BSP and Device Driver Development Guide
The Shm_Convert_address is responsible for converting an address
of an entity in the shared memory area into the address that should be
used from this node. Most targets will simply return the address
passed to this routine. However, some target boards will have a special
window onto the shared memory. For example, some VMEbus boards have
special address windows to access addresses that are normally reserved
in the CPU's address space.
void *Shm_Convert_address( void *address )
return the local address version of this bus address
