The stack bounds checker is an RTEMS support component that determines if a task has overrun its run-time stack. The routines provided by the stack bounds checker manager are:
rtems_stack_checker_is_blown - Has the Current Task Blown its Stack
rtems_stack_checker_report_usage - Report Task Stack Usage
