libdl
include
sys
cdefs_elf.h
1
/* $NetBSD: cdefs_elf.h,v 1.24 2005/07/16 17:53:36 christos Exp $ */
2
3
4
* Copyright (c) 1995, 1996 Carnegie-Mellon University.
5
* All rights reserved.
6
7
* Author: Chris G. Demetriou
8
9
* Permission to use, copy, modify and distribute this software and
10
* its documentation is hereby granted, provided that both the copyright
11
* notice and this permission notice appear in all copies of the
12
* software, derivative works or modified versions, and any portions
13
* thereof, and that both notices appear in supporting documentation.
14
15
* CARNEGIE MELLON ALLOWS FREE USE OF THIS SOFTWARE IN ITS "AS IS"
16
* CONDITION. CARNEGIE MELLON DISCLAIMS ANY LIABILITY OF ANY KIND
17
* FOR ANY DAMAGES WHATSOEVER RESULTING FROM THE USE OF THIS SOFTWARE.
18
19
* Carnegie Mellon requests users of this software to return to
20
21
* Software Distribution Coordinator or Software.Distribution@CS.CMU.EDU
22
* School of Computer Science
23
* Carnegie Mellon University
24
* Pittsburgh PA 15213-3890
25
26
* any improvements or extensions that they make and grant Carnegie the
27
* rights to redistribute these changes.
28
29
30
#ifndef _SYS_CDEFS_ELF_H_
31
#define _SYS_CDEFS_ELF_H_
32
33
#ifdef __LEADING_UNDERSCORE
34
#define _C_LABEL(x) __CONCAT(_,x)
35
#define _C_LABEL_STRING(x) "_"x
36
#else
37
#define _C_LABEL(x) x
38
#define _C_LABEL_STRING(x) x
39
#endif
40
41
#if __STDC__
42
#define ___RENAME(x) __asm__(___STRING(_C_LABEL(x)))
43
#else
44
45
#define ___RENAME(x) ____RENAME(_x)
46
#define ____RENAME(x) __asm__(___STRING(x))
47
#else
48
#define ___RENAME(x) __asm__(___STRING(x))
49
#endif
50
#endif
51
52
#define __indr_reference(sym,alias)
/* nada, since we do weak refs */
53
54
#if __STDC__
55
#define __strong_alias(alias,sym) \
56
__asm__(".global " _C_LABEL_STRING(#alias) "\n" \
57
_C_LABEL_STRING(#alias) " = " _C_LABEL_STRING(#sym));
58
59
#define __weak_alias(alias,sym) \
60
__asm__(".weak " _C_LABEL_STRING(#alias) "\n" \
61
62
#define __weak_extern(sym) \
63
__asm__(".weak " _C_LABEL_STRING(#sym));
64
#define __warn_references(sym,msg) \
65
__asm__(".section .gnu.warning." #sym "\n\t.ascii \"" msg "\"\n\t.text");
66
67
#else
/* !__STDC__ */
68
69
70
#define __weak_alias(alias,sym) ___weak_alias(_alias,_sym)
71
#define ___weak_alias(alias,sym) \
72
__asm__(".weak alias\nalias = sym");
73
#else
74
75
76
#endif
77
78
#define __weak_extern(sym) ___weak_extern(_sym)
79
#define ___weak_extern(sym) \
80
__asm__(".weak sym");
81
#else
82
83
84
#endif
85
86
__asm__(".section .gnu.warning.sym\n\t.ascii msg ; .text");
87
88
#endif
/* !__STDC__ */
89
90
#if __STDC__
91
#define __SECTIONSTRING(_sec, _str) \
92
__asm__(".section " #_sec "\n\t.asciz \"" _str "\"\n\t.previous")
93
#else
94
95
__asm__(".section _sec\n\t.asciz _str\n\t.previous")
96
#endif
97
98
#define __IDSTRING(_n,_s) __SECTIONSTRING(.ident,_s)
99
100
#define __RCSID(_s) __IDSTRING(rcsid,_s)
101
#define __SCCSID(_s)
102
#define __SCCSID2(_s)
103
#if 0
/* XXX userland __COPYRIGHTs have \ns in them */
104
#define __COPYRIGHT(_s) __SECTIONSTRING(.copyright,_s)
105
#else
106
#define __COPYRIGHT(_s) \
107
static const char copyright[] \
108
__attribute__((__unused__,__section__(".copyright"))) = _s
109
#endif
110
111
#define __KERNEL_RCSID(_n, _s) __RCSID(_s)
112
#define __KERNEL_SCCSID(_n, _s)
113
#if 0
/* XXX see above */
114
#define __KERNEL_COPYRIGHT(_n, _s) __COPYRIGHT(_s)
115
#else
116
#define __KERNEL_COPYRIGHT(_n, _s) __SECTIONSTRING(.copyright, _s)
117
#endif
118
119
#ifndef __lint__
120
#define __link_set_make_entry(set, sym) \
121
static void const * const __link_set_##set##_sym_##sym \
122
__section("link_set_" #set) __used = &sym
123
#define __link_set_make_entry2(set, sym, n) \
124
static void const * const __link_set_##set##_sym_##sym##_##n \
125
__section("link_set_" #set) __used = &sym[n]
126
#else
127
128
extern void const * const __link_set_##set##_sym_##sym
129
130
extern void const * const __link_set_##set##_sym_##sym##_##n
131
#endif
/* __lint__ */
132
133
#define __link_set_add_text(set, sym) __link_set_make_entry(set, sym)
134
#define __link_set_add_rodata(set, sym) __link_set_make_entry(set, sym)
135
#define __link_set_add_data(set, sym) __link_set_make_entry(set, sym)
136
#define __link_set_add_bss(set, sym) __link_set_make_entry(set, sym)
137
#define __link_set_add_text2(set, sym, n) __link_set_make_entry2(set, sym, n)
138
#define __link_set_add_rodata2(set, sym, n) __link_set_make_entry2(set, sym, n)
139
#define __link_set_add_data2(set, sym, n) __link_set_make_entry2(set, sym, n)
140
#define __link_set_add_bss2(set, sym, n) __link_set_make_entry2(set, sym, n)
141
142
#define __link_set_decl(set, ptype) \
143
extern ptype * const __start_link_set_##set[]; \
144
extern ptype * const __stop_link_set_##set[] \
145
146
#define __link_set_start(set) (__start_link_set_##set)
147
#define __link_set_end(set) (__stop_link_set_##set)
148
149
#define __link_set_count(set) \
150
(__link_set_end(set) - __link_set_start(set))
151
152
#endif
/* !_SYS_CDEFS_ELF_H_ */
