score
cpu
epiphany
score
epiphany.h
1
5
6
* Copyright (c) 2015 University of York.
7
* Hesham ALMatary <hmka501@york.ac.uk>
8
9
* COPYRIGHT (c) 1989-1999, 2010.
10
* On-Line Applications Research Corporation (OAR).
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
22
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
25
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31
* SUCH DAMAGE.
32
33
34
#ifndef _RTEMS_SCORE_EPIPHANY_H
35
#define _RTEMS_SCORE_EPIPHANY_H
36
37
#ifdef __cplusplus
38
extern
"C"
39
#endif
40
41
42
* This file contains the information required to build
43
* RTEMS for a particular member of the Epiphany family.
44
* It does this by setting variables to indicate which
45
* implementation dependent features are present in a particular
46
* member of the family.
47
48
* This is a good place to list all the known CPU models
49
* that this port supports and which RTEMS CPU model they correspond
50
* to.
51
52
53
54
* Define the name of the CPU family and specific model.
55
56
57
#define CPU_NAME "EPIPHANY"
58
#define CPU_MODEL_NAME "EPIPHANY"
59
60
#ifdef __cplusplus
61
62
#endif
63
64
#endif
/* _RTEMS_SCORE_EPIPHANY_H */
