score
cpu
avr
score
avr.h
1
13
14
* COPYRIGHT 2004, Ralf Corsepius, Ulm, Germany.
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
22
#ifndef _RTEMS_SCORE_AVR_H
23
#define _RTEMS_SCORE_AVR_H
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
29
30
* This file contains the information required to build
31
* RTEMS for a particular member of the NO CPU family.
32
* It does this by setting variables to indicate which
33
* implementation dependent features are present in a particular
34
* member of the family.
35
36
* This is a good place to list all the known CPU models
37
* that this port supports and which RTEMS CPU model they correspond
38
* to.
39
40
41
42
* Figure out all CPU Model Feature Flags based upon compiler
43
* predefines.
44
45
#if defined(__AVR__)
46
47
#if defined(__AVR_ARCH__)
48
#if __AVR_ARCH__ == 1
49
#define CPU_MODEL_NAME "avr1"
50
#define AVR_HAS_FPU 1
51
52
#elif __AVR_ARCH__ == 2
53
#define CPU_MODEL_NAME "avr2"
54
55
56
#elif __AVR_ARCH__ == 3
57
#define CPU_MODEL_NAME "avr3"
58
59
60
#elif __AVR_ARCH__ == 4
61
#define CPU_MODEL_NAME "avr4"
62
63
64
#elif __AVR_ARCH__ == 5
65
#define CPU_MODEL_NAME "avr5"
66
67
68
#elif __AVR_ARCH__ == 25
69
#define CPU_MODEL_NAME "avr25"
70
71
72
#elif __AVR_ARCH__ == 31
73
#define CPU_MODEL_NAME "avr31"
74
75
76
#elif __AVR_ARCH__ == 35
77
#define CPU_MODEL_NAME "avr35"
78
79
80
#elif __AVR_ARCH__ == 51
81
#define CPU_MODEL_NAME "avr51"
82
83
84
#elif __AVR_ARCH__ == 6
85
#define CPU_MODEL_NAME "avr6"
86
87
88
#else
89
#error "Unsupported __AVR_ARCH__"
90
#endif
91
#else
92
#error "__AVR_ARCH__ undefined"
93
#endif
94
95
#else
96
97
#error "Unsupported CPU Model"
98
99
#endif
100
101
102
* Define the name of the CPU family.
103
104
105
#define CPU_NAME "avr"
106
107
#ifdef __cplusplus
108
109
#endif
110
111
#endif
/* _RTEMS_SCORE_AVR_H */
