BSP and Device Driver Development Guide
The benchmark_timer_read routine returns the number of benchmark
time units (typically microseconds) that have elapsed since the last
call to benchmark_timer_initialize.
int benchmark_timer_read(void)
stop time = read the hardware timer
if the subtract overhead feature is enabled
subtract overhead from stop time
return the stop time
Many implementations of this routine subtract the overhead required to initialize and read the benchmark timer. This makes the times reported more accurate.
Some implementations report 0 if the harware timer value change is sufficiently small. This is intended to indicate that the execution time is below the resolution of the timer.
