Functions | Variables
barriertranslatereturncode.c File Reference
Translate SuperCore Barrier Status Code to RTEMS Status Code. More...
#include <rtems/rtems/barrierimpl.h>
Include dependency graph for barriertranslatereturncode.c:
rtems_status_code _Barrier_Translate_core_barrier_return_code (CORE_barrier_Status the_barrier_status)
rtems_status_code _Barrier_Translate_core_barrier_return_code_ []
Variable Documentation
◆ _Barrier_Translate_core_barrier_return_code_
rtems_status_code _Barrier_Translate_core_barrier_return_code_[]
Initial value:
This is the status to indicate that a blocking directive timed out.
Definition: status.h:75
This is the status to indicate successful completion.
Definition: status.h:50
This is the status to indicate the the object was deleted while the task was blocked waiting...
Definition: status.h:80
