BSP and Device Driver Development Guide
This file contains the results of the RTEMS Timing Test Suite. It is in a standard format so that results from one BSP can be easily compared with those of another target board.
If a BSP supports multiple variants, then there may be multiple times
files. Usually these are named times.VARIANTn
