extern-dd.h File Reference
#include <setjmp.h>
Include dependency graph for extern-dd.h:
struct  rtems_shell_dd_globals_t
#define in   globals->in
#define out   globals->out
#define st   globals->st
#define cfunc   globals->cfunc
#define cpy_cnt   globals->cpy_cnt
#define ddflags   globals->ddflags
#define cbsz   globals->cbsz
#define files_cnt   globals->files_cnt
#define casetab   globals->casetab
#define ctab   globals->ctab
#define fill_char   globals->fill_char
#define exit_jump   &(globals->exit_jmp)
#define block   rtems_shell_dd_block
#define block_close   rtems_shell_dd_block_close
#define dd_out   rtems_shell_dd_dd_out
#define def   rtems_shell_dd_def
#define def_close   rtems_shell_dd_def_close
#define jcl   rtems_shell_dd_jcl
#define pos_in   rtems_shell_dd_pos_in
#define pos_out   rtems_shell_dd_pos_out
#define summary   rtems_shell_dd_summary
#define summaryx   rtems_shell_dd_summaryx
#define terminate   rtems_shell_dd_terminate
#define unblock   rtems_shell_dd_unblock
#define unblock_close   rtems_shell_dd_unblock_close
#define exit(ec)   rtems_shell_dd_exit(globals, ec)
typedef struct rtems_shell_dd_globals_t rtems_shell_dd_globals
void block (rtems_shell_dd_globals *)
void block_close (rtems_shell_dd_globals *)
void dd_out (rtems_shell_dd_globals *, int)
void def (rtems_shell_dd_globals *globals)
void def_close (rtems_shell_dd_globals *)
void jcl (rtems_shell_dd_globals *, char **)
void pos_in (rtems_shell_dd_globals *)
void pos_out (rtems_shell_dd_globals *)
void summary (rtems_shell_dd_globals *)
void summaryx (rtems_shell_dd_globals *, int)
void terminate (int)
void unblock (rtems_shell_dd_globals *globals)
void unblock_close (rtems_shell_dd_globals *globals)
void rtems_shell_dd_exit (rtems_shell_dd_globals *globals, int code)
const u_char a2e_32V [256]
const u_char a2e_POSIX [256]
const u_char e2a_32V [256]
const u_char e2a_POSIX [256]
const u_char a2ibm_32V [256]
const u_char a2ibm_POSIX [256]
