extern-ls.h File Reference
#include <sys/cdefs.h>
#include <setjmp.h>
Include dependency graph for extern-ls.h:
struct  rtems_shell_ls_globals
struct  DISPLAY
struct  NAMES
#define NO_PRINT   1
#define major(d)   rtems_filesystem_dev_major_t(d)
#define minor(d)   rtems_filesystem_dev_minor_t(d)
#define blocksize   globals->blocksize
#define termwidth   globals->termwidth
#define sortkey   globals->sortkey
#define rval   globals->rval
#define output   globals->output
#define now   globals->now
#define f_accesstime   globals->f_accesstime
#define f_column   globals->f_column
#define f_columnacross   globals->f_columnacross
#define f_flags   globals->f_flags
#define f_grouponly   globals->f_grouponly
#define f_humanize   globals->f_humanize
#define f_inode   globals->f_inode
#define f_listdir   globals->f_listdir
#define f_listdot   globals->f_listdot
#define f_longform   globals->f_longform
#define f_nonprint   globals->f_nonprint
#define f_nosort   globals->f_nosort
#define f_numericonly   globals->f_numericonly
#define f_octal   globals->f_octal
#define f_octal_escape   globals->f_octal_escape
#define f_recursive   globals->f_recursive
#define f_reversesort   globals->f_reversesort
#define f_sectime   globals->f_sectime
#define f_singlecol   globals->f_singlecol
#define f_size   globals->f_size
#define f_statustime   globals->f_statustime
#define f_stream   globals->f_stream
#define f_type   globals->f_type
#define f_typedir   globals->f_typedir
#define f_whiteout   globals->f_whiteout
#define exit_jump   &(globals->exit_jmp)
#define exit(ec)   rtems_shell_ls_exit(globals, ec)
#define acccmp   rtems_shell_ls_acccmp
#define revacccmp   rtems_shell_ls_revacccmp
#define modcmp   rtems_shell_ls_modcmp
#define revmodcmp   rtems_shell_ls_revmodcmp
#define namecmp   rtems_shell_ls_namecmp
#define revnamecmp   rtems_shell_ls_revnamecmp
#define statcmp   rtems_shell_ls_statcmp
#define revstatcmp   rtems_shell_ls_revstatcmp
#define sizecmp   rtems_shell_ls_sizecmp
#define revsizecmp   rtems_shell_ls_revsizecmp
#define printescaped   rtems_shell_ls_printescaped
#define printacol   rtems_shell_ls_printacol
#define printcol   rtems_shell_ls_printcol
#define printlong   rtems_shell_ls_printlong
#define printscol   rtems_shell_ls_printscol
#define printstream   rtems_shell_ls_printstream
#define usage   rtems_shell_ls_usage
const char * user_from_uid (uid_t uid, int nouser)
void rtems_shell_ls_exit (rtems_shell_ls_globals *globals, int code)
int acccmp (const FTSENT *, const FTSENT *)
int revacccmp (const FTSENT *, const FTSENT *)
int modcmp (const FTSENT *, const FTSENT *)
int revmodcmp (const FTSENT *, const FTSENT *)
int namecmp (const FTSENT *, const FTSENT *)
int revnamecmp (const FTSENT *, const FTSENT *)
int statcmp (const FTSENT *, const FTSENT *)
int revstatcmp (const FTSENT *, const FTSENT *)
int sizecmp (const FTSENT *, const FTSENT *)
int revsizecmp (const FTSENT *, const FTSENT *)
int printescaped (rtems_shell_ls_globals *globals, const char *)
void printacol (rtems_shell_ls_globals *globals, DISPLAY *)
void printcol (rtems_shell_ls_globals *globals, DISPLAY *)
void printlong (rtems_shell_ls_globals *globals, DISPLAY *)
void printscol (rtems_shell_ls_globals *globals, DISPLAY *)
void printstream (rtems_shell_ls_globals *globals, DISPLAY *)
int safe_print (rtems_shell_ls_globals *globals, const char *)
void usage (rtems_shell_ls_globals *globals)
void strmode (mode_t mode, char *p)
