drvmgr_internal.h
1 /* Private driver manager declarations
2  *
3  * COPYRIGHT (c) 2009 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /* Structure hold all information the driver manager needs to know of. Used
11  * internally by Driver Manager routines.
12  */
13 struct drvmgr {
14  int level;
15  int initializing_objs;
16
17  /* Device tree Lock */
18  rtems_id lock;
19
20  /* The first device - The root device and it's driver */
21  struct drvmgr_drv *root_drv;
22  struct drvmgr_dev root_dev;
23
25  struct drvmgr_list drivers;
26
27  /* Buses that reached a certain initialization level.
28  * Lists by Level:
29  * N=0 - Not intialized, just registered
30  * N=1..MAX-1 - Reached init level N
31  * N=MAX - Successfully initialized bus
32  */
33  struct drvmgr_list buses[DRVMGR_LEVEL_MAX+1];
34  /* Buses failed to initialize or has been removed by not freed */
35  struct drvmgr_list buses_inactive;
36
37  /* Devices that reached a certain initialization level.
38  * Lists by Level:
39  * N=0 - Not intialized, just registered
40  * N=1..MAX-1 - Reached init level N
41  * N=MAX - Successfully initialized device
42  */
43  struct drvmgr_list devices[DRVMGR_LEVEL_MAX+1];
45  struct drvmgr_list devices_inactive;
46 };
47
48 extern struct drvmgr drvmgr;
49
50 extern void _DRV_Manager_Lock(void);
51 extern void _DRV_Manager_Unlock(void);
52 extern int _DRV_Manager_Init_Lock(void);
53
54 /* The best solution is to implement the locking with a RW lock, however there
55  * is no such API available. Care must be taken so that dead-lock isn't created
56  * for example in recursive functions.
57  */
58 #if defined(DRVMGR_USE_LOCKS) && (DRVMGR_USE_LOCKS == 1)
59  #define DRVMGR_LOCK_INIT() _DRV_Manager_Init_Lock()
60  #define DRVMGR_LOCK_WRITE() _DRV_Manager_Lock()
61  #define DRVMGR_LOCK_READ() _DRV_Manager_Lock()
62  #define DRVMGR_UNLOCK() _DRV_Manager_Unlock()
63 #else
64  /* no locking */
65  #define DRVMGR_LOCK_INIT()
66  #define DRVMGR_LOCK_WRITE()
67  #define DRVMGR_LOCK_READ()
68  #define DRVMGR_UNLOCK()
69 #endif
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:80
Linked list of all registered drivers.
Definition: drvmgr_internal.h:23
Devices failed to initialize, removed, ignored, no driver.
Definition: drvmgr_internal.h:44
Device information.
Definition: drvmgr.h:271
Definition: drvmgr_internal.h:14
Device driver description.
Definition: drvmgr.h:301
List description, Singly link list with head and tail pointers.
Definition: drvmgr_list.h:25
