ccp.h
1 /*
2  * ccp.h - Definitions for PPP Compression Control Protocol.
3  *
4  * Copyright (c) 1994 The Australian National University.
5  * All rights reserved.
6  *
7  * Permission to use, copy, modify, and distribute this software and its
8  * documentation is hereby granted, provided that the above copyright
9  * notice appears in all copies. This software is provided without any
10  * warranty, express or implied. The Australian National University
11  * makes no representations about the suitability of this software for
12  * any purpose.
13  *
14  * IN NO EVENT SHALL THE AUSTRALIAN NATIONAL UNIVERSITY BE LIABLE TO ANY
15  * PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES
16  * ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
17  * THE AUSTRALIAN NATIONAL UNIVERSITY HAVE BEEN ADVISED OF THE POSSIBILITY
18  * OF SUCH DAMAGE.
19  *
20  * THE AUSTRALIAN NATIONAL UNIVERSITY SPECIFICALLY DISCLAIMS ANY WARRANTIES,
21  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
22  * AND FITNESS FOR A PARTICULAR PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS
23  * ON AN "AS IS" BASIS, AND THE AUSTRALIAN NATIONAL UNIVERSITY HAS NO
24  * OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS,
25  * OR MODIFICATIONS.
26  *
27  * $Id$
28  */
29
30 typedef struct ccp_options {
31  bool bsd_compress; /* do BSD Compress? */
32  bool deflate; /* do Deflate? */
33  bool predictor_1; /* do Predictor-1? */
34  bool predictor_2; /* do Predictor-2? */
35  bool deflate_correct; /* use correct code for deflate? */
36  bool deflate_draft; /* use draft RFC code for deflate? */
37  u_short bsd_bits; /* # bits/code for BSD Compress */
38  u_short deflate_size; /* lg(window size) for Deflate */
39  short method; /* code for chosen compression method */
40 } ccp_options;
41
42 extern fsm ccp_fsm[];
43 extern ccp_options ccp_wantoptions[];
44 extern ccp_options ccp_gotoptions[];
45 extern ccp_options ccp_allowoptions[];
46 extern ccp_options ccp_hisoptions[];
47
48 extern struct protent ccp_protent;
Definition: fsm.h:44
Definition: ccp.h:31
Definition: pppd.h:250
