void rtems_interrupt_flash( rtems_interrupt_level level );
NONE
This directive temporarily enables maskable interrupts to the level
which was returned by a previous call to
rtems_interrupt_disable.
Immediately prior to invoking this directive, maskable interrupts should
be disabled by a call to rtems_interrupt_disable
and will be redisabled when this directive returns to the caller.
This directive will not cause the calling task to be preempted.
