auth.h
1 /*
2  * Sun RPC is a product of Sun Microsystems, Inc. and is provided for
3  * unrestricted use provided that this legend is included on all tape
4  * media and as a part of the software program in whole or part. Users
5  * may copy or modify Sun RPC without charge, but are not authorized
6  * to license or distribute it to anyone else except as part of a product or
7  * program developed by the user.
8  *
9  * SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
10  * WARRANTIES OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR
11  * PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
12  *
13  * Sun RPC is provided with no support and without any obligation on the
14  * part of Sun Microsystems, Inc. to assist in its use, correction,
15  * modification or enhancement.
16  *
17  * SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
18  * INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
19  * OR ANY PART THEREOF.
20  *
21  * In no event will Sun Microsystems, Inc. be liable for any lost revenue
22  * or profits or other special, indirect and consequential damages, even if
23  * Sun has been advised of the possibility of such damages.
24  *
25  * Sun Microsystems, Inc.
26  * 2550 Garcia Avenue
27  * Mountain View, California 94043
28  *
29  * from: @(#)auth.h 1.17 88/02/08 SMI
30  * from: @(#)auth.h 2.3 88/08/07 4.0 RPCSRC
31  * $FreeBSD: src/include/rpc/auth.h,v 1.15 1999/08/27 23:45:02 peter Exp $
32  */
33
34 /*
35  * auth.h, Authentication interface.
36  *
37  * Copyright (C) 1984, Sun Microsystems, Inc.
38  *
39  * The data structures are completely opaque to the client. The client
40  * is required to pass a AUTH * to routines that create rpc
41  * "sessions".
42  */
43
44 #ifndef _RPC_AUTH_H
45 #define _RPC_AUTH_H
46 #include <sys/cdefs.h>
47 #include <sys/socket.h>
48 #include <rpc/xdr.h>
49
50 #define MAX_AUTH_BYTES 400
51 #define MAXNETNAMELEN 255 /* maximum length of network user's name */
52
53 /*
54  * Status returned from authentication check
55  */
56 enum auth_stat {
57  AUTH_OK=0,
58  /*
59  * failed at remote end
60  */
61  AUTH_BADCRED=1, /* bogus credentials (seal broken) */
62  AUTH_REJECTEDCRED=2, /* client should begin new session */
63  AUTH_BADVERF=3, /* bogus verifier (seal broken) */
64  AUTH_REJECTEDVERF=4, /* verifier expired or was replayed */
65  AUTH_TOOWEAK=5, /* rejected due to security reasons */
66  /*
67  * failed locally
68  */
69  AUTH_INVALIDRESP=6, /* bogus response verifier */
70  AUTH_FAILED=7, /* some unknown reason */
71  _AUTH_STAT = 0xffffffff
72 };
73
74 union des_block {
75  struct {
76  u_int32_t high;
77  u_int32_t low;
78  } key;
79  char c[8];
80 };
81 typedef union des_block des_block;
82 __BEGIN_DECLS
83 extern bool_t xdr_des_block (XDR *, des_block *);
84 __END_DECLS
85
86 /*
87  * Authentication info. Opaque to client.
88  */
89 struct opaque_auth {
90  enum_t oa_flavor; /* flavor of auth */
91  caddr_t oa_base; /* address of more auth stuff */
92  u_int oa_length; /* not to exceed MAX_AUTH_BYTES */
93 };
94 __BEGIN_DECLS
95 bool_t xdr_opaque_auth (XDR *xdrs, struct opaque_auth *ap);
96 __END_DECLS
97
98
99 /*
100  * Auth handle, interface to client side authenticators.
101  */
102 typedef struct __rpc_auth {
103  struct opaque_auth ah_cred;
104  struct opaque_auth ah_verf;
105  union des_block ah_key;
106  struct auth_ops {
107  void (*ah_nextverf) (struct __rpc_auth *);
108  /* nextverf & serialize */
109  int (*ah_marshal) (struct __rpc_auth *, XDR *);
110  /* validate verifier */
111  int (*ah_validate) (struct __rpc_auth *,
112  struct opaque_auth *);
113  /* refresh credentials */
114  int (*ah_refresh) (struct __rpc_auth *);
115  /* destroy this structure */
116  void (*ah_destroy) (struct __rpc_auth *);
117  } *ah_ops;
118  caddr_t ah_private;
119 } AUTH;
120
121
122 /*
123  * Authentication ops.
124  * The ops and the auth handle provide the interface to the authenticators.
125  *
126  * AUTH *auth;
127  * XDR *xdrs;
128  * struct opaque_auth verf;
129  */
130 #define AUTH_NEXTVERF(auth) \
131  ((*((auth)->ah_ops->ah_nextverf))(auth))
132 #define auth_nextverf(auth) \
133  ((*((auth)->ah_ops->ah_nextverf))(auth))
134
135 #define AUTH_MARSHALL(auth, xdrs) \
136  ((*((auth)->ah_ops->ah_marshal))(auth, xdrs))
137 #define auth_marshall(auth, xdrs) \
138  ((*((auth)->ah_ops->ah_marshal))(auth, xdrs))
139
140 #define AUTH_VALIDATE(auth, verfp) \
141  ((*((auth)->ah_ops->ah_validate))((auth), verfp))
142 #define auth_validate(auth, verfp) \
143  ((*((auth)->ah_ops->ah_validate))((auth), verfp))
144
145 #define AUTH_REFRESH(auth) \
146  ((*((auth)->ah_ops->ah_refresh))(auth))
147 #define auth_refresh(auth) \
148  ((*((auth)->ah_ops->ah_refresh))(auth))
149
150 #define AUTH_DESTROY(auth) \
151  ((*((auth)->ah_ops->ah_destroy))(auth))
152 #define auth_destroy(auth) \
153  ((*((auth)->ah_ops->ah_destroy))(auth))
154
155
156 extern struct opaque_auth _null_auth;
157
158 /*
159  * These are the various implementations of client side authenticators.
160  */
161
162 /*
163  * Unix style authentication
164  * AUTH *authunix_create(machname, uid, gid, len, aup_gids)
165  * char *machname;
166  * int uid;
167  * int gid;
168  * int len;
169  * int *aup_gids;
170  */
171 __BEGIN_DECLS
172 struct sockaddr_in;
173 extern AUTH *authunix_create (char *, int, int, int, int *);
174 extern AUTH *authunix_create_default (void);
175 extern AUTH *authnone_create (void);
176 __END_DECLS
177
178 /* Forward compatibility with TI-RPC */
179 #define authsys_create authunix_create
180 #define authsys_create_default authunix_create_default
181
182 /*
183  * DES style authentication
184  * AUTH *authdes_create(servername, window, timehost, ckey)
185  * char *servername; - network name of server
186  * u_int window; - time to live
187  * struct sockaddr *timehost; - optional hostname to sync with
188  * des_block *ckey; - optional conversation key to use
189  */
190 __BEGIN_DECLS
191 extern AUTH *authdes_create ( char *, u_int, struct sockaddr *, des_block * );
192 #ifdef NOTYET
193 /*
194  * TI-RPC supports this call, but it requires the inclusion of
195  * NIS+-specific headers which would require the inclusion of other
196  * headers which would result in a tangled mess. For now, the NIS+
197  * code prototypes this routine internally.
198  */
199 extern AUTH *authdes_pk_create ( char *, netobj *, u_int,
200  struct sockaddr *, des_block *,
201  nis_server * );
202 #endif
203 __END_DECLS
204
205 /*
206  * Netname manipulation routines.
207  */
208 __BEGIN_DECLS
209 extern int netname2user ( char *, uid_t *, gid_t *, int *, gid_t *);
210 extern int netname2host ( char *, char *, int );
211 extern int getnetname ( char * );
212 extern int user2netname ( char *, uid_t, char * );
213 extern int host2netname ( char *, char *, char * );
214 extern void passwd2des ( char *, char * );
215 __END_DECLS
216
217 /*
218  * Keyserv interface routines.
219  * XXX Should not be here.
220  */
221 #ifndef HEXKEYBYTES
222 #define HEXKEYBYTES 48
223 #endif
224 typedef char kbuf[HEXKEYBYTES];
225 typedef char *namestr;
226
227 struct netstarg {
228  kbuf st_priv_key;
229  kbuf st_pub_key;
230  namestr st_netname;
231 };
232
233 __BEGIN_DECLS
234 extern int key_decryptsession ( const char *, des_block * );
235 extern int key_decryptsession_pk ( char *, netobj *, des_block * );
236 extern int key_encryptsession ( const char *, des_block * );
237 extern int key_encryptsession_pk ( char *, netobj *, des_block * );
238 extern int key_gendes ( des_block * );
239 extern int key_setsecret ( const char * );
240 extern int key_secretkey_is_set ( void );
241 extern int key_setnet ( struct netstarg * );
242 extern int key_get_conv ( char *, des_block * );
243 __END_DECLS
244
245 /*
246  * Publickey routines.
247  */
248 __BEGIN_DECLS
249 extern int getpublickey ( char *, char * );
250 extern int getpublicandprivatekey ( char *, char * );
251 extern int getsecretkey ( char *, char *, char * );
252 __END_DECLS
253
254
255 #define AUTH_NONE 0 /* no authentication */
256 #define AUTH_NULL 0 /* backward compatibility */
257 #define AUTH_UNIX 1 /* unix style (uid, gids) */
258 #define AUTH_SYS 1 /* forward compatibility */
259 #define AUTH_SHORT 2 /* short hand unix style */
260 #define AUTH_DES 3 /* des style (encrypted timestamps) */
261
262 #endif /* !_RPC_AUTH_H */
Definition: in.h:74
Definition: xdr.h:104
Definition: xdr.h:278
Definition: socket.h:180
Definition: auth.h:228
Definition: auth.h:103
Definition: auth.h:107
Definition: auth.h:90
