }, \
437  { IFM_IEEE80211_OFDM24, "OFDM24" }, \
438  { IFM_IEEE80211_OFDM36, "OFDM36" }, \
439  { IFM_IEEE80211_OFDM48, "OFDM48" }, \
440  { IFM_IEEE80211_OFDM54, "OFDM54" }, \
441  { IFM_IEEE80211_OFDM72, "OFDM72" }, \
442  { IFM_IEEE80211_DS1, "CCK1" }, \
443  { IFM_IEEE80211_DS2, "CCK2" }, \
444  { IFM_IEEE80211_DS5, "CCK5.5" }, \
445  { IFM_IEEE80211_DS11, "CCK11" }, \
446  { 0, NULL }, \
447 }
448
449 #define IFM_SUBTYPE_IEEE80211_OPTION_DESCRIPTIONS { \
450  { IFM_IEEE80211_ADHOC, "adhoc" }, \
451  { IFM_IEEE80211_HOSTAP, "hostap" }, \
452  { IFM_IEEE80211_IBSS, "ibss" }, \
453  { IFM_IEEE80211_IBSSMASTER, "ibss-master" }, \
454  { IFM_IEEE80211_TURBO, "turbo" }, \
455  { IFM_IEEE80211_MONITOR, "monitor" }, \
456  { 0, NULL }, \
457 }
458
459 #define IFM_SUBTYPE_IEEE80211_MODE_DESCRIPTIONS { \
460  { IFM_AUTO, "autoselect" }, \
461  { IFM_IEEE80211_11A, "11a" }, \
462  { IFM_IEEE80211_11B, "11b" }, \
463  { IFM_IEEE80211_11G, "11g" }, \
464  { IFM_IEEE80211_FH, "fh" }, \
465  { 0, NULL }, \
466 }
467
468 #define IFM_SUBTYPE_IEEE80211_MODE_ALIASES { \
469  { IFM_AUTO, "auto" }, \
470  { 0, NULL }, \
471 }
472
473 # define IFM_SUBTYPE_ATM_DESCRIPTIONS { \
474  { IFM_ATM_UNKNOWN, "Unknown" }, \
475  { IFM_ATM_UTP_25, "UTP/25.6MBit" }, \
476  { IFM_ATM_TAXI_100, "Taxi/100MBit" }, \
477  { IFM_ATM_TAXI_140, "Taxi/140MBit" }, \
478  { IFM_ATM_MM_155, "Multi-mode/155MBit" }, \
479  { IFM_ATM_SM_155, "Single-mode/155MBit" }, \
480  { IFM_ATM_UTP_155, "UTP/155MBit" }, \
481  { IFM_ATM_MM_622, "Multi-mode/622MBit" }, \
482  { IFM_ATM_SM_622, "Single-mode/622MBit" }, \
483  { IFM_ATM_VIRTUAL, "Virtual" }, \
484  { 0, NULL }, \
485 }
486
487 # define IFM_SUBTYPE_ATM_ALIASES { \
488  { IFM_ATM_UNKNOWN, "UNKNOWN" }, \
489  { IFM_ATM_UTP_25, "UTP-25" }, \
490  { IFM_ATM_TAXI_100, "TAXI-100" }, \
491  { IFM_ATM_TAXI_140, "TAXI-140" }, \
492  { IFM_ATM_MM_155, "MM-155" }, \
493  { IFM_ATM_SM_155, "SM-155" }, \
494  { IFM_ATM_UTP_155, "UTP-155" }, \
495  { IFM_ATM_MM_622, "MM-622" }, \
496  { IFM_ATM_SM_622, "SM-622" }, \
497  { IFM_ATM_VIRTUAL, "VIRTUAL" }, \
498  { 0, NULL }, \
499 }
500
501 #define IFM_SUBTYPE_ATM_OPTION_DESCRIPTIONS { \
502  { IFM_ATM_SDH, "SDH" }, \
503  { IFM_ATM_NOSCRAMB, "Noscramb" }, \
504  { IFM_ATM_UNASSIGNED, "Unassigned" }, \
505  { 0, NULL }, \
506 }
507
508
509 #define IFM_SUBTYPE_SHARED_DESCRIPTIONS { \
510  { IFM_AUTO, "autoselect" }, \
511  { IFM_MANUAL, "manual" }, \
512  { IFM_NONE, "none" }, \
513  { 0, NULL }, \
514 }
515
516 #define IFM_SUBTYPE_SHARED_ALIASES { \
517  { IFM_AUTO, "auto" }, \
518  { 0, NULL }, \
519 }
520
521 #define IFM_SHARED_OPTION_DESCRIPTIONS { \
522  { IFM_FDX, "full-duplex" }, \
523  { IFM_HDX, "half-duplex" }, \
524  { IFM_FLAG0, "flag0" }, \
525  { IFM_FLAG1, "flag1" }, \
526  { IFM_FLAG2, "flag2" }, \
527  { IFM_LOOP, "hw-loopback" }, \
528  { 0, NULL }, \
529 }
530
531 #endif /* _NET_IF_MEDIA_H_ */
Definition: if_var.h:99
Definition: if_media.h:291
