BSP and Device Driver Development Guide
The following functions are provided by the driver and invoked by Termios for simple character IO.
The my_driver_poll_write routine is responsible for writing n
characters from buf to the serial device specified by minor.
static int my_driver_poll_write(int minor, const char *buf, int n)
my_driver_entry *e = &my_driver_table [minor];
int i = 0;
* There is no need to check the minor number since it is derived
* from a file descriptor. The upper layer takes care that it is
* in a valid range.
/* Write */
for (i = 0; i < n; ++i) {
my_driver_write_char(e, buf [i]);
return 0;
The my_driver_poll_read routine is responsible for reading a single
character from the serial device specified by minor. If no character is
available, then the routine should return minus one.
static int my_driver_poll_read(int minor)
* in a valid range.
/* Check if a character is available */
if (my_driver_can_read_char(e)) {
/* Return the character */
return my_driver_read_char(e);
} else {
/* Return an error status */
return -1;
