BSP and Device Driver Development Guide
The console_control is invoked when the line parameters for a particular
serial device are to be changed. This entry point corresponds to the device
driver io_control entry point.
The application writer is able to control the serial line configuration with
Termios calls (such as the ioctl command, see the Termios documentation
for more details). If the driver is to support dynamic configuration, then it
must have the console_control piece of code. Basically ioctl
commands call console_control with the serial line configuration in a
Termios defined data structure.
rtems_device_driver console_control(
rtems_device_major_number major,
rtems_device_minor_number minor,
void *arg
return rtems_termios_ioctl(arg);
The driver is responsible for reinitializing the device with the correct
settings. For this purpuse Termios calls the my_driver_set_attributes
function.
static int my_driver_set_attributes(
int minor,
const struct termios *t
my_driver_entry *e = &my_driver_table [minor];
* There is no need to check the minor number since it is derived
* from a file descriptor. The upper layer takes care that it is
* in a valid range.
* Inspect the termios data structure and configure the device
* appropriately. The driver should only be concerned with the
* parts of the structure that specify hardware setting for the
* communications channel such as baud, character size, etc.
return 0;
