IMFS Device Node Handlers. More...
int | device_open (rtems_libio_t *iop, const char *pathname, int oflag, mode_t mode) |
int | device_close (rtems_libio_t *iop) |
ssize_t | device_read (rtems_libio_t *iop, void *buffer, size_t count) |
ssize_t | device_write (rtems_libio_t *iop, const void *buffer, size_t count) |
int | device_ioctl (rtems_libio_t *iop, ioctl_command_t command, void *buffer) |
int | device_ftruncate (rtems_libio_t *iop, off_t length) |
