clnt_stat.h
1 /* $FreeBSD: src/include/rpc/clnt_stat.h,v 1.2 2001/03/20 08:20:50 alfred Exp $ */
2 /*
3  * Copyright (c) 1986 - 1991, 1994, 1996, 1997 by Sun Microsystems, Inc.
4  * All rights reserved.
5  */
6
7 /*
8  * clnt_stat.h - Client side remote procedure call enum
9  *
10  */
11
12 #ifndef _RPC_CLNT_STAT_H
13 #define _RPC_CLNT_STAT_H
14
15 /* #pragma ident "@(#)clnt_stat.h 1.2 97/04/28 SMI" */
16
17 #ifdef __cplusplus
18 extern "C" {
19 #endif
20
21 enum clnt_stat {
22  RPC_SUCCESS = 0, /* call succeeded */
23  /*
24  * local errors
25  */
26  RPC_CANTENCODEARGS = 1, /* can't encode arguments */
27  RPC_CANTDECODERES = 2, /* can't decode results */
28  RPC_CANTSEND = 3, /* failure in sending call */
29  RPC_CANTRECV = 4,
30  /* failure in receiving result */
31  RPC_TIMEDOUT = 5, /* call timed out */
32  RPC_INTR = 18, /* call interrupted */
33  RPC_UDERROR = 23, /* recv got uderr indication */
34  /*
35  * remote errors
36  */
37  RPC_VERSMISMATCH = 6, /* rpc versions not compatible */
38  RPC_AUTHERROR = 7, /* authentication error */
39  RPC_PROGUNAVAIL = 8, /* program not available */
40  RPC_PROGVERSMISMATCH = 9, /* program version mismatched */
41  RPC_PROCUNAVAIL = 10, /* procedure unavailable */
42  RPC_CANTDECODEARGS = 11, /* decode arguments error */
43  RPC_SYSTEMERROR = 12, /* generic "other problem" */
44
45  /*
46  * rpc_call & clnt_create errors
47  */
48  RPC_UNKNOWNHOST = 13, /* unknown host name */
49  RPC_UNKNOWNPROTO = 17, /* unknown protocol */
50  RPC_UNKNOWNADDR = 19, /* Remote address unknown */
51  RPC_NOBROADCAST = 21, /* Broadcasting not supported */
52
53  /*
54  * rpcbind errors
55  */
56  RPC_RPCBFAILURE = 14, /* the pmapper failed in its call */
57 #define RPC_PMAPFAILURE RPC_RPCBFAILURE
58  RPC_PROGNOTREGISTERED = 15, /* remote program is not registered */
59  RPC_N2AXLATEFAILURE = 22,
60  /* Name to address translation failed */
61  /*
62  * Misc error in the TLI library
63  */
64  RPC_TLIERROR = 20,
65  /*
66  * unspecified error
67  */
68  RPC_FAILED = 16,
69  /*
70  * asynchronous errors
71  */
72  RPC_INPROGRESS = 24,
73  RPC_STALERACHANDLE = 25,
74  RPC_CANTCONNECT = 26, /* couldn't make connection (cots) */
75  RPC_XPRTFAILED = 27, /* received discon from remote (cots) */
76  RPC_CANTCREATESTREAM = 28, /* can't push rpc module (cots) */
77  _CLNT_STAT = 0xffffffff
78 };
79
80 #ifdef __cplusplus
81 }
82 #endif
83
84 #endif /* !_RPC_CLNT_STAT_H */
