cfg.h
1 /* PCI Configuration Library
2  *
3  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10 /* Four versions of the library exists:
11  * - auto configuration (default)
12  * - read configuration from PnP (inherit BIOS set up)
13  * - static configuration (user defined config)
14  * - peripheral configuration, no CFG space accesses are possible instead a
15  * device tree known at compile-time have been built in.
16  * all versions are defined through here.
17  */
18
19 #ifndef __PCI_CFG_H__
20 #define __PCI_CFG_H__
21
22 #include <pci.h>
23
24 /* PCI Configuration library */
25
26 /* Return the number of PCI buses in system */
27 extern int pci_bus_count(void);
28
29 /* PCI Address assigned to BARs which failed to fit into the PCI Window or
30  * is disabled by any other cause.
31  */
32 extern uint32_t pci_invalid_address;
33
34 /* PCI Configuration Library of the system */
35 enum {
36  PCI_CONFIG_LIB_NONE = 0,
37  PCI_CONFIG_LIB_AUTO = 1,
38  PCI_CONFIG_LIB_STATIC = 2,
39  PCI_CONFIG_LIB_READ = 3,
40  PCI_CONFIG_LIB_PERIPHERAL = 4,
41 };
42 extern const int pci_config_lib_type;
43
44 /* Configuration library function pointers, these are set in <rtems/confdefs.h>
45  * by project configuration or by the BSP. The configuration will pull in the
46  * PCI Library needed and the PCI initialization functions will call these
47  * functions on initialization from the host driver.
48  */
49 extern int (*pci_config_lib_init)(void);
50 extern void (*pci_config_lib_register)(void *config);
51
52 /* Configure PCI devices and bridges, and setup the RAM data structures
53  * describing the PCI devices currently present in the system.
54  *
55  * Returns 0 on success, -1 on failure.
56  */
57 extern int pci_config_init(void);
58
59 /* Register a config-library specific configuration used by the libarary in
60  * pci_config_init().
61  */
62 extern void pci_config_register(void *config);
63
64 /* Print current PCI configuration (C-code) to terminal, can be used in
65  * static and peripheral PCI configuration library. The configuration is
66  * taken from the current configuration library setup.
67  */
68 extern void pci_cfg_print(void);
69
70 struct pci_bus; /* Bridge Device and secondary bus information */
71 struct pci_dev; /* Device/function */
72 struct pci_res; /* Resource: BAR, ROM or Bridge Window */
73
74 /* The Host Bridge and all subdevices (the PCI RAM data structure) */
75 extern struct pci_bus pci_hb;
76
77 /* Arguments for pci_for_each_child() search option */
78 #define SEARCH_CHILDREN 0 /* direct children of bus only */
79 #define SEARCH_DEPTH 1 /* all children of bus */
80
81 /* Iterate over all PCI devices on a bus (see search options) and call func(),
82  * iteration is stopped if a non-zero value is returned by func().
83  *
84  * The function iterates over the PCI RAM data structure, it is not
85  * available until after all devices have been found and pci_hb is populated,
86  * typically after pci_config_init() is called.
87  *
88  * search options: 0 (no child buses), 1 (depth first, recursive)
89  *
90  * Return Values
91  * 0 All PCI devices were processed, func() returned 0 on every call
92  * X func() returned non-zero X value, the search was stopped
93  */
94 extern int pci_for_each_child(
95  struct pci_bus *bus,
96  int (*func)(struct pci_dev *, void *arg),
97  void *arg,
98  int search);
99
100 /* Depth first search of all PCI devices in PCI RAM data structure and call
101  * func(dev, arg), iteration is stopped if a non-zero value is returned by
102  * func().
103  *
104  * The function iterates over the PCI RAM data structure, it is not
105  * available until after all devices have been found and pci_hb is populated,
106  * typically after pci_config_init() is called.
107  *
108  * Return Values
109  * 0 All PCI devices were processed, func() returned 0 on every call
110  * X func() returned non-zero X value, the search was stopped
111  */
112 extern int pci_for_each_dev(
113  int (*func)(struct pci_dev *, void *arg),
114  void *arg);
115
116 /* Get PCI device from RAM device tree for a device matching PCI Vendor, Device
117  * and instance number 'index'.
118  *
119  * Return Values
120  * -1 pci_find_dev did not find a device matching the criterion.
121  * 0 device was found, *ppdev was updated with the PCI device address
122  */
123 extern int pci_find_dev(uint16_t ven, uint16_t dev, int index,
124  struct pci_dev **ppdev);
125
126 /* Get PCI device from RAM device tree by BUS|SLOT|FUNC.
127  *
128  * Return Values
129  * -1 pci_get_dev did not find a device matching the criterion
130  * 0 device was found, *ppdev was updated with the PCI device address
131  */
132 extern int pci_get_dev(pci_dev_t pcidev, struct pci_dev **ppdev);
133
134 /* Resource flags */
135 #define PCI_RES_IO 1
136 #define PCI_RES_MEMIO 2
137 #define PCI_RES_MEM_PREFETCH 1
138 #define PCI_RES_MEM (PCI_RES_MEMIO | PCI_RES_MEM_PREFETCH)
139 #define PCI_RES_TYPE_MASK 0x3
140 #define PCI_RES_IO32 0x08
141 #define PCI_RES_FAIL 0x10 /* Alloc Failed */
142
143 /* BAR Resouces entry */
144 struct pci_res {
145  struct pci_res *next;
146  uint32_t size;
147  uint32_t boundary;
148  unsigned char flags; /* I/O, MEM or MEMIO */
149  unsigned char bar;
150
151  /* Assigned Resource (PCI address), zero if not assigned */
152  uint32_t start;
153  uint32_t end;
154 };
155
156 /* Get Device from resource pointer. bar is the index of the pci_dev.resources
157  * array and used to get the device base address of which the resource is
158  * associated with.
159  */
160 #define RES2DEV(res) ((struct pci_dev *) \
161  ((uintptr_t)res - (uintptr_t)(res->bar * (sizeof(struct pci_res)))))
162
163 /* Device flags */
164 #define PCI_DEV_BRIDGE 0x01 /* Device is a Bridge (struct pci_bus) */
165 #define PCI_DEV_RES_FAIL 0x02 /* Resource alloction for device BARs failed */
166
167 /* Bus Flags */
168 #define PCI_BUS_IO 0x01 /* 16-bit I/O address decoding */
169 #define PCI_BUS_MEMIO 0x02 /* Bus support non-prefetchable mem (always) */
170 #define PCI_BUS_MEM 0x04 /* Bus support prefetchable memory space */
171 #define PCI_BUS_IO32 0x08 /* 32-bit I/O address decoding */
172
173 #define BRIDGE_RES_COUNT 2 /* Number of BAR resources a bridge can have */
174 #define BUS_RES_START BRIDGE_RES_COUNT
175
176 /* Bus Resources Array */
177 enum {
178  BUS_RES_IO = 0,
179  BUS_RES_MEMIO = 1,
180  BUS_RES_MEM = 2,
181 };
182
183 /* Device Resource array index meaning */
184 enum {
185  /* A Device has up to 6 BARs and an optional ROM BAR */
186  DEV_RES_BAR1 = 0,
187  DEV_RES_BAR2 = 1,
188  DEV_RES_BAR3 = 2,
189  DEV_RES_BAR4 = 3,
190  DEV_RES_BAR5 = 4,
191  DEV_RES_BAR6 = 5,
192  DEV_RES_ROM = 6,
193
194  /* Bridges have 2 BARs (BAR1 and BAR2) and 3 Windows to secondary bus
195  * and an optional ROM BAR
196  */
197  BRIDGE_RES_BAR1 = 0,
198  BRIDGE_RES_BAR2 = 1,
199  BRIDGE_RES_IO = 2,
200  BRIDGE_RES_MEMIO = 3,
201  BRIDGE_RES_MEM = 4,
202  BRIDGE_RES_UNUSED1 = 5,
203  BRIDGE_RES_ROM = 6,
204 };
205
206 /* Maximum Number of Resources of a device */
207 #define DEV_RES_CNT (DEV_RES_ROM + 1)
208
209 /* PCI Device (Bus|Slot|Function) description */
210 struct pci_dev {
211  struct pci_res resources[DEV_RES_CNT]; /* must be topmost field */
212  struct pci_dev *next;
213  struct pci_bus *bus;
214  pci_dev_t busdevfun;
215  uint8_t flags;
216  uint8_t sysirq;
217  uint16_t vendor;
218  uint16_t device;
219  uint16_t subvendor;
220  uint16_t subdevice;
221  uint32_t classrev;
222
223  /* static configuration settings */
224  uint16_t command;
225 };
226
227 /* PCI Bus description */
228 struct pci_bus {
229  struct pci_dev dev; /* PCI Bridge */
230  struct pci_dev *devs; /* Devices on child (secondary) Bus */
231  unsigned int flags;
232
233  /* Bridge Information */
234  int num; /* Bus number (0=Root-PCI-bus) */
235  int pri; /* Primary Bus Number */
236  int sord; /* Subordinate Buses (Child bus count) */
237
238 #if defined(PCI_CFG_AUTO_LIB)
239  /* Resources of devices on bus. USED INTERNALLY IN AUTO-CFG LIBRARY.
240  *
241  * BUS_RES_IO = 0: I/O resources
242  * BUS_RES_MEMIO = 1: Prefetchable memory resources
243  * BUS_RES_MEM = 2: Non-Prefetchable memory resources
244  */
245  struct pci_res *busres[3];
246 #endif
247 };
248
249 #include <pci/cfg_auto.h>
250 #include <pci/cfg_static.h>
251 #include <pci/cfg_read.h>
252 #include <pci/cfg_peripheral.h>
253
254 #endif
Definition: deflate.c:116
Definition: cfg.h:229
Definition: cfg.h:145
Definition: cfg.h:211
