asm.h
1
17 /*
18  * COPYRIGHT:
19  *
20  * This file is based on similar code found in newlib available
21  * from ftp.cygnus.com. The file which was used had no copyright
22  * notice. This file is freely distributable as long as the source
23  * of the file is noted. This file is:
24  *
25  * COPYRIGHT (c) 1994-2006.
26  * On-Line Applications Research Corporation (OAR).
27  */
28
29 #ifndef _RTEMS_ASM_H
30 #define _RTEMS_ASM_H
31
32 /*
33  * Indicate we are in an assembly file and get the basic CPU definitions.
34  */
35
36 #ifndef ASM
37 #define ASM
38 #endif
39 #include <rtems/score/cpuopts.h>
40 #include <rtems/score/bfin.h>
41
42 #ifndef __USER_LABEL_PREFIX__
43
51 #define __USER_LABEL_PREFIX__ _
52 #endif
53
54 #ifndef __REGISTER_PREFIX__
55
63 #define __REGISTER_PREFIX__
64 #endif
65
66 #include <rtems/concat.h>
67
69 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
70
72 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
73
74 /*
75  * define macros for all of the registers on this CPU
76  *
77  * EXAMPLE: #define d0 REG (d0)
78  */
79
80 /*
81  * Define macros to handle section beginning and ends.
82  */
83
84
86 #define BEGIN_CODE_DCL .text
87
88 #define END_CODE_DCL
89
90 #define BEGIN_DATA_DCL .data
91
92 #define END_DATA_DCL
93
94 #define BEGIN_CODE .text
95
96 #define END_CODE
97
98 #define BEGIN_DATA
99
100 #define END_DATA
101
105 #define BEGIN_BSS
106
107 #define END_BSS
108
109 #define END
110
117 #define PUBLIC(sym) .globl SYM (sym)
118
125 #define EXTERN(sym) .globl SYM (sym)
126
127 #endif
Blackfin Set up Basic CPU Dependency Settings Based on Compiler Settings.
This include file defines ANSI concatenation macros.
