19 #ifndef _RTEMS_SCORE_COREBARRIER_H 20 #define _RTEMS_SCORE_COREBARRIER_H CORE_barrier_Disciplines
Flavors of barriers.
Definition: corebarrier.h:41
This is the structure used to manage sets of tasks which are blocked waiting to acquire a resource...
Definition: threadq.h:171
Constants and Structures Needed to Declare a Thread Queue.
This specifies that the barrier will automatically release when the user specified number of threads ...
Definition: corebarrier.h:45
CORE_barrier_Attributes Attributes
This element is the set of attributes which define this instance's behavior.
Definition: corebarrier.h:78
Thread_queue_Control Wait_queue
This field is the Waiting Queue used to manage the set of tasks which are blocked waiting for the bar...
Definition: corebarrier.h:74
uint32_t number_of_waiting_threads
This element contains the current number of thread waiting for this barrier to be released...
Definition: corebarrier.h:81
This specifies that the user will have to manually release the barrier in order to release the waitin...
Definition: corebarrier.h:49
The following defines the control block used to manage each barrier.
Definition: corebarrier.h:70
The following defines the control block used to manage the attributes of each barrier.
Definition: corebarrier.h:56
CORE_barrier_Disciplines discipline
This field indicates whether the barrier is automatic or manual.
Definition: corebarrier.h:59
uint32_t maximum_count
This element indicates the number of threads which must arrive at the barrier to trip the automatic r...
Definition: corebarrier.h:63
