asm.h
1
17 /*
18  * COPYRIGHT:
19  *
20  * This file is based on similar code found in newlib available
21  * from ftp.cygnus.com. The file which was used had no copyright
22  * notice. This file is freely distributable as long as the source
23  * of the file is noted. This file is:
24  *
25  * COPYRIGHT (c) 2000 Canon Research Centre France SA.
26  * Emmanuel Raguet, mailto:raguet@crf.canon.fr
27  *
28  * The license and distribution terms for this file may be
29  * found in the file LICENSE in this distribution or at
30  * http://www.rtems.org/license/LICENSE.
31  *
32  */
33
34 #ifndef _RTEMS_ASM_H
35 #define _RTEMS_ASM_H
36
37 /*
38  * Indicate we are in an assembly file and get the basic CPU definitions.
39  */
40
41 #ifndef ASM
42 #define ASM
43 #endif
44 #include <rtems/score/percpu.h>
45
55 /*
56  * Recent versions of GNU cpp define variables which indicate the
57  * need for underscores and percents. If not using GNU cpp or
58  * the version does not support this, then you will obviously
59  * have to define these as appropriate.
60  */
61
62 #ifndef __USER_LABEL_PREFIX__
63 #define __USER_LABEL_PREFIX__ _
64 #endif
65
66 #ifndef __REGISTER_PREFIX__
67 #define __REGISTER_PREFIX__
68 #endif
69
70 #include <rtems/concat.h>
71
72 /* Use the right prefix for global labels. */
73
74 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
75
76 /* Use the right prefix for registers. */
77
78 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
79
80 /*
81  * define macros for all of the registers on this CPU
82  *
83  * EXAMPLE: #define d0 REG (d0)
84  */
85
86 #define r0 REG(r0)
87 #define r1 REG(r1)
88 #define r2 REG(r2)
89 #define r3 REG(r3)
90 #define r4 REG(r4)
91 #define r5 REG(r5)
92 #define r6 REG(r6)
93 #define r7 REG(r7)
94 #define r8 REG(r8)
95 #define r9 REG(r9)
96 #define r10 REG(r10)
97 #define r11 REG(r11)
98 #define r12 REG(r12)
99 #define r13 REG(r13)
100 #define r14 REG(r14)
101 #define r15 REG(r15)
102
103 #define CPSR REG(CPSR)
104
105 #define SPSR REG(SPSR)
106
107 #define NUM_IRQ_VECTOR 6 // IRQ number
108 #define NUM_FIQ_VECTOR 7 // IRQ number
109  // //
110 #define CPSR_IRQ_DISABLE 0x80 // FIQ disabled when =1
111 #define CPSR_FIQ_DISABLE 0x40 // FIQ disabled when =1
112 #define CPSR_THUMB_ENABLE 0x20 // Thumb mode when =1
113 #define CPSR_FIQ_MODE 0x11
114 #define CPSR_IRQ_MODE 0x12
115 #define CPSR_SUPERVISOR_MODE 0x13
116 #define CPSR_UNDEF_MODE 0x1B
117
118 #define CPSR_MODE_BITS 0x1F
119
120 /*
121  * Define macros to handle section beginning and ends.
122  */
123
124
125 #define BEGIN_CODE_DCL .text
126 #define END_CODE_DCL
127 #define BEGIN_DATA_DCL .data
128 #define END_DATA_DCL
129 #define BEGIN_CODE .text
130 #define END_CODE
131 #define BEGIN_DATA
132 #define END_DATA
133 #define BEGIN_BSS
134 #define END_BSS
135 #define END
136
137 /*
138  * Following must be tailor for a particular flavor of the C compiler.
139  * They may need to put underscores in front of the symbols.
140  */
141
142 #define PUBLIC(sym) .globl SYM (sym)
143 #define EXTERN(sym) .globl SYM (sym)
144
145 #define FUNCTION_THUMB_ENTRY(name) \
146  .thumb; \
147  .thumb_func; \
148  .align 2; \
149  .globl name; \
150  .type name, %function; \
151  name:
152
153 #define FUNCTION_ENTRY(name) \
154  .align 2; \
155  .globl name; \
156  .type name, %function; \
157  name:
158
159 #define FUNCTION_END(name) \
160  .size name, . - name
161
162 #if defined(ARM_MULTILIB_ARCH_V7M)
163  #define DEFINE_FUNCTION_ARM(name) \
164  .thumb_func ; .globl name ; name:
165 #elif defined(__thumb__)
166  #define DEFINE_FUNCTION_ARM(name) \
167  .thumb_func ; .globl name ; name: ; bx pc ; \
168  .arm ; .globl name ## _arm ; name ## _arm:
169 #else
170  #define DEFINE_FUNCTION_ARM(name) \
171  .globl name ; name: ; .globl name ## _arm ; name ## _arm:
172 #endif
173
174 .macro SWITCH_FROM_THUMB_TO_ARM
175 #ifdef __thumb__
176 .align 2
177  bx pc
178 .arm
179 #endif /* __thumb__ */
180 .endm
181
182 .macro SWITCH_FROM_ARM_TO_THUMB REG
183 #ifdef __thumb__
184  add \REG, pc, #1
185  bx \REG
186 .thumb
187 #endif /* __thumb__ */
188 .endm
189
190 .macro GET_SELF_CPU_CONTROL REG, TMP
191  ldr \REG, =_Per_CPU_Information
192 #ifdef RTEMS_SMP
193  /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
194  mrc p15, 0, \TMP, c0, c0, 5
195
196  and \TMP, \TMP, #0xff
197  add \REG, \REG, \TMP, asl #PER_CPU_CONTROL_SIZE_LOG2
198 #endif
199 .endm
200
203 #endif /* _RTEMS_ASM_H */
#define REG(x)
Definition: asm.h:72
This include file defines the per CPU information required by RTEMS.
This include file defines ANSI concatenation macros.
