bpf.h
1 /*
2  * Copyright (c) 1990, 1991, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * This code is derived from the Stanford/CMU enet packet filter,
6  * (net/enet.c) distributed as part of 4.3BSD, and code contributed
7  * to Berkeley by Steven McCanne and Van Jacobson both of Lawrence
8  * Berkeley Laboratory.
9  *
10  * Redistribution and use in source and binary forms, with or without
11  * modification, are permitted provided that the following conditions
12  * are met:
13  * 1. Redistributions of source code must retain the above copyright
14  * notice, this list of conditions and the following disclaimer.
15  * 2. Redistributions in binary form must reproduce the above copyright
16  * notice, this list of conditions and the following disclaimer in the
17  * documentation and/or other materials provided with the distribution.
18  * 3. All advertising materials mentioning features or use of this software
19  * must display the following acknowledgement:
20  * This product includes software developed by the University of
21  * California, Berkeley and its contributors.
22  * 4. Neither the name of the University nor the names of its contributors
23  * may be used to endorse or promote products derived from this software
24  * without specific prior written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
27  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
30  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
31  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
32  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
33  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
34  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
35  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
36  * SUCH DAMAGE.
37  *
38  * @(#)bpf.h 8.1 (Berkeley) 6/10/93
39  * @(#)bpf.h 1.34 (LBL) 6/16/96
40  */
41
42 #ifndef _NET_BPF_H_
43 #define _NET_BPF_H_
44
45 #include <sys/time.h> /* struct timeval */
46
47 /* BSD style release date */
48 #define BPF_RELEASE 199606
49
50 typedef int32_t bpf_int32;
51 typedef u_int32_t bpf_u_int32;
52
53 /*
54  * Alignment macros. BPF_WORDALIGN rounds up to the next
55  * even multiple of BPF_ALIGNMENT.
56  */
57 #define BPF_ALIGNMENT sizeof(bpf_int32)
58 #define BPF_WORDALIGN(x) (((x)+(BPF_ALIGNMENT-1))&~(BPF_ALIGNMENT-1))
59
60 #define BPF_MAXINSNS 512
61 #define BPF_MAXBUFSIZE 0x8000
62 #define BPF_MINBUFSIZE 32
63
64 /*
65  * Structure for BIOCSETF.
66  */
67 struct bpf_program {
68  u_int bf_len;
69  struct bpf_insn *bf_insns;
70 };
71
72 /*
73  * Struct returned by BIOCGSTATS.
74  */
75 struct bpf_stat {
76  u_int bs_recv; /* number of packets received */
77  u_int bs_drop; /* number of packets dropped */
78 };
79
80 /*
81  * Struct return by BIOCVERSION. This represents the version number of
82  * the filter language described by the instruction encodings below.
83  * bpf understands a program iff kernel_major == filter_major &&
84  * kernel_minor >= filter_minor, that is, if the value returned by the
85  * running kernel has the same major number and a minor number equal
86  * equal to or less than the filter being downloaded. Otherwise, the
87  * results are undefined, meaning an error may be returned or packets
88  * may be accepted haphazardly.
89  * It has nothing to do with the source code version.
90  */
91 struct bpf_version {
92  u_short bv_major;
93  u_short bv_minor;
94 };
95 /* Current version number of filter architecture. */
96 #define BPF_MAJOR_VERSION 1
97 #define BPF_MINOR_VERSION 1
98
99 #define BIOCGBLEN _IOR('B',102, u_int)
100 #define BIOCSBLEN _IOWR('B',102, u_int)
101 #define BIOCSETF _IOW('B',103, struct bpf_program)
102 #define BIOCFLUSH _IO('B',104)
103 #define BIOCPROMISC _IO('B',105)
104 #define BIOCGDLT _IOR('B',106, u_int)
105 #define BIOCGETIF _IOR('B',107, struct ifreq)
106 #define BIOCSETIF _IOW('B',108, struct ifreq)
107 #define BIOCSRTIMEOUT _IOW('B',109, struct timeval)
108 #define BIOCGRTIMEOUT _IOR('B',110, struct timeval)
109 #define BIOCGSTATS _IOR('B',111, struct bpf_stat)
110 #define BIOCIMMEDIATE _IOW('B',112, u_int)
111 #define BIOCVERSION _IOR('B',113, struct bpf_version)
112 #define BIOCGRSIG _IOR('B',114, u_int)
113 #define BIOCSRSIG _IOW('B',115, u_int)
114
115 /*
116  * Structure prepended to each packet.
117  */
118 struct bpf_hdr {
119  struct timeval bh_tstamp; /* time stamp */
120  bpf_u_int32 bh_caplen; /* length of captured portion */
121  bpf_u_int32 bh_datalen; /* original length of packet */
122  u_short bh_hdrlen; /* length of bpf header (this struct
123  plus alignment padding) */
124 };
125 /*
126  * Because the structure above is not a multiple of 4 bytes, some compilers
127  * will insist on inserting padding; hence, sizeof(struct bpf_hdr) won't work.
128  * Only the kernel needs to know about it; applications use bh_hdrlen.
129  */
130 #ifdef _KERNEL
131 #define SIZEOF_BPF_HDR 18
132 #endif
133
134 /*
135  * Data-link level type codes.
136  */
137 #define DLT_NULL 0 /* no link-layer encapsulation */
138 #define DLT_EN10MB 1 /* Ethernet (10Mb) */
139 #define DLT_EN3MB 2 /* Experimental Ethernet (3Mb) */
140 #define DLT_AX25 3 /* Amateur Radio AX.25 */
141 #define DLT_PRONET 4 /* Proteon ProNET Token Ring */
142 #define DLT_CHAOS 5 /* Chaos */
143 #define DLT_IEEE802 6 /* IEEE 802 Networks */
144 #define DLT_ARCNET 7 /* ARCNET */
145 #define DLT_SLIP 8 /* Serial Line IP */
146 #define DLT_PPP 9 /* Point-to-point Protocol */
147 #define DLT_FDDI 10 /* FDDI */
148 #define DLT_ATM_RFC1483 11 /* LLC/SNAP encapsulated atm */
149
150 /*
151  * The instruction encodings.
152  */
153 /* instruction classes */
154 #define BPF_CLASS(code) ((code) & 0x07)
155 #define BPF_LD 0x00
156 #define BPF_LDX 0x01
157 #define BPF_ST 0x02
158 #define BPF_STX 0x03
159 #define BPF_ALU 0x04
160 #define BPF_JMP 0x05
161 #define BPF_RET 0x06
162 #define BPF_MISC 0x07
163
164 /* ld/ldx fields */
165 #define BPF_SIZE(code) ((code) & 0x18)
166 #define BPF_W 0x00
167 #define BPF_H 0x08
168 #define BPF_B 0x10
169 #define BPF_MODE(code) ((code) & 0xe0)
170 #define BPF_IMM 0x00
171 #define BPF_ABS 0x20
172 #define BPF_IND 0x40
173 #define BPF_MEM 0x60
174 #define BPF_LEN 0x80
175 #define BPF_MSH 0xa0
176
177 /* alu/jmp fields */
178 #define BPF_OP(code) ((code) & 0xf0)
179 #define BPF_ADD 0x00
180 #define BPF_SUB 0x10
181 #define BPF_MUL 0x20
182 #define BPF_DIV 0x30
183 #define BPF_OR 0x40
184 #define BPF_AND 0x50
185 #define BPF_LSH 0x60
186 #define BPF_RSH 0x70
187 #define BPF_NEG 0x80
188 #define BPF_JA 0x00
189 #define BPF_JEQ 0x10
190 #define BPF_JGT 0x20
191 #define BPF_JGE 0x30
192 #define BPF_JSET 0x40
193 #define BPF_SRC(code) ((code) & 0x08)
194 #define BPF_K 0x00
195 #define BPF_X 0x08
196
197 /* ret - BPF_K and BPF_X also apply */
198 #define BPF_RVAL(code) ((code) & 0x18)
199 #define BPF_A 0x10
200
201 /* misc */
202 #define BPF_MISCOP(code) ((code) & 0xf8)
203 #define BPF_TAX 0x00
204 #define BPF_TXA 0x80
205
206 /*
207  * The instruction data structure.
208  */
209 struct bpf_insn {
210  u_short code;
211  u_char jt;
212  u_char jf;
213  bpf_u_int32 k;
214 };
215
216 /*
217  * Macros for insn array initializers.
218  */
219 #define BPF_STMT(code, k) { (u_short)(code), 0, 0, k }
220 #define BPF_JUMP(code, k, jt, jf) { (u_short)(code), jt, jf, k }
221
222 #ifdef _KERNEL
223 int bpf_validate(struct bpf_insn *, int);
224 void bpf_tap(struct ifnet *, u_char *, u_int);
225 void bpf_mtap(struct ifnet *, struct mbuf *);
226 void bpfattach(struct ifnet *, u_int, u_int);
227 void bpfilterattach(int);
228 u_int bpf_filter(const struct bpf_insn *, u_char *, u_int, u_int);
229 #endif
230
231 /*
232  * Number of scratch memory words (for BPF_LD|BPF_MEM and BPF_ST).
233  */
234 #define BPF_MEMWORDS 16
235
236 #endif /* _NET_BPF_H_ */
Definition: bpf.h:210
Definition: bpf.h:76
Definition: bpf.h:68
Definition: if_var.h:99
Definition: mbuf.h:103
Definition: inftrees.h:25
Definition: bpf.h:119
Definition: bpf.h:92
