cfg_peripheral.h
1 /* PCI Peripheral Configuration Library
2  *
3  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 #ifndef __PCI_CFG_PERIPHERAL_H__
11 #define __PCI_CFG_PERIPHERAL_H__
12
13 /* The user must provide a PCI configuration using the "struct pci_bus pci_hb"
14  * structure. Nothing else than setting pci_system_type and pci_bus_cnt is done
15  * by the peripheral library.
16  */
17 extern int pci_config_peripheral(void);
18
19 #endif
