BSP and Device Driver Development Guide
The console_close is invoked when the serial device is to be closed.
This entry point corresponds to the device driver close entry point.
This routine is responsible for notifying Termios that the serial device was
closed. This is done with a call to rtems_termios_close.
rtems_device_driver console_close(
rtems_device_major_number major,
rtems_device_minor_number minor,
void *arg
return rtems_termios_close(arg);
Termios will call the my_driver_last_close function if the last close
happens on the device.
static int my_driver_last_close(int major, int minor, void *arg)
my_driver_entry *e = &my_driver_table [minor];
* There is no need to check the minor number since it is derived
* from a file descriptor. The upper layer takes care that it is
* in a valid range.
/* Disconnect the TTY data structure */
e->tty = NULL;
* The driver may do some cleanup here.
return 0;
