extern-cp.h File Reference
#include <setjmp.h>
#include <sys/cdefs.h>
Include dependency graph for extern-cp.h:
struct  PATH_T
struct  rtems_shell_cp_globals
#define PATH_T   RTEMS_SHELL_CP_PATH_T
#define to   cp_globals->to
#define info   cp_globals->info
#define myuid   cp_globals->myuid
#define fflag   cp_globals->fflag
#define iflag   cp_globals->iflag
#define lflag   cp_globals->lflag
#define nflag   cp_globals->nflag
#define pflag   cp_globals->pflag
#define vflag   cp_globals->vflag
#define myumask   cp_globals->myumask
#define exit_jump   &(cp_globals->exit_jmp)
#define copy_fifo   rtems_shell_cp_copy_fifo
#define copy_file   rtems_shell_cp_copy_file
#define copy_link   rtems_shell_cp_copy_link
#define copy_special   rtems_shell_cp_copy_special
#define set_utimes   rtems_shell_cp_set_utimes
#define setfile   rtems_shell_cp_setfile
#define usage   rtems_shell_cp_usage
__BEGIN_DECLS int copy_fifo (rtems_shell_cp_globals *cp_globals, struct stat *, int)
int copy_file (rtems_shell_cp_globals *cp_globals, FTSENT *, int)
int copy_link (rtems_shell_cp_globals *cp_globals, FTSENT *, int)
int copy_special (rtems_shell_cp_globals *cp_globals, struct stat *, int)
int set_utimes (const char *, struct stat *)
int setfile (rtems_shell_cp_globals *cp_globals, struct stat *, int)
int preserve_dir_acls (struct stat *, char *, char *)
int preserve_fd_acls (int, int)
void usage (rtems_shell_cp_globals *cp_globals)
